Question about Microsoft Office Standard for PC
Microsoft Office 2007
Hi I was wondering if you could be more specific by:
"open "digitalproductid" and change the data in the first line
you need some luck with the changing,but if it works then you can run any office product without activation needed."
is there any guide as how to change the data in the first line? Or do you just have to type random letters and numbers? Help would be appreciated as soon as possible. Thanks!
The Product number for Microsoft office pro 2007
Posted on May 01, 2008
I don't know my product key
Follow the steps bellow! Replace all * with html closed or opened. For example see here: http://img713.imageshack.us/img713/139/expt.png
Then follow these instructions:
1. Close all Microsoft Office applications.
2. Run Register Editor by clicking on Start - Run, and then type "regedit" in the Open box and press Enter key.
3. Navigate to the following registry key:
HKEY_LOCAL_MACHINE\Software\Microsoft\Office\12.0\Registration
Note that inside the registry key, there should be another subkey that resembles the following:
HKEY_LOCAL_MACHINE\Software\Microsoft\Office\12.0\Registration\{90120000-0030-00
­00-0000-0000000FF1CE
or
HKEY_LOCAL_MACHINE\Software\Microsoft\Office\12.0\Registration\{91120000-0011-00­00-0000-0000000FF1CE
4. If there is more than one registry entries or subkeys that reference Microsoft 12.0 registration, open up each subkey, and then identify the product by the ProductName value data until you locate the subkey for the product which you want to remove the existing product license key.
For example:
ProductName=Microsoft Office Professional Plus 2007
ProductName=Microsoft Office Enterprise 2007
5. Once found the correct registry subkey, delete the following values:
DigitalProductID
ProductID
6. Close Registry Editor.
Once Microsoft Office 2007 has been installed with no product key, proceed with the following steps:
1. In Windows Explorer, brose to the following folder:
C:\Program Files\Common Files\Microsoft Shared\OFFICE12\Office Setup Controller\Proof.en\
2. Right click on Proof.XML file, select "Open With..." in the right click menu.
3. In the "Open With" window, select Notepad to be used to open the XML file. In Vista, if you can't see the Notepad option, simply double click the "Other Programs" to unhide it.
4. Scroll down to the bottom of the Proof.XML to locate the following lines:
*/Feature* *Feature Id="SetupXmlFiles" Cost="1248?*
*OptionRef Id="AlwaysInstalled"/*
*/Feature*
5. Change the AlwaysInsalled to neverInstalled so that the line looks like following:
*OptionRef Id="neverInstalled"/*
6. Save the Proof.xml file. In Windows Vista, you may need to take ownership and grant full access permission to yourself before able to modify the file.
7. You can now launch Microsoft Office 2007 application such as Word, Excel, Powerpoint, Outlook and etc without prompting for activation.
Aug 08, 2011 | Microsoft Office Professional 2007 Full...
Tip
Crack office 2007
Microsoft Office 2007 all version crack (it work )
DO NOT ENTER ANY KEY OR DO NOT OPEN ANY MicroSoft Document file AND JUST FOLLOW THESE STEPS
STEP 1 == >
Open Regedit
go to
HKEY_LOCAL_MACHINE > SOFTWARE > MICROSOFT > OFFICE > 12.0 > REGISTRATION > { 30120000 }
And then Delete These three files
- DigitalProductID
- LicenseType
- TrialType
STEP 2 == >
Navigate to C:\Program Files\Common Files\Microsoft Shared\Office 12\Office Setup Controller\Proof.en
Inside the folder, edit the xml file in notepad/wordpad...
...find where it says
and replace "AlwaysInstalled" with "neverinstalled" and save.
Remember reply is must here
on Jul 07, 2010 | Computers & Internet
Can i have productcode of MS Office Home and Student 2007, i bought a new laptop, a haved Vista product... when i tried it asked me the code and i don't have it, could you help me please for the...
Try this..........
How to disable Microsoft Office Activation
Do this it Works with ur 60 days trial MS ofice 2007
First of all make sure that u install Office 2007 without any Serial Number... If u have already installed it with a serial number then follow these instructions.....
2. Click Start, click Run, type regedit in the Open box, and then click OK.
3. Locate the following registry subkey:
Note You may also find another subkey that resembles the following subkey:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\12.0\Registration\{91120000-0011-0000-0000-0000000FF1CE}
4. If you find additional subkeys that reference Microsoft 12.0 registration, open each subkey, and then identify the product by the ProductName entry.
