I have a Sony pfm42b1 plasma tv and I get a fuzzy distorted picture. Also, I hear a loud buzzing from one of the transformers. Can anyone help me on this?
  • 5 more comments
  • Steve Yelmene
    Steve Yelmene May 28, 2010
  • Steve Yelmene
    Steve Yelmene May 29, 2010
  • Steve Yelmene
  • Steve Yelmene
    Looking forward to working with you!
  • Steve Yelmene
    Here are my voltage specs and measurements. Were you able to locate a service manual?
    vs=150-170 reading=165
    va=50-70 reading=67
    vcc=4.75-5.25 reading=5.14
    ve= +17 reading=16.95
    veq=+18 reading=-106
    vey=+18 reading=-161
    vx=50-100 reading=90
    -vq=120-170 reading=-124
    vsc=70-120 reading=-51.3
    -vy=150-180 reading=-175
    vra=0-2 reading=2.1
    vrr=3v reading=3
    vrs=0-3 reading=1.5
  • Steve Yelmene
    I don't know if I already added the comment or not. But here is the measurements I came up with and I was also going to ask if you came across a service manual.
    va=50-70 reading=67
    vra=0-2 reading=2.1
    vrr=3v reading=3
    vrs=0-3 reading=1.5
  • Steve Yelmene
    Steve Yelmene May 30, 2010
    you got it buddy, give me a chance to look things over and get back with u. Did u leave me a link to the service manual so I can downoad it? I didn't see one. Please get that too me so I can see what we are looking at.
    Thanks,
    Steve
  • 4,889 Answers
That sounds like a HV circuit problem. Where is this transformer located? Sustain board?
Posted on May 29, 2010
  • 5 more comments
  • Steve Yelmene
    it is located on the power supply board. it is a hv problem. i am in the process of testing the voltages and documenting them. let me get back to you with a full report. unless you have repaired a few and already pretty much know where the problem is? There is resistor that has been fried on that board. the location is r203 and I need to know the value.
  • eagle338
    eagle338 May 29, 2010
    Try the color code. Resistors have color code on them that you can use to read the values. If you don't know how to read them please refer to guide below.
    http://www.elexp.com/t_resist.htm
    Yes I did see this problem a couple of times on a different model but they were 42" sets as well. But this kind of problems cannot be pin pointed exactly without checking the circuits first one at a time.. I will see if I have a service manual for this model.
  • Steve Yelmene
    Thanks for the info. let me get back to you tomorrow and give you some voltage mesurements. The resistor is a little burnt. That's why I wanted to give you the part location on the board. We will talk about the rest tomorrow and have a great evening. We will see if we can pinpoint this problem together. TTYL
  • eagle338
    Sure thing. Good evening to you too.
  • eagle338
    eagle338 May 30, 2010
    Here is the service manual. Sorry I was kind of busy so could not respond. I should be free in a couple of hours and will compare the readings you have posted.
    http://www.megaupload.com/?d=A0O56QZL
    Sai.
  • eagle338
    Ok. I am back. Now the values you have sent me don't make much of a sense to me. Please let me know what are your test points. See service manual and lets talk with respect to that so that it will be easier to ensure that we are on the same page.
  • eagle338
    Yes that is indeed the link to the service manual. Download it and have a look.
  • 12,061 Answers
Forums.futura-sciences.com/.../56514d1222941113-plasma-sony-pfm42b1e-sony-pfm42b1e-plasma-tv-sm.pdf Above is your service and repair manual, below is your user manual BOTH have invaluable information, please download and use both, thanks. http://esupport.sony.com/perl/model-documents.pl?mdl=PFM42B1
Above is your service manual, inside this manual are troubleshooting procedures, use these and you will soon isolate your problem.
With this symptom, it is impossible to tell what the exact "Cause" of this symptom is. The LED's do not tell us what is wrong, sometimes it may indicate the "Area" in your case it is the X board. BUT thats NOT where the "Fault is" thats just the part that is affected. These days unlike the "Old" analogue days it just isn't realistically possible to fix anything but the most basic of problems with todays sophisticated units. This is quite apart from the Safety aspect, any unit that can cause a firs or have an explosion, or both, is NOT to be treated lightly, and and the repairer, of the unit is legally responsible, another thing to think about. Also, one must have tools, a Multimeter, a soldering iron, a deslodering iron, an oscilloscope, a signal tracer, tools, and most important of all, a Service Manual, without which, there is no way to even begin to understand and fix it, and more importantly Program it, AFTER it has been fixed. As these days a TV, is a PC, a Tuner, and an HDTV Monitor, and more, all in one. in the "old" days TV"s were more, rudimentary, and built to last for 20 years, and a "Parts" supply was set aside. They usually used to fail for only a few reasons, and they while still difficult, were less difficult to repair. Electrical knowledge was transferable, and they could be and would respond to, This-is-the-symptom-This-us-the-Fix, But that no longer applies, as now, it can be a Fault on I squared Bus, or "Sensor" failure, or it simple may have "Crashed" just like a PC, It could be a Diode go bad, and that will stop the whole thing. You see, in the day, the sets were Very "Fault Tolerant" because they were Analouge, and a faulty, component, or more sometimes, the set would always diplay something usually, and when they didn't it was one of anly a few things, sure there are always the horrid ones, and there are pleanty of those, but all in all it was quite easy. But with Digital Electronics, it either goes, or it doesnt, there are usualy few half measures. I mean thats the definition of logic either going or not. So it can take very little to completely paralyse a set, and generally give the only sysmptom, it can, by not working, usually No picture, or the like. So you, see the list is endless almost for any given SYMPTOM, as that is what is being seen, not the cause, as I keep going on about. Also any fault, usually involves the Power Supply, it is either the cause, the cause of the damage, or it is damaged. or ALL of them. Then after you have done the electronic repairs, you then must program the set to work, and align, and set up in general, any one of those settings missed or done wrong, back to square one. So, it is nearly always my professional opinion that one should always get a "Quote" form the manufacturers recommended service center, I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else.
