Question about Video Game Consoles & Games
I RECENTLY PURCHASED A LINKSYS ROUTER #BEFSR41 CABLE/DSL ROUTER AND AT TIMES I AM ABLE TO CONNECT TO THE INTERNET ON MY COMPUTER BUT I CANT CONNECT TO XBOX LIVE THRU MY 360 AND AT TIMES ITS THE OTHER WAY AROUND. I NOTICED THAT AFTER INPUTING MY ROUTERS ADRESS THERE SEEMS TO BE A GAMING TAB THAT SHOWS DEIFFERENT PORT NUMBERS BUT I NEED HELP SETTING THAT UP IF THAT IS THE PROBLEM TO WHAT I MENTIONED ABOVE.
    Sergeant:
    Champion:
  • 427 Answers
The port tab wouldnt have any affect on the problem. I had a similar problem as you and it is the console just simply massing everything up. Solution: restore Factory settings on the console and reset your entire network.
Posted on Apr 08, 2008
Internet wont work thru my Linksys BEFSR41 Cable/DSL Router W/4 Port Switch.....can i fix it or do i need a new one?
hi there, you need to configure the router first to connect over the internet.
checked if everything is properly connected, modem-router to the computer, checked the lights on the router and the modem as well if it is properly lit up.
if your ISP(Internet Provider) is cable then you need to clone the mac address of the computer, if you are running DSL, you need to input the username and password of your account from your ISP.
Accessing the router setup screen, open IE and type on the address bar 192.168.1.1 then nothing for username and password is admin.
on the setup screen you will see there Internet connection type, by default it is automatic configuration if you have cable connection as your Internet then leave it that way and look for mac address clone sub tab.
if you are running dsl for the Internet connection type you need to put PPPoE and input there your username and password from your ISP. then in everything you do you need to save the settings there.
tell me if it
Jun 26, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
hi,
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
Woodenthings
Your provider probably sent you either a cable modem or adsl modem. If you connect the single port on the modem to the WAN or Internet Port on the Linksys and then connect the computers to any of the 4 ports that are grouped together, it should work.
Mac or PC, it makes no difference and drivers are not needed.
Unless this is a new router or it is one that you personally configured, I recommend resetting it back to factory default by holding down the little red button for 30 seconds, this eliminates any configuration issues that someone else may have introduced.
Jan 03, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Cant get to internet thru linksys etherfast cable/dsl router
Reset the modem while the router is plugged into it. Do this by disconnecting the power to the modem and then reconnecting.
Nov 09, 2008 | Linksys EtherFast Cable/DSL Router
Linksys Cable/DSL Router model BEFSR4141
Since you did not include the type of internet provider I cannot give you more specific instructions. Although you can refer to the links below on how to set it up. If you require further assistance just reply to this and give me the model number of your ISP and the model of your router. Also answer this question " When you plug your computer to your modem do you get online automatically or do you need a username and password"
DSL
Cable
Oct 25, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
I cannot install the CD for my router
u can simply connect connect modem to internet port on router and connect no 4 of linksys to computer and u will be able to go online ....
Oct 22, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys Rouer BFR stops functioning
There's a possibility that the router is already going bad but you can try first updating the firmware of the router because sometimes this problem is related to the software of the router so you may need to update its firmware,but if still after updating and still the same a new router will be the best solution for this problem of yours..You can also call this number for technical support help and double checking if the router is bad or still can be fix 1-877-787-8749...
Don't forget to rate the solution FIXYA thank you....
Oct 18, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Video Game Consoles & Games Logo
27 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