For example: ProductName=Microsoft Office Professional Plus 2007
5. When you find the subkey for the product from which you want to remove the existing product license key, delete the following entries:
* DigitalProductID
* ProductID
6. Exit Registry Editor.
After u are finished with this...
1. Go to start and Click Run...
2. In the run box type... "C:\Program Files\Common Files\Microsoft Shared\OFFICE12\Office Setup Controller\Proof.en"
3. You should now see a file named Proof.XML
4. Right click the file and select open with notepad.
5. After opening the file with notepad scroll down to the the bottom.
6. You should see lines like this...
7.
8. Just change the line AlwaysInstalled with neverInstalled retaining the quotes...
9. Save the file and u are ready to go...
10. Now just open Word and it should not ask you for any activation...
11. Make sure you do not do any kind of update...
Oct 03, 2010 | Microsoft Office Professional 2007 Full...
I need 25 characters product key of 2007 microsoft office.....plz
Can't provide you with the product key, but can show you how to get around the product key checking if you're interested ;-)
This works with your 60 days trial MS ofice 2007 as well
First of all make sure that you install Office 2007 without any Serial Number… If u have already installed it with a serial number then follow these instructions…..
* DigitalProductID
* ProductID
After u are finished with this…
1. Go to start and Click Run…
2. In the run box type… "C:\Program Files\Common Files\Microsoft Shared\OFFICE12\Office Setup Controller\Proof.en"
6. You should see lines like this…
7. </Feature> <Feature Id="SetupXmlFiles" Cost="1248′>
<OptionRef Id="AlwaysInstalled"/>
</Feature>
8. Just change the line AlwaysInstalled with neverInstalled retaining the quotes…
9. Save the file and u are ready to go…
10. Now just open Word and it should not ask you for any activation…
11. Make sure you do not do any kind of updates though..
Aug 06, 2010 | Microsoft Office Professional 2007 Full...
I need to remove the genuine microsoft sottware my system....
Most suites or programs of Microsoft Office 2007 allows user to evaluate the product. The trial version of 2007 Microsoft Office system can be installed by using a 25-character trial product key available from Microsoft while you download the free Office software, and you can use the Microsoft Office 2007 suite or program with full functionality for 60 days.
You may have the Office 2007 CD and are able to install Office 2007 without entering product key. However, Office 2007 will work in reduced functionality mode, where it’s effectively just a viewer for Office documents. Beside, if you forget the trial product key, or don’t wish to register a Windows Live ID to get the trial key, here’s the trick to activate Office 2007, or more correctly, bypass the activation of Office 2007 60 days trial, and making the “trial” word disappear from the Office title at the top and suppress activation and trial expiry prompt.
Note that to use Microsoft Office 2007 beyond 60 days trial period, you need to purchase a valid license for it, available from Amazonir?t=techgadgetrev-20&l=ur2&o=1 or most computer retail store.
To use this hack to crack activation on Office 2007, you need to install Office 2007 without any serial number or product key. If you have installed Office 2007 with a product key or serial number, do the following to clean remove Office 2007 of product key:
  2. Run Register Editor by clicking on Start -> Run, and then type “regedit” in the Open box and press Enter key.
  3. Navigate to the following registry key: HKEY_LOCAL_MACHINE\Software\Microsoft\Office\12.0\Registration
    HKEY_LOCAL_MACHINE\Software\Microsoft\Office\12.0\Registration\{90120000-0030-0000-0000-0000000FF1CE
    or
    HKEY_LOCAL_MACHINE\Software\Microsoft\Office\12.0\Registration\{91120000-0011-0000-0000-0000000FF1CE
  4. If there is more than one registry entries or subkeys that reference Microsoft 12.0 registration, open up each subkey, and then identify the product by the ProductName value data until you locate the subkey for the product which you want to remove the existing product license key. For example:
    Product Name=Microsoft Office Professional Plus 2007
    Product Name=Microsoft Office Enterprise 2007
  5. Once found the correct registry subkey, delete the following values: DigitalProductID
    ProductID
  1. In Windows Explorer, brose to the following folder: C:\Program Files\Common Files\Microsoft Shared\OFFICE12\Office Setup Controller\Proof.en\
  2. Right click on Proof.XML file, select “Open With…” in the right click menu.
  3. In the “Open With” window, select Notepad to be used to open the XML file. In Vista, if you can’t see the Notepad option, simply double click the “Other Programs” to unhide it.
