Question about Whirlpool ACC108PS Air Conditioner
Air conditioner fan run,but compressor makes popping soun
Air conditioner ,fan run ,but compressor making a popping sound when trying to come on. constantly clicking off and on,but not cooling.
    Sergeant:
    Champion:
  • 311 Answers
Go buy a new a/c unit as the compressor is locked up in all probability and if the sealed system has no warranty left.
Posted on May 28, 2010
Why does my dometic ac runs but no cold air?
If the compressor is running, then you have a refrigerant leak. The blower fan can operate and make noise, move air, etc. So make sure the compressor is working too.
Jul 18, 2014 | Dometic Rooftop RV Air Conditioner
Window a/c compressor runs. fan hums but does not run
Replace the fan. The bearing is worn and it may need a new capacitor.
Jul 14, 2012 | Whirlpool ACQ158XP Wall/Window Air...
Air conditioner unit out side is not working. The fan is not moving, and it is flipping our breakers. The furnace is still running - so we are circulating the air in the house. The big unit out side goes...
it could be the compressor or possibly the dual stage capacitor that starts the compressor and runs the fan ,it will be marked with H-for compressor appx35uf./F-for fan at appx 5uf./ and a C-common terminal in the center for the neutral line to both fan and compressor
Jun 04, 2011 | Air Tools & Compressors
My air conditioner will not Start on it's own. Then temp controller in house makes a click sound, the furnace fan then runs like it should. But when I go outside I hear a buzz and click sound like it's...
compressor locked up. try hitting top of compressor with a block of wood on top and a hammer, wait a few min. then turn on. if it dosen' start u will have to replace it.
Aug 06, 2010 | Heating & Cooling
AIR CONDITIONER QUIT WORKING
Pop the hood, start the vehicle and turn the AC on. Watch the compressor, it should have a center that rotates on an off and you should hear a clicking sound. This is the compressor clutch you are looking at. If the compressor is not doing this, check the fuses for the AC. If the fuses are good, then most likely the high side sensor switch is not working, therefore the clutch never engages and the air never gets cold.
Try that and get back to me, ok?
Sep 18, 2009 | 2003 Kia Sedona
FAN IS WORKIN BUT NOT COLD AIR
If the fan is running then it sounds like the compressor isn't turning on and the compressor is what makes the cold air,likely it's the thermostat because the thermostat tells the compressor to turn on.Try replacing the t-stat and it should be fine.
Aug 25, 2009 | Heating & Cooling
Ac starts kicks on and off every couple mins
Sounds like the compressor is the one making the "NOISE". If the sound sounds like something trying to start, then kicking off, its probably the compressor and not the fan. Hence no cool air.
Jul 26, 2009 | Dometic Rooftop RV Air Conditioner
Strange straining sound
Either compressor is going bad or the fan is rubbing. There is a condensor fan that comes on only when the compressor starts. So check the fan out first to make sure that it is not rubbing or moving around. If that is not then check the compressor by letting it run for about 5 minutes then touch the top of the compressor. BE careful as it can be extremly hot that will show you one of two things either bad compressor or condensor is dirty and a garden hose with a jet blast of water will solve the problem. If that doesnt work either compressor is bad and will either need to be replaced for about 250 dollars or unit will need to be replaced
May 30, 2009 | Haier Mechanical Air Conditioner HWF05XC7
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Whirlpool ACC108PS Air Conditioner Logo
172 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
