Question about Maytag EPIC MFW9700S Front Load Washer
What does the code nd stands for on the maytag front load washer?
  • 10,319 Answers
ND No Drain Machine control board monitors water level in washer during and at the end of pump out. If wash level does not reset pressure switch, it will see water left in the washer. 1.Check for pump/drain restriction. 2.Check pump operation.
3.Check pressure switch for open contacts.
4.Check inputs and outputs at machine control board.
5.Replace responsible component.
Posted on May 29, 2010
  • 38 Answers
Oh that means no drain....your pump is either cloggedor not working
Posted on Feb 18, 2015
I am getting code nd on my maytag neptune washer. how can i fix?
ND code is "no drain" the washer probably has a drain plug/filter on the main pump, more than likely all you need to do is clear debris from the pump.
Jun 20, 2012 | Maytag Neptune MAH9500A Front Load Washer
Customer states washer will not drain/also reads ND on screen. Washer will spin when set to spin option. When set to regular wash the washer will not proceed with full wash stops and screen reads ND
the ND stand for NO DRAIN the filter on the pump is clogged,or the pump itself is clogged,the washer will not spin till it is drained,remove front panel by removing door and the screws that are opposite if it were hinged on othe side pop off front panel and check filter/pump for blockage
Aug 08, 2011 | Maytag Neptune MAH5500B Front Load Washer
What the heck does nd stand for? Why does it sometimes say nf? Model MAH5500BWW
Hello & Welcome to FixYa
ND error in your Maytag Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump.
NF error in your Maytag is displayed due to no fill condition, when the washer tries to fill but is unable to, nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
May 12, 2011 | Maytag Neptune MAH5500B Front Load Washer
I am getting the nd error
you can get help in this matter at appliancerepairplanet.vstore.ca and you can get a sevice manual and help in this matter
Dec 15, 2010 | Maytag Neptune MAH6700A Front Load Washer
Nd in the display
nd stands for no drain check for a restriction in your drain line and in your pump assembly
May 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer gives code "nd" and stops! What is the problem??
"nd" is code for "difficult draining" installed a new water pump $60, problem solved.
May 11, 2009 | Maytag MAH8700A Front Load Washer
Showing code nd
Hi. The washer experienced difficulty draining. The code represents this issue. Here's a check list to combat these issues. (code nd)
Check for a kinked drain hose.
Check for a plugged stand pipe.
please rate and god bless..
Mar 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
333 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
