Question about Lasko 2152C Hassock Floor / Box Fan
I cannot find replacement parts for lasko 2152C hassock floor fan does anyone know where you can find some
4 Suggested Answers
mrboo747
  • 24 Answers
SOURCE: Lasko E20739 Fan
I would love to tell you yes, but I ended up buying new fan.
The common wire was broken, buried in the windings and no way to repair without
damaging the windings.
Could not find anything on line.
Sorry,
mrboo747
aka Gary C
Posted on Nov 11, 2008
sawdust46694
  • 398 Answers
SOURCE: I ahve a hassock fan from 1952 that needs a new blade-
http://www.laskoproducts.com/fans/model_2152c.html
hope this helps you.
Sawdust
Posted on Aug 15, 2009
SOURCE: Problem with a Lasko 3440 Floor/Box Fan.
light is on ,but there is no movement from the fan. I think I need a fan motor.Lasko 20" fan motor part #3440.
Posted on Nov 03, 2010
How do I know which wires go where on a lasko tower fan, I'm trying to use the lasko motor on a blower
You have to cut the blue wire, WAIT NO, the red wire. No the blue wire, yes cut the blue wire. Phew that was close. (How the hell is anyone going to know the answer this question? you took the think apart so you can see what the wires are for)
Dec 03, 2014 | Lasko 48" Xtra Air Tower Fan with Air...
BROKEN BLADE
Replace Fan, order part from Lasko
Aug 03, 2008 | Lasko 2152C Hassock Floor / Box Fan
How to disassemble lasko hassock floor fan
I'm assuming you want to open the fan up to give it a thorough cleaning. This is how I got one open. First things first, make sure it's unplugged. No need to risk zapping yourself of accidentally turning it on when your fingers are in range of the fan blade...
Turn the fan upside down. There are four very long Phillips screws concealed by long plastic sleeves that cover the shafts of the screws, with the ***** heads covered by the rubber feet at the bottom of the unit. Pop out the rubber feet, then loosen the screws (there will likely be an alarming snap when they break loose). The two-piece top of the unit will come loose. You can then remove the screws and the plastic sleeves that hide the screws.
Turn the unit right side up and remove the fan blade. The nut holding the blade on is reverse thread, so "lefty loosy, righty tighty" will not apply--turn the nut clockwise to loosen. Remove the nut and lock washer, then pull the blade from underneath the hub (it'll take a bit of force to pop it off.
The wire from the motor to the speed control switch connects the base to the cylindrical center portion of the unit. To separate the center portion from the base, pull the knob off of the shaft of the switch and remove the ***** holding it in place. The switch can then be disconnected from the center piece. I'd put the ***** back into the switch to keep it from disappearing.
The motor can be removed from the base by removing the three screws holding it to the base from underneath, but unless you're looking to replace the motor, you shouldn't need to do this.
Put it back together by reversing the disassembly process.
Jun 16, 2014 | Lasko 2152C Hassock Floor / Box Fan
Lasko 2510 tower fan fuse
Follow the power cord. If they have a fuse, it will be attached to the cord.
Jul 02, 2012 | Lasko 2510 Tower Fan
Is there a means for a technically competent handyman to lubricate the bearings of the lasko wind machine 3300?
The fan and motor are both easily disassembled with a Phillips screwdriver and some gentle force to remove the blades. Try to use even pressure when removing both the blades and opening the motor housing. The only questions are whether to flush the existing lubricant out of the bearings and what to replace it with. If you know what to use it shouldn't be a problem. If anyone could suggest an oil or grease, please do.
Apr 03, 2011 | Lasko 3300 Wind Machine¿ Floor / Box...
Where do i get lasko box fan electric motor??
Lasko has an online parts resource for fans. Click the link below:
https://store.laskoproducts.com/ReplPartsStorefront/Web/c-2-fans.aspx
Also, a toll-free number (from USA locations):
1-800-233-0268
Apr 07, 2010 | WeatherWorks DB888 Floor / Box Fan
Lasko Box Fan Stinks!
same thing with my lasko box fan awful oil smell
Aug 05, 2009 | Lasko 3720 Floor / Box Fan
How do you take off the spinning part off of a lasko fan?
Just hold the blade and use a sharp knife and cut the string. It's really not that hard!
Jul 28, 2009 | Lasko 3300 Wind Machine¿ Floor / Box...
Mar 30, 2009 | Lasko 3440 Wind Tunnel Floor / Box Fan
Lasko 2152C Hassock Floor / Box Fan Logo
114 people viewed this question
Top Lasko Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
