Question about Asko T761 Electric Dryer
Is the belt replaced from the front or back?
On an Asko T761 electric dryer ,is the belt replaced from the front or back?
    Sergeant:
    Champion:
  • 311 Answers
Back. Takes some skill, but that is how it is done. The back comes off to do this.
Posted on May 28, 2010
The dryer heats but will not turn. How do I replace the belt?
first find out if the back comes off .and go from there
Oct 13, 2015 | Asko T761 Electric Dryer
Amana ndg7200tw dryer belt replacement
Unplug it from power,Take the top off the dryer. They "pop" on and pull off. Take the front panel off from the inside, Clean all the lint out, remove the old belt by sliding it off the front if it is not broken, put the new belt on, Stretch it to motor pulley, put the belt tensioner pulley on it, reassemble.
Feb 17, 2014 | Asko T761 Electric Dryer
ASko dryer T761 goes bump bump bump when starting. sometimes we can wiggle drum around and get it to stop. Help!
I believe asko says this is normal at start up and should stop after the drum has been spinning for a bit.
Jun 21, 2011 | Asko T761 Electric Dryer
The drying turns on, but does not spin
Welcome to FixYa.
Sounds like it has a broken belt based on your description of your Asko dryer "The drying turns on, but does not spin".
You can visually inspect it be either removing the lower access panel or the dryer top panel, the choice is yours and either way will let you check the belt.
To go infrom the top remove the screws at the back of the top, they will be three #25 torx head screws.
Once the screws are out, slide the top towards the back slightly and lift up. You should then see something like this...
Oct 01, 2010 | Asko T761 Electric Dryer
How do I replace the belt on my Asko T761 dryer? Do I go in thru the front, the back? Are there instructions on-line for belt replacement?
How to install a belt on ASKO dryer
Belt Type: Flat belt with ribs
Installation Notes: Ribs go against drum
You could Refer to :-
http://fixitnow.com/wp/2006/05/08/asko-t700-dryer-wheel-drum-and-belt-replacement-instructions/
It would be a Generic one but would help you.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 11, 2010 | Asko T761 Electric Dryer
Belt/Drum Noise
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 15, 2009 | Asko T761 Electric Dryer
Drum is not turning. Heat works
Sounds like the belt has broken or come off. This is usually inexpensive to fix. You just need to get it out in the open to replace.
May 25, 2008 | Asko T761 Electric Dryer
ASKO T761
press the black reset button on the back.wash door filter and condensor,then try again hope this helps.
Mar 16, 2008 | Asko T781 Electric Dryer
Asko T761 Electric Dryer Logo
303 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
