Question about Car Audio & Video
I was connecting my ipod to my kenwood ddx7017 and i think two wires touched and my stereo screen went blank i tried resetting it and it didnt work the red trangle blinks on the bottom of the stereo
    President:
  • 1,194 Answers
Thanks for using Fixya.
This problem arises due to an internal fault due short circuit as you are saying that two wires touched each other.
This problem can only be solved at a service center, so i advice you to take your device to a Kenwood service station for repair.
Good Luck and have a nice day.
Posted on May 28, 2010
Did I short out my kenwood in-car stereo?
To be honest if you have taken it apart then it is fried and the circuit board is not easy to replace i recommend a new radio, next time run your usb wire loose as you can so it wont never snag
May 29, 2013 | Kenwood Car Audio & Video
Tip
How do I connect my iPod to a stereo Kenwood
<p>The superior audio quality thanks to the Kenwood stereo system is as good as any on the market. However, many of Kenwood audio receivers contain no iPod connection port. Even the business hubs of high-end entertainment that interface with the computer via USB cannot provide connectivity to an iPod. But that does not mean you cannot high-quality audio through your stereo Kenwood iPod. <br /> <p><br /> <p>1. Put your Kenwood stereo. Connect devices with the stereo turned on may lead to spikes in volume that can damage the speakers and even your ears. Turn up the stereo, so you can use the set of connectors on the back to see. <br /> <p><br /> <p>2. Connect the end of 3.5 mm 3.5 mm to RCA cable for the headset from your iPod. If you do not have a cable 3.5mm to RCA, you can buy one of the sound equipment stores or electronics stores like Radio Shack. <br /> <p><br /> <p>3. Connect the RCA end to your cable 3.5mm to RCA in an available port on the back of your Kenwood stereo. Put your Kenwood stereo, so you can access the buttons on the front. Turn the sound and select the channel of your iPod is connected. <br /> <p><br /> <p>4. Test the connection. Lower the volume on the Kenwood stereo and start a track playing on your iPod that you can recognize. Turn your volume until you play the iPod through the stereo to listen. If you hear no sound, check the "Monitor CD2/TAPE2" is active, and "Mute" is off <br />
on Aug 09, 2011 | Apple iPod touch
Kenwood DDX7017 Car DVD Player "Reset password
During the code request mode, while holding the DISP key, press and hold the Volume UP or DOWN key for 3 seconds.
Oct 24, 2012 | Car Audio & Video
I purchased a Kenwood KDC- MP345U and my Ipod touch version 4.0.2 used to work fine in the stereo. Now it only reads and then gives me an IPOD error. I have tried other Ipod products and they work fine. I...
i had a similar issue only mine read the song title and everything but just gave no sound. i called up kenwood and the solution for me was take the ipod (5th gen nano) turn it on, flip the hold switch on then off, then press and hold both the menu and center button of the scroll wheel until the apple logo showed up and release them. wait for it to go back to the menu and plug it in. fixed my problem. they said it was something w/ the ipod not connecting properly or something. hope this helps a bit
Oct 01, 2010 | Kenwood KDC-MP342U Car CD Player
My kenwood KDC-MP342U stopped reading my ipod i just got it within the past two weeks and it was working fine and the all of a sudden when i pluggedd my ipod in all it says is reading. i have tried to use...
I had the same problem with my first gen ipod touch. The reset button is on the front panel, between the Fast Forward button and the "1" button. Push it with a pen or something with the unit turned on. It will go dark then come back. You'll have to set up your preamp and other stuff again. I also now push the eject button before removing my ipod or USB thumb drives. The display will flash "remove". I guess this does some handshaking that cleans things up before removal.
Oct 18, 2009 | Kenwood KDC-MP342U Car CD Player
I need the bypass code for a kenwood ddx7017
turn on and as soon as buttons lights up on press 552222777777 with a remote you wont see any activity on the screen but i just unlocked one push numbers before screen lights up fast it may take a few tries
Jul 04, 2009 | Kenwood DDX7017 Car DVD Player
A freen install kenwood ddx7017 and we hear dvds but no vision if there any extra part we need or were connected the wire whit the p
the only thing i can think of is the same prob I had with mine before I knew how to use it. there is a button on the left side of the screen with an "F" on it. That button switches between video modes. Try that if that doesn't work, check to see that both wiring harnesses are connected to a ground (actually 3 wires). 2 black, 1 green on the 8 pin harness (goes to parking brake switch); doesnt actually have to go there (that is for safety) Other than that you are on your own.
Jan 14, 2009 | Kenwood DDX7017 Car DVD Player
Kenwood DDX7017 Screen has no color and it won't eject
Had the same thing happen to me. All you have to do is use a pen or a paper clip and push the reset button located on the front of the unit. It cleared right up.
Oct 31, 2008 | Kenwood DDX7017 Car DVD Player
Sound problems
Hey, easy fix that is usually over looked.
If the vehicle has a stock amp to power the stock system installed,
that the remote power amp wire (P-cont) {baby blue I think} is connected
to the harness.
Melo
Sep 19, 2008 | Kenwood DDX7017 Car DVD Player
Car Audio & Video Logo
32 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
