Question about Kenwood Audio Players & Recorders
Why won't my Kenwood DP-M97 6 magazine CD Player eject?
I have an old Kenwood DP-M97 6 magazine CD Player that won't play or eject. It has power. What can I try to fix it myself?
  • 36 Answers
SOURCE: CD won't play; continually shuffles from one CD to another
did it just start doing this....how long have you had the unit for?
Posted on Dec 31, 2007
  • 41 Answers
SOURCE: Ejecting magazine on Pioneer CDX-fm1257
I have very gently taken a pair of needle nose pliers and grasping the edge of the cartridge that holds the disk carefully work it back into the magazine.
Posted on Jan 09, 2008
SOURCE: kenwood cd player DP-M6010
After retrieving the cds from the unit I replaced it with my iPod. It seemed to me to be the most cost effect method to solve the problem.
Posted on Feb 09, 2008
smilemaker
  • 790 Answers
SOURCE: 6 disc cd magazine will not eject
HELLO!!
Posted on Feb 23, 2008
SOURCE: I receive error msg and cant eject magazine
The magazine in our Sony CD player would not eject. I tried pressing two buttons at the same time etc., with no result. I uplugged the player, removed the screws that hold the black metal cover on and took off the cover (pull the metal up, out and away at the back bottom sides, then slide it back to release the lip from under the front pane.) Looked down inside and saw the problem, a CD disc extended about 1/2 inch from the magazine, blocking ejection. I pushed the extended edge of the disc back into the magazine with the tip of a kitchen knife. Plugged the player back in, pushed power and then the eject button, and the magazine ejected. Replaced the metal cover and it works fine. If it won't eject again I know what to do. Be sure to unplug before you work, you don't need an electrical shock.
All the best, Sonia Murray
Posted on May 06, 2008
Kenwood 10 Disc Cartridge won't eject
From your description it is likely that a CD is jammed in the player, preventing the magazine from being removed. Even though your Kenwood is hard to get to, it will have to be removed and disassembled to correct the problem
Feb 01, 2013 | Car Audio & Video
Magazine won't eject?
A CD may be stuck between the player unit and the magazine. You can try loading and unloading several times but in extreme cases it is necessary to do some disassembly to get at the disk
Oct 20, 2012 | Clarion Caa-355 6-Disc CD Magazine...
No power to the disc changer, how do I manually eject the magazine
There is a manual eject slot on the side of the CD changer. You will need a small flat head screwdriver or a pry tool to insert into the slot.
Oct 11, 2012 | Kenwood KDC-C715 10 Disc CD Changer
How do I remove the CD magazine from a kenwood kdc-c462 which is out of car & has no power?
I had the same unit, with the same issue. Unfortunately, There is no way to eject the magazine without power to the unit. I took the unit to a stereo shop where they plugged it into a control unit (powered off), powered up the system and ejected the magazine for me.
Sep 05, 2009 | Car Audio & Video
Can't eject cd magazine - E-99 error message
I put a small pin in the reset button a few times and that then got the catridge to eject.
Apr 14, 2009 | Car Audio & Video
I had the same problem. I opened up the unit and found out that there is a plastic gear that moves the loader. When worn the loader can not load tha magazines nor change cd's. I replaced the gear and the cd autochanger worked fine.
Gerald,
Kenya.
Dec 01, 2008 | Kenwood KDC-C717 10-Disc CD Changer
No ejection
hi does it make any noise or clicking?
you may have a cd dislodged or mag dammaged.
Mark
Sep 05, 2008 | Clarion DC625 6-Disc CD Changer
Playing CD-RW audio CDs on Kenwood DP-J2070
try to play a song from original cds.
maybe you brunt it in mp3 file, or its a different format. try to burn your song to cd-r.
if still, try to use nero to burner..
if it wont play your original cds and burnt cds,then the optical lens or the board is broken.
hope I helped you.
Dec 06, 2007 | Kenwood DP-J2070 CD Player
CD Changer Not Working
sum have a small reset button where the mag is
Nov 26, 2007 | Kenwood KDC-MP3035 CD Player
Cd will not play and keeps ejecting
source http://www.kenwood.nl/support/veelgestelde_vragen/ Changer Error Codes ? E-00: Poor Cable connection. ? E-01: Magazine not properly set in changer. ? E-02: No Disc in magazine. ? E-03: CD does not have selected track number. ? E-04: Disc is dirty, upside down or unreadable. ? E-10: No data is recorded on the MD. The player plays the next disc automatically. ? E-99: Changer malfunction, disc may be caught in machine or changer requires service. Sounds like the mech is gummed up, jammed, or a cd is stuck inside. Get a nerd to open it up and check it over. Luck
Jan 14, 2007 | Kenwood KDC-3027A CD Player
392 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
