Question about Dryers
Dryer stopped drying. - Dryers
    Novelist:
  • 184 Answers
IS IT HEATING? IF YES, IS THE DRUM TURNING? IF YES,
THERE IS A RESTRICTION IN THE AIR FLOW SOMEWHERE.
CHECK THE OPERATION WITHOUT THE VENT ATTACHED TO THE DRYER FOR ONE LOAD.DOES IT DRY O.K?
THERE IS A RESTRICTION IN YOUR EXHAUST.MAKE SURE YOU DON'T PUSH THE DRYER TIGHT AGAINST THE WALL. YOU MIGHT PINCH OFF THE FLEX VENT MATERIAL. YOU CAN'T JUDGE THE AIR FLOW BY VIEWING WHERE THE VENTING GOES OUTSIDE. IT MIGHT HAVE AIR FLOWING OUT IT, BUT CAN STILL BE RESTRICTED. REMOVE THE SECTIONS OF DUCT AND CLEAN OUT THE LINT FROM THEM. IF YOU HAVE FLEXIBLE MATERIAL RUNNING A LONG DISTANCE, GET RID OF IT. USE ONLY 4INCH RIGID METAL PIPE FOR LONG DISTANCES. THEN CONNECT TO IT WITH A SHORT PIECE OF METAL FLEXIBLE MATERIAL.
Posted on Apr 08, 2008
Leq2152ee1 dryer does dry but keeps stopping if put on any setting over 15 min. Dryer stops single beep and top four lights blink.
MAY BE BAD MOTOR WITH BAD WINDINGS USUALLY STOPS AFTER 20 MINUTES OF USE? OR HEATING ELEMENT IS OVERHEATING? DUE TO BAD VENTING? THERMAL CUT OFF KEEPS SHUTTING IT DOWN?
May 08, 2014 | Frigidaire GLEQ2152ES Electric Dryer
Kenmore 11066912690 dryer stops working
if you are using the sensor drying cyle this could cause the unit to stop. it will detect the most dry clothing first usually light clothes that dry faster.if not and you are useing timed dry the most likely cause is a faluty timer,or a thermostat sesnor is going bad and turnoing off the dryer before the clothes are dry
Sep 16, 2009 | Kenmore 62602 Electric Dryer
Dryer stops working after 2 minutes into cycle
If it is new, is it not under warranty?
does it run ok on air dry? Is there good air flow?
post your answers in comments
May 14, 2017 | Whirlpool WED9500T Electric Dryer
Dryer stops working after 10 minutes
Motor may be over heating.may need new motor.
Mar 01, 2009 | Kenmore 73952 Gas Dryer
Drying timer on auto dry
I called LG...they said to unplug the dryer for 5 min. to reset the timer ...this solved the problem.
They also said not to use dryer sheets during the sensor dry cycle as the coating on the dryer sheets causes the sensor to malfunction as it can't read the humidity level in the dryer.
Dec 28, 2008 | LG Dryers
Dryer stop drying
Check you venting,on gas units call for service.
Mar 17, 2008 | Maytag MDE2600 Electric Dryer
LG DLG2532 Gas Dryer will only dry on manual setting
If you use dryer sheets, LG recommends no.  Dryer sheets cause a film that will not allow the sensors to feel the clothes moisture during the drying process thereby causing the computer to countdown the timer quickly.  To clean out the sensors, use a green pad and scrub the sensor bars inside the dryer drum.  That should remove the film left by the dryer sheets.
Mar 12, 2008 | LG DLG2532 Gas Dryer
Dryers Logo
67 people viewed this question
Top Dryers Experts
