Question about GE (PSS26MSRSS) Side by Side Refrigerator
Why does the refrigerator sound like a pulsating noise
    Sergeant:
    Champion:
  • 311 Answers
This is the sound of the refrigerant enetering the coil and it will make noise as it is evaporating from a liquid state.
Posted on May 28, 2010
Frigidaire refrigerator only 6 months old making high pitch noise constantly after door has been opened. What is causing this?
Hello friend, thank you for your post!
Based off the information you have provided your Frigidaire refrigerator is making high pitched noises after the door has been opened. With our current refrigerators the new modern, high-efficiency compressors operate much faster than older models. The compressor may have a high-pitched hum or pulsating sound. If you feel that further assistance is needed please contact your manufacturer for any warranty coverage. -Matt
Feb 02, 2016 | Frigidaire Refrigerators
I have had my wine fridge for 16 months & it was running all the time and it started making a loud clanking noise from the fan area. I haven't had it that long. What is causing this problem?
I would start by checking to see if anything is touching the fan blades. Believe it or not, mice typically get decapitated by them. Also wires can get in the way. However, About Appliance.com says: "Clicking, banging and knocking: These sounds can come from the compressor telling you there is a problem with it. Normally, it can make a whining or pulsating noise"
May 10, 2015 | Refrigerators
Refrigerator has developed a low buzz or hum. Do I need to be concerned?
I understand that your Frigidaire refrigerator, LFHT1817LW1, is buzzing or humming. With modern, high efficiency compressors you may hear a high pitched humming or pulsating sound. Additionally, if you have an icemaker equipped inside of your refrigerator the water valve may produce a buzzing noise as the valve opens to fill the icemaker with water. I hope this has been helpful. -Matt
Oct 15, 2014 | Frigidaire Refrigerators
Why does my new Frigidaire FFHT1826 make a high pitch noise
Thank you for your post, friend!
Based off the information you have provided it sounds like you are hearing the compressor come on. In the newer, high-efficiency compressors they operate much faster than the older models and some may put out a high pitched hum or pulsating noise. I hope this helps. -Matt
Sep 03, 2014 | Frigidaire Refrigerators
Why would a brand new fridge make strange noises already?
Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FFSS2614QS, is making a strange humming noise. Your new, high-efficiency refrigerator may introduce unfamiliar sounds. These sounds normally indicate your refrigerator is operating correctly. Some surfaces on floors, walls, and kitchen cabinets may make these sounds more noticeable. This could possibly be the compressor that you are hearing. Modern, high-efficiency compressors run much faster than in the past. The compressor may have a high-pitched hum or pulsating sound. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire FFSS2614QS FFSS2614QS 26 Cu....
Water leak on back wall of my freezer and a hell of noise from my icemaker when on
Water leak and noise are due to wrong temp setting or malfunction of defrost cycking.Keep temp setting between 3 and 5 degree centigrade. Due to over frosting, the freezer fan fan hits over the ice and working to cool fridge compartment.And also check defrost timer, and heaterworking properly to defrost in time. And if your ice maker is making sound, due to:
  • You will hear a buzzing sound when the water valve opens to fill the water reservoir for each cycle.
  • Rattling noises may come from the flow of the refrigerant or water line. Items stored on top of the ice maker can also make noises.
  • The high-efficiency compressor may make a pulsating or high-pitched sound.
  • Water running over the evaporator plate may make a splashing sound.
  • Water running from the evaporator plate to the water reservoir may make a splashing sound.
  • As each cycle ends, you may hear a gurgling sound due to the refrigerant flowing in your ice maker.
  • You may hear air being forced over the condenser by the condenser fan.
  • During the harvest cycle, you may hear a "thud" when the ice sheet slides from the evaporator onto the cutter grid.
  • When you first start the ice maker, you may hear water running continuously. The ice maker is programmed to run a rinse cycle before it begins to make ice.
Hope, it's helpful>
Feb 05, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Noise problem related to dim pulsating light
this is caused by the motherboard on this model,have replaced many lately,what happens is when a light bulb in the refrige compartment burns out it creates a surge and burns this circuit board,the clicking is a relay on this board trying to latch,but when the board is defective it cant,when you remove this board it will have a burnt spot on the boards circuit trace and a discolored spot on the case holding it
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Jenn-Air JCB2059ES refrigerator makes weird noise
Sounds like the plastics are just rubbing from vibration. redistribute the contents of the drawer and see what that does. Good Luck.
Nov 21, 2009 | Refrigerators
GE Stainless Steel Side by Side - Loud Huming and Whoosh noice
you should not hear it from that far away. It sounds like it may be compressor related. The only thing you could check to make sure is remove the lower rear cover and check the condensor fan and listen to the compressor to see if thats where the noise is cmming from. Check the fan in the freezer too.
Aug 06, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
456 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