  4. Scroll down to the bottom of the Proof.XML to locate the following lines: </Feature> <Feature Id=”SetupXmlFiles” Cost=”1248′>
    <OptionRef Id=”AlwaysInstalled”/>
    </Feature>
  5. Change the AlwaysInsalled to neverInstalled so that the line looks like following: <OptionRef Id=”neverInstalled”/>
As usual, as it’s a hack, and before you purchase a valid product key for it, you won’t be able to AND can’t access any updates or Microsoft Office Online.
Note: The hack may work for 60 days only. To make this hack fully working, try to delete additional file below, probably has to be deleted every two months:
C:\Documents and Settings\All Users\Application Data\Microsoft\OFFICE\DATA\opa12.dat
Or,
C:\ProgramData\Microsoft\OFFICE\DATA (for Windows 7 and Vista)
Disclaimer: This article is for educational and informational purpose only.
Aug 02, 2010 | Microsoft Office Professional 2007 Full...
How can i download microsoft power point for free
There are many illegal ways of doing this....torrents with a crack, just google it.
An easy and legal way to view power points is to download the free Powerpoint Viewer, published and hosted by microsoft here:
http://www.microsoft.com/downloads/details.aspx?FamilyID=048dc840-14e1-467d-8dca-19d2a8fd7485&displaylang=en
Jul 17, 2010 | Microsoft Computers & Internet
Microsoft Office came preinstall on my PC running Windows 7. When I try to use Word, I am asked for an product key. Where do I find the product key since Word was preinstalled and I have nothing to refer...
You may need to alter or change Microsoft Office 2007 (aka 2007 Microsoft Office System programs and suites) product license key or volume license key (VLK) which also known as serial number or CD key. You can modify or change product key for 2007 Microsoft Office programs or suites by first uninstall or remove Microsoft Office and then reinstalling the business productivity suite. However, you can follow the following steps in order to reset and change the Microsoft Office 2007 product serial key without the need to uninstall or reinstall 2007 Office system suites.
Note: The following steps involve modification of registry key values, which may corrupt your Windows if done incorrectly. Backup registry first before performing the workaround.
  1. Close all Microsoft Office programs.
  2. Click on Start button, then click on Run.
  3. Type “regedit” (without quotes) in the Run text box, and click OK or press Enter.
  4. Locate and then click the following subkey: HKEY_LOCAL_MACHINE \Software\Microsoft\Office\12.0\Registration
    Inside, you will find another subkey that resembles the following subkey:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\12.0\Registration\{30120000-0011-0000-0000-0000000FF1CE}
  5. Optional: Backup this registry branch by exporting the Registration subkey to a file, just in case the new product key does not work and you have to restore back the old product key. To export the registry, right click on the Registration subkey and click on Export, and follow the on-screen prompt to enter a file name for the registry file and choose a location to store it.
  6. Under the Registration subkey, there may be several Globally Unique Identifiers (GUID) subkey that contain a combination of alphanumeric characters. Each GUID is specific to a program that is installed on your computer. If you find additional subkeys that reference Microsoft 12.0 registration, then click and open each GUID subkey to view and identify the Office product version by the ProductName registry entry in the right pane. For example:
  7. After you find the GUID subkey that contains your Office product or program which you want to remove the existing product license key or registration details, delete the following registry entries by right clicking on the registry entry in the GUID subkey, click Delete, and then click Yes: • DigitalProductID
    • ProductID
  8. Exit Registry Editor.
  9. Run or open an Office application program, such as Microsoft Word or Excel or Outlook. Office 2007 will prompt you to enter a new 25-character product key.
  10. Type in the valid and genuine product key, and then click OK.
  11. Then when prompted to choose your preferred type of Microsoft Office 2007 installation, press on “Install Now”.
  12. Microsoft Office 2007 will be updated with new product CD key or volume license key, and ready for activation (if it’s a non-VLK serial) or use.
Jul 07, 2010 | Microsoft Office Computers & Internet
MICROSOFT OFFICE HOME AND STUDENT 2007
Hi,i'm Dildora.i need microsoft office 2007 to load in my laptop. i do not have product key. can u get me 25 character product key. Please describe the specifics of your problem below. We'll add your post as a comment to HIEK's Hi.
Jan 06, 2009 | HP Pavilion Media Center a1330n - AMD...
Microsoft Office Standard for PC Logo
35 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
