Question about Haier HLC26R1 26 in HDTVReady TVDVD Combo
Dvd won't play
I have a Haier 26" DVD/Combo and the DVD will no longer play. This is set up only for DVD playing with no other inputs.
    Novelist:
  • 112 Answers
The following suggestion may or may not fix your DVD reader.
You can put a CD/DVD cleaner disk to put into your TV to clean the laser’s eye. The best cleaner disks have the “whisker” that protrudes from the disk and have a fluid you put on the whiskers to aid in the cleaning. Read the cleaner’s directions before using.
You will want to put this disk in your TV at least at three different times to maximize the cleaning.
After you have completed the cleaning, unplug the TV for about 3 minutes. Plug the TV back in and try a non scratched DVD in your TV to see if the cleaning has fixed your problem.
If the TV takes a long time to read the disks and or the TV is not able to read the disks, then the DVD assembly has failed. You could purchase a replacement DVD assembly and install it yourself if you think you are up to it. You just have to remove the stand, the back of the unit, and the old DVD assembly.
I hope this information has helped you.
Good Luck.
Posted on May 28, 2010
Alba dvd/tv combo playing dvd's in black and white
There are a couple of things you could try with this. One, is to make sure that the video input is connected properly. The second would be to make sure that the DVD that played in black and white automatically changed your settings to PAL rather than NTSC
May 13, 2012 | Televison & Video
The DVD player keeps opening and closing and won't play/load DVD's. What could be the problem?
There are sensors which tell the DVD drive that the drawer is closed and that there is a DVD inserted, if these fail there is usually no simple fix, the parts need to be replaced which requires complete dis-assesembly of the TV/DVD, Most people just choose to connect an external DVD as it is cheaper.
Mar 07, 2012 | V7 VC2607 26 in. LCD TV/DVD Combo
No sound playing on rca 26 in tv/dvd combo
Have you tried going into sound settings and seeing if the sound output is set to Tv speakers and not external sound system?
Dec 02, 2011 | RCA Televison & Video
Toshiba 26 inch lcd tv/dvd combo lost picture
I have same problem with a 7 month old Toshiba 26LV610U LCD TV/DVD combo.
Feb 10, 2010 | Toshiba 26HLV66 26 in. LCD TV/DVD Combo
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
DVD picture is in Black & White only.
Are you trying to play an NTSC disc in a PAL player, If so,your player has a switch or
on-screen setting to select the output format for NTSC discs,
Or maybe you have connected one of the component outputs (Y, R-Y, or B-Y) of
your DVD player to the composite input of your TV.
Please rate this solution
Jan 20, 2009 | Toshiba 26AV500U 26 in. LCD HDTV
Dvd does not play need help.
u have a off brand tv set that will not get and parts to service it go buy a cheep dvd player for $29.00 at walmart i know u dont wont here this but it is true when u buy the off brands llike the one u have u donot repair them u just go buy another one sorry i hpe this helps u
Oct 13, 2008 | Haier 20" TV/DVD Combo
Haier HLC26R1 26 in HDTVReady TVDVD Combo Logo
174 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
