Question about Longines Dolce Vita 18K Solid White Gold & Diamonds L51557847 Watch for Women
Hi my 18k longines dolce vita chrono functions no longer reset to zero after replacing the battery, is there a quick fix?
  • 29 Answers
SOURCE: Invicta Ocean Ghost Chrono Model# 2636
Did you recently have a battery changed. A lot of times on chronos when the battery is changed the battery has to be short circuited to the AC. Which is done by taking tweezers. & touching the positive part of the battery to the part of the watch marked AC. Then try to pull the crown all the way out to time setting position press the top rt button & the second should move keep moving until it lines up with zero. If you haven't had the battery changed try what I told you to do with the crown & the top right button.
Posted on Mar 13, 2008
SOURCE: Hand on chrono won't reset to zero
It all depends on what kind of watch you have. On most watches you want to pull the stem out ( the part used to set the hands) HALF way, you will feel the "click" as you do this. Then I can't tell you which button ( because they are all differant on every watch) but one of the buttons will move the hand to the correct zeroing spot for you.
Posted on Jun 29, 2008
escapement
  • 2334 Answers
SOURCE: how to zero the chrono second hand( doesn't reset to zero)
Paste this link into your browser, find your movement caliber number and download instructions how to reset your Citizen watch:
http://www.citizenwatch.com/COA/English/settings.asp
Do not forget to rate, please.
Posted on Jan 22, 2009
escapement
  • 2334 Answers
SOURCE: The minute counter on my chrono won't reset to zero.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
Posted on Jul 31, 2009
  • 11 Answers
SOURCE: How do you reset all chrono counters so they are
Pull the crown (winder knob) out all the way, zero with the lower button, then push the crown back in. Job done.
Posted on Aug 26, 2009
My Coifman sc0170 has stopped working , I've only worn it 6 or 7 times i bought it in March 2016 , after wearing the watch I always put it back in its box any I dears plz
I see that this is a quartz chrono. Firstly, make sure that the crown (winder) is fully pushed in. If you have had the chronograph function running all the time, this will deplete the battery quite quickly. Also, when you buy a watch, depending on where you bought it, it may have been running for some time perhaps as a display model so the battery might already be well used.
If pressing the crown in doesn't sort it, get the battery replaced. If that doesn't get the watch running then you should return it as faulty (as it was a very recent purchase). If battery replacement does get the watch going then you might want to read the manual to ensure that you're not constantly running the chrono function, which will seriously reduce the battery life..
Jun 05, 2016 | Watches
Skagen manual 747lsxn
Stop the chrono with top button (if it is running) reset with bottom button. If hand does not zero pull out winder to position 2 and use top button to forward to zero by single steps or hold to move faster. #push winder back and chrono hand should be zeroed.
May 23, 2014 | Skagen Mens Sport 747LSXN
How to reset the chrono function of a Tag Heuer Aquaracer Calibre S CAF7113.FT8010 after a battery change
Pull the crown out to the first position, and then you may find that successive pushes of the upper pushbutton will move one of the chrono hands by one division, and the lower pushbutton will move a different chrono hand. Similarly if you pull the crown out to the second position, the pushbuttons will control the other chrono hands. In this way you can set each of the chrono hands to their zero positions. Hope this works..
Jan 17, 2014 | Tag Heuer Aquaracer Calibre S...
Please clarify use of the 3 smaller dials and how the hands to each are set and reset
The small bottom dial is seconds counter and there is no option to set or reset it as it is part of the main gear train - it just counts the seconds. Top right dial is 1/10 seconds counter and runs only when the chronograph function is engaged. One full circle indicates 1 second. Top left dial is 30 minutes counter and runs only when the chronograph function is engaged. One full circle indicates 30 minutes, two circles = 1 hour. The big centre seconds hand is actually Chronograph hand and runs only when the chrono function is engaged. So, the chronograph hand and two top dials works all together when chrono function is engaged. To start chrono: push upper button once. To stop chrono: push upper button again (once). To return all hands to zero: push lower button once. There is another option: if you already stopped chrono by pushing upper button, but want to continue counting without returning hands to zero, push the upper button once more and the counting will start from the point where it stopped. You can repeat this as many as you wish - it will count on and on, till you will stop it and reset to zero. Fine tuning of chrono hands can be made by pulling the crown half way out and while leaving in this position pushing and holding one of the push buttons (which one - depends on movement caliber). Watch has an tachymeter function as well (big inner ring). Learn how to use it by browsing through my Tips and Tricks- it is explained there. Rate me, please.
Feb 28, 2011 | Calvin Klein K7547107 Celerity Watch for...
Pulsar chrono hand alignment
mcdedevito75 here, Return to the watch rep[air that installed the battery for adjustmaet.
Jul 03, 2010 | Seiko Pulsar watch
Touch function is not working
I had the same issue. After installing the battery and trying to calibrate several times... to no avail.I tried pressing the T button, keeping it pressed down and then install the battery. It give you a mode or function setting ( I'm not sure what it means). i then press the T button and it cycles through these mode setting. I synchronized the hands and then was able to get the: altimeter, compass, meteo, date and time working. The temp, chrono still doesn't work.
I think getting all the functions to work, depends on the mode setting... but i don't know the correct setting.
Jun 30, 2010 | Tissot T-Touch T33759851
Reset chronograph
Hi, I had the same problem and was able to fix it by reading the manual:
Basic Settings for the chronograph hand -
After changing the battery, or in exceptional circumstances, following incorrect operation, it is necessary to reset the Chrono indicator to zero (starting time).
- Leave the winder in Position 1 (pushed all the way in)
- Press button H (top) and button I (bottom) at the same time
- Now set the 30 minute (small hand) counter to zero by pressing/holding button I (bottom button)
- You can now set the 60 second counter to zero by pressing/holding button H (top button).
This worked for me... it took me a while to figure it out, but that
Jun 04, 2010 | Maurice Lacroix Masterpiece Flyback...
Timex 1854 chrono,indigo lght not working. 2nd one in 4 mths?
the same problem, after 3 years of use.
Night Indiglo light was very bad.
thought the battery replaced it, the battery was okay.
began to collect but probably need a special tool, the glass cracked)
Sep 09, 2009 | Timex Watches
How do you set and deactivate the alarm function.
I did find two authorized dealers:
www.kenmarwatches.com
www.princetownwatches.com
Contact both and request users manual fur your specific model. They must be able to help.
Jan 05, 2009 | Bulova Watch
Mar 13, 2008 | Invicta 2636 Ocean Ghost Chronograph Watch
Longines Dolce Vita 18K Solid White Gold & Diamonds L51557847 Watch for Women Logo
81 people viewed this question
Top Longines Watches Experts
michaelrt616
Andrew Taylor
Andrew Taylor
Are you a Longines Watch Expert? Answer questions, earn points and help others
