Question about GE Profile 23.3 Cu. Ft. Counter-Depth Side-by-Side Refrigerator - Stainless-Steel
Model psc23sgpass GE Profile freezer and frig do not get cold enough. I have already cleaned the condenser and defrosted the freezer. We seem to have determined the evap dc fan motor is not running. But I have purchase new and tried it and it also seem to not run. Is there a check I can do on the fan motor to confirm the original is bad. Also what else may prevent this from running when called for.
  • 619 Answers
The fan is controlled thru the main control board located on the back of your refrigerator. Pull unit away from the wall and you will see a metal plate. The board is located there and you will need to replace the board. This is a common problem with the GE's. The board is pricey but better than a new refrigerator. If an appliance company told you the fan was bad you should try and get them to refund the fan. wr 55x10942 is the number you need.
Posted on May 28, 2010
Testimonial: "Yep! This was my next step. I replaced the control board and it ran my old evap fan motor. The freezer and refrig are at the proper temp. again. I was able to return the new evap fan motor I bought and tried for full credit."
Ge profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing both fridge and freezer same
Not sure if the compressor is running. If not, you'll need a repair man. Since fans are running, most likely the thermistor. Also, if you haven't unplug from the wall, wait 10 seconds then plug back in; this may reset the control board. The link below may help. GE Refrigerator Not Cold Enough
Feb 03, 2015 | GE Refrigerators
Freezer will not go below 20 degrees.
Most likely the defrost heater is not turning off. Either a bad limit switch or a bad timer.
Nov 05, 2014 | GE Refrigerators
Why is freezer/Frig at 51/59 degrees with both fans running?
Good Morning Friend,
I understand your Frigidaire refrigerator, model# FRT18G6JB6, is not cooling well. I also see that you have checked the gaskets, cleaned the condenser coil, and manually defrosted your refrigerator. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why it is not cooling. Hope this is helpful,
-Best Regards-
WP
Jun 23, 2014 | Frigidaire Refrigerators
Ge profile bottom freezer (model GFSS6KIX) not keeping freezer cold enough. Water under veggie drawers.
First, check the condenser coils for any lint and dirt buildup and see if the condenser fan is running fast.
Post back your results.
Nov 04, 2012 | GE Profile 26.6 cu. ft. Side-by-Side...
The defroster on my GE profile side-by-side is not working. Now what?
Locate the wiring diagram, it should be somewhere on the unit. Letting the unit completely defrost so the ice is removed from the back will help. The autodefrost circuit may be defective, the heating elelment could be burned out, there may be a faulty wire, a faulthy thermal sensor, each would need to be checked for continuity.
Also check to make sure the fan inside cabinet works correctly.
Apr 11, 2012 | GE Refrigerators
Not defrosting and back of frig is iced up
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fgjety
May 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE 24 Profile refrigerator: The freezer part
my refrigerator goes into auto defrost every 60hrs for 45 minutes or till the bi metal(defrost thermostat) says it had enough....recently i had ice built up on the coil because my defrost thermostat was stuck open...
ice builds up because the moisture that comes from opening the door or food condenses on the cold coil...tempurature of the coil is below 32 degrees which will ice up the condensed moisture...
defrost is timed to remove this build up
Oct 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer isn't freezing all of a sudden but frig. side is still cold
There is a cheap repair manual for this model listed on eBay. The item number is 200262539606.
Premmy
Oct 14, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile 23.3 Cu. Ft. Counter-Depth Side-by-Side Refrigerator - Stainless-Steel Logo
734 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
