Question about All-Pro Propane Garage Shop Heaters - All Pro SPC 125 Forced Air Propane Space Heater
Terrible smell and burns my eyes from 5gallon tank. First 5gallon tank was find as is small Coleman bottle . Can propane be bad from Supplier. It gives off sour smell and irritates eyes when burning?
  • ddrummerdan May 28, 2010
    All propane has a smell to it...and irritates your eyes.Did you allways have this problem?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 195 Answers
I would not use it any further, I cant say if anything is in the gas, I doubt it, However the propane at too low a pressure etc, can cause this, dont use it with eyes butrning ever!
Posted on May 29, 2010
Bad propane gas bottle - is it possible to get bad gas in new propane bottles?
The supplier's bulk propane tank either is not equipped with a moisture filter in the discharge line or the filter is ineffective.
Feb 06, 2017 | Heating & Cooling
Way is my machine using to much propane
Are you smelling gas around the grill or tank? Fill a spray bottle with soapy water, slowly turn on the tank valve, and check for leaks at the tank valve, hose, regulator, as well as each gas valve (remove the knobs first). If no smell or leak is found, check your burners to see if they are burning mostly blue. If they are lazy yellow, they could be dirty or partially clogged and require cleaning; or possibly rusted through and need replaced.. If you do have blue flames, consider turning down the burners for a reduced flame and see if that helps.
Apr 30, 2015 | Grilling
There is white smoke coming out the tailpipe no smell of antifreeze
If it doesn't smell like sweet then you most likely got a bad tank of gas. Just to be safe keep an eye on your engine temp. and coolant levels.
Mar 26, 2011 | 1993 Dodge Intrepid
We polyurethaned a floor now our propane gas heaters, when on smells terrible
hI it sound like the smell ha sgot in to the fire open the windos and try and burn the smell off but keep a eye on it when you do this , just for safety
Feb 06, 2010 | Desa International GWP20T GLOWARM Wall...
Raw propane fumes and burning eyes
Ours didn,t burn liquid propane too well, so ccheck your connections on your tank for vapor or liquid.
Dec 17, 2009 | All-Pro Propane Garage Shop Heaters - All...
Gas flow problem...
Stick with the one pound disposable propane bottles & you will be fine. The 5lb tank is not compatable.
Jul 01, 2009 | Weber Q Grill
No propane flow to grill using bulk bottle system.
the office that is open on the bottom of the burner sound like a spider has taken home to.. the hole.... This happened to mine. a small pipe cleaner or wire will break it up...try that. also did you feel the top of the tank regulator and see if it has froze. try turning the tank upside down and turn the unit on.... this may also help by forcing the spider debris out.
Jun 05, 2009 | Coleman Roadtrip Grill LXE 9949-750
Reddyheat rlp 100 will not stay lit, strong gas smell.
I had the same problem with my Reddy Heater PRO 100. It is the 20Lb bottle causing your problem.
I Put a 100LB bottle on and ended my problems.
Dec 31, 2008 | Reddy Heater RLP100 Portable Forced Air...
GE XL44 Working fine but awful burnt propane smell
Remove the burners and clean them with EASY OFF oven cleaner. The passages are likely plugged and this causes incomplete burning of the gas. If you do smell raw gas shut the gas to the stove off RIGHT AWAY and call the local gas supplier.
May 12, 2017 | Kitchen Ranges
All-Pro Propane Garage Shop Heaters - All Pro SPC 125 Forced Air Propane Space Heater Logo
242 people viewed this question
Top All-Pro Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Mack Baxter
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
