Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
I have a Robinair 34700, during vacuuming and recycling I lose about 200 g refrigerant gas.
    President:
  • 180 Answers
Don't worry this is normal.Because while machine is running for vacuum or recycle mode,automatic air purge device will active for some time & it will purge air from ISV.
Posted on May 28, 2010
Robinair 34700 hi-p
Disconnected Air Purge lines. It was under high pressure (careful).
Feb 29, 2012 | Robinair Cool Tech 34700Z Recovery,...
34700 unit when in the vacuum mode it sends R134 into the oil recovery bottle tank
Please check oil drain sensor(switch) or oil drain solenoid for any debris. If both are check OK, then check Vacuum,Recycle and charge solenoid for any debris or damage. Replace/rebuild as needed. Hope this will help you
Nov 03, 2010 | Robinair Cool Tech 34700Z Recovery,...
Every time machine is put on vacuum, it starts purging air
This is a normal function during vacuum. But it can happen if the refrigerant is not 100% pure. However if it is so ling then you may need to rebuild airpurge solenois or replace Automatic airpurge device. Hope this will help you to rectify the problem,if this solution is helpful to you please vote for it. Good luck.
Aug 03, 2010 | Robinair Cool Tech 34700Z Recovery,...
Robinair 34700 recovery problem
It sound like one of the pressure trunsducer is not working or disconnected from the manifold assy.or from ISV tank.Please check Low,High and ISV tank pressure transducer
Jul 08, 2010 | Robinair Cool Tech 34700Z Recovery,...
ROBINAIR 34700Z ALWAYS FAILS VACUUM CHECK AND WON'T INJECT OIL.SAYS PRESSURES EQUAL.
Please check the following: Low side manifold gauge is going to -13"HG while you recover refrigerant from the vehicle.If low side gauge not rich to that lavel then vacuum sensor will detect pressuer &
it will stop you to make vacuum until you fix the problem.If it happen you may nee to rebuild/replace one or more of this solenoid.1#Vacuum solenoid 2# Recover solenoid.3# Recycle solenoid.Also check Low/High side small solenoids ( In the small block assy.)
If all of this solenoids working properly then check Vacuum pump capacitor & vacuum sensor.Hope this will help you to solve your problem.
Apr 09, 2010 | Robinair Cool Tech 34700Z Recovery,...
PROBLEM WITH WEIGHT CALIBRATION
Calibration procedure for Robinair AC machine.
NOTE:FOR SCAL CALIBRATION YOU SHOULD HAVE 9KG/20LB OF WEIGHT.From main menu go to change default (press 8787 for old type machine or 5454 new type machine)
then press enter/start key.after enter to default nenu you have to select calibrate scal option.press again enter/start key then follow the on scree message.once you done so,press stop/exit key to complete the prcess.
Aug 18, 2009 | Robinair Cool Tech 34700Z Recovery,...
Model Robinair 34700 Series 21699 Date 09/97 very slow when recharging system? Same problem on any vehicle. Tried closing off high side and running the vehicle ac n/g Any Help Thanks Tony
Please do the following 1# Check your machine ISV tank liquid line quick connector.it's seems to be very tight,open little & try to charging.2# Rebuild charging solenoid.
Jun 23, 2009 | Robinair Cool Tech 34700Z Recovery,...
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
524 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
