Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
Chauffe-air cat# D55603 mod. F. Heater and fan will not operate. where to look?
3 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: my chauffe air heater will not give off any heat
see this causes and fix it. God bless you
If an appliance that should produce heat does not, inspect the element for breaks or obvious damage. If you don't see any damage, test the element for continuity (see below).
  1. Turn off power to the appliance or device. If the unit is plugged in, unplug it from the electrical receptacle (outlet); if the device is wired into the circuit (such as an oven), turn off the circuit at the electrical service panel.
  2. Disassemble the appliance or device to access the heating element, following the guides in this book for your appliance. Some heating elements, such as plug-in units in electric ovens, are relatively easy to remove (see the Electric Oven Fix-It Guide).
  3. Set the multimeter to RX1 (resistance times 1).
  4. Touch the multimeter probes to each end of the element.
  5. High resistance (kilo-ohms or thousands of ohms) indicates the heating element is okay. A reading of infinite resistance indicates a broken element.
  6. If a heating element is faulty, replace it with one of the exact size, shape, power rating, and resistance.
  7. Reassemble the appliance or device and turn it on or plug it in to test it.
Posted on Oct 01, 2012
  • 35 Answers
SOURCE: Electric fireplace still works, except the flame
Find an access door on the back or side or both.
check lightbulbs.
Do not replace with anything but exact bulb.
try taking the bulb to Lowes...I've gotten luck there before with odd bulbs...they have a special drawer for them.
Good luck,
Vinnie
Posted on Sep 13, 2010
Can you show me a diagram of a chauffe-air
Hot air system but for what may i dare ask
Dec 23, 2012 | Cars & Trucks
What is a E4 code mean
Error Code:
E1 Loss of communication between the Single Zone LCD thermostat and the mod-ule board. LCD will cycle between E1 and the previous mode setting. System
will shut down.
E2 Open circuit or out of range Indoor Temperature Sensor. Heating and cooling
operation will be locked out. Fan operation can continue to operate.
E3 Shorted Indoor Temperature Sensor. Heating and cooling operation will be
E4 Open circuit or out of range Outdoor Temperature Sensor (select models). Heat
Pump operation will be locked out. Air Conditioner, Fan and Furnace operation
E5 Open circuit or out of range Freeze Sensor. Air conditioner mode of operation
will be locked out. Furnace, heat strip, heat pump and fan mode of operation can
continue to operate but displays the last temperature set-poi
Dec 18, 2012 | Dometic 3313192.000 White Single Zone LCD...
I have a Model MOD-CAT-23785-380 Ceiling Fan. I broke the arm that holds one of the blades. I need a replacement.
Davd the "arm" is technically a "Blade Iron". You can find them at most Home Improvement Centers (Lowe's & Home Depot) as they both sell Hunter Fans and universal parts.
Hope this helped you and thanks for choosing FixYa.
Aug 09, 2011 | Hunter Heating & Cooling
I can't to find the area to replace the bulb. Everything works except for the light To eacy to leave on without the light. Where is the bulb located and what should I purchase to replace it. model #...
On the back of the heater stove, you will see a rectangular panel in the center, near the bottom of the stove. If you remove that (by removing the screws that hold it in place), you will have access to the small base, 60 watt. chandelier bulbs that you will need to replace. Be sure to turn the stove OFF and unplug it, before attempting to replace the bulbs.
Hope this helped you and Happy Easter!
Apr 24, 2011 | Dimplex Compact Electric Flame Stove...
700w carbon fiber heater bulb is broken, where can i buy a replacement ? Heater Mod #6318348. Price?
Jan 11, 2011 | Heating & Cooling
Electric fireplace still works, except the flame does not light up anymore? Is there a way to fix this? It is a Chauffe-Air, Model# 6901740100 Cat.No. DFB4047 Mod. Level: MOD A Serial # 26806D6F 093. I...
check lightbulbs.
Good luck,
Vinnie
Mar 21, 2010 | Leisure HOMEPRIDE Electric Fireplace...
Dayton mod#3e219b gas heater
air compressor output should be 3.5 psi. to the fuel nozzle. the cowlings purpose is to channel the air-fan output through the rear vanes of the combustion chamber. if these openings are restricted then air can't get into the chamber. check to see that the fan blades aren't jammed against the cowling. if they won't spin then you won't get any air through the unit.
Dec 21, 2007 | Dayton E52 Utility Heater
Heating & Cooling Logo
891 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
