Question about Whirlpool LER5636P Electric Dryer
Dryer wont work
Whirpool ultimate care II , cleened out the lint, power source is fine,the push start button after closing door clicks but will not engage dryer total silence
    Sergeant:
    Champion:
  • 311 Answers
Probably have an open fuse. take off the back and by the exhaust is a skinny white fuse. jump the wires together and see if dryer will work. Replace it if so.
Posted on May 28, 2010
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
    When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
    The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
    For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
    Aug 03, 2012 | Dryers
    Dryer has started to make a loud sqealing when it starts and gets up to speed, the kind of sound a loose fan belt makes on a car, and now just makes a buzzing sound when the button is pushed but dosen't...
    If you push the start button and you here a buzzing sound, This sounds like the motor is bad.
    Somthing you can try and this might not work. but open the dryer door and turn the drum a littel bit then close the door and try to start it. If it starts running again then you have hit a bad spot on the motor.
    If it just still just makes the buzzing noise then the motor is most likley bad.
    Jan 15, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
    Lost power after opening door during cycle.
    Try and flip the breaker to off again and push lightly then on , when a breaker trips somtimes just flipping it on it wont catch a latch inside the breaker to actually flip it on.
    Oct 29, 2009 | Dryers
    Whirlpool dryer model LEQ8800JQ won't start when push start butto
    I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
    Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
    Whirpool estate dryer teds680eq2 does NOTHING when start button is pushed.
    NO POWER CAN BE A MULTITUDE OF PROBLEMS.
    1 DOOR SWITCH 2. THERMAL FUSE. 3 MOTOR 4. TIMER
    5. HOUSEHOLD VOLTAGE. 6. PUSH TO START SWITCH.
    CHECK ITEMS IN THE ORDER LISTED.
    THE DOOR SWITCH HAS AN ARM THAT EXTENDS DOWN INTO THE SPACE WHERE THE DOOR CLOSES. IT IS LOCATED IN THE UPPER RIGHT CORNER. PRESS IT WITH YOUR FINGER TO SEE IF IT CLICKS. THEN CLOSE THE DOOR AND SEE IF IT CLICKS WHEN THE DOOR SHUTS.
    IF NO CLICK, REPLACE THE SWITCH.
    THE THERMAL FUSE IS LOCATED BEHIND THE LOWER BACK PANEL OF THE DRYER DOWN BE THE EXHAUST. IT IS A SMALL WHITE ITEM WITH TWO WIRES ATTACHED.
    JUMPER ACROSS THE TWO WIRES. PUSH THE START BUTTON. IF THE DRYER COMES ON, REPLACE THE THERMAL FUSE AND CHECK FOR PROPER OPERATING TEMPS.APPROX 160-175DEGREES FAHRENHEIT.
    IF IT GOES BEYOND 220 DEGREES, REPLACE THE CYCLING THERMOSTAT LOCATED BESIDE THE THERMAL FUSE.
    THE OTHER ITEMS SUGGESTED ARE MORE IN DEPTH AND REQUIRE A KNOWLEDGE OF READING SCHEMATICS.
    Apr 16, 2008 | Dryers
    Washer won't start spin cycle
    sounds like a lid assy issue, can you hear a "clicking" just before the lid is closed, try opening nad closing a few times listening for a distinct "click" if not the machine doesnt think the door is closed and for safety reasons wont spin and drain.
    Mar 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Cleaning Whirpool Ultimate Care II
    once that you have lifted the top up you can remove the two screws that are down inside the frount panel about three inches, pull out on the frount panel and swing to the side, if the lint buildup is large then check the vent to the dryer for any kink a shop vack works great for this chore
    Feb 18, 2008 | Whirlpool LER5636P Electric Dryer
    Whirlpool LER5636P Electric Dryer Logo
    267 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal De
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