So, it is nearly always my professional opinion that one should always get a "Quote" from the manufacturers recommended service center, Toshiba in your case, please contact a local or head office and ask for a referral to an Authorised service center. I cannot stress how important that last point is. It is even worth the cost of shipping. You see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else.
Posted on May 28, 2010
  • Steve Yelmene
    there is a ... on your service manual link (it didn't give me the whole link). I do now have the needed equipment for testing purposes and went to college for consumer electronic repair and have practiced it as a hobby through-out the years. So, for me to take it to a service center is a huge insult. Being that I have the knowledge to do these sort of things myself. I understand technology has gotten more complex. I have kept up with it. The reason I am on this site is to talk to experts with more experience than me to get ideas. Not to be referred to paying more money out of my pocket! Please send me the link to the service manual again if you would though and thanks for all of you thoughts. I appreciate most of them.
    Guru:
  • 416 Answers
I believe your power supply is the problem. The fuzzy picture is due to panel voltages that are "unclean" or drifting out of spec. The buzz is caused by a worn transformer or may be coming from the panel due to the "unclean" power it is receiving. You could replace the failing supply, but the part cost is very high (as are all parts for this model). The part number for the power supply is: 98850485. I was able to find it on Theyservice.com at a whopping price of $1,695.25. At current Plasma TV prices, you could buy 3 new units for the cost of this single part. I would advise replacing the unit once it becomes too unbearable.
  • Steve Yelmene
    What part goes bad on avereage to cause this? do you know where I can get a service manual
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Aug 11, 2017 | Panasonic Viera Plasma TV TC-P60ST30
SONY PFM42B1
Just check - easiest with another tv if you have one that the signal source you are using is not the cause of the dimming. Also check that the voltage supply to the set is at the correct level - unlikely but a slightly lower voltage on the power circuit could dim your picture. The phosphor in a plasmascreen is generally a thin coating inside each of the tiny glass pockets which contain the plasma gas mixture (each of which becomes a pixel when activated). Unless you could open up each one of the pixel pockets and recoat the inside (not recommended) the answer to your question is no. Since the picture is made with phosphor, engineers can accurately predict the geometric decline of the phosphor?s potential brightness. Note that while the brightness declines slowly, the phosphors never actually burn out. Also, note how the rate slows over time. The rate of decline points to a specification called ?Life to Half Brightness? or LTHB. The half life ranges from about 10,000 to 60,000 hours, depending on model, it is about the same as you?d expect in a high-quality, properly calibrated TV or studio monitor.(see attached graph). Here is the link to the user manual for your set if you need it; http://esupport.sony.com/perl/model-documents.pl?mdl=PFM42B1 Check page 97 of the pdf (page 45(GB) of the manual) - it explains the self diagnosis feature. Sorry I couldn't find the details of the resulting flashing light's meaning online - you need to contact sony with the results to find out for sure if your screen is the problem. Hope this helps - sorry if bad news :)
Aug 05, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Loud buzzing sound,
There are a couple of possibilities. There are some styles of TV's which have lightbulbs which project light from the back of the TV. These are big TV's but are not Plasma's.
The bulb will be behind a small square or rectangle door and can be held shut with a screw or several screws. You can get the parts Online. You do not touch the bulb without gloves or a rag. A fingerprint will make a hot spot and destroy a new bulb.
There is no adjustment with a new bulb, so they are plug and play. The buzzing is the bulb arcing. The second possibility is a meltdown in a power transformer or capacitor. The video and audio are 2 separate systems to a certain point and that is why one can work and the other can be bad.
I would do a Web search using your Make and Model and look for bulbs and Consumer complaints.
Jan 25, 2012 | Samsung PS50Q97HDX 50 in. Plasma TV
A buzzing noise coming from inside the tv but still buzzes when on mute but doesnt buzz when tv guide is up on the screen or when a channel is showing what time it starts
plasma tvs buzz a lot, depending on screen brightness. its probably normal but if you can hear loudly over your volume, may be a bad board or plasma panel. from behind tv, left side = y board, right side = z board, middle = power board ---- bad panel can buzz from anywhere... if you hear all parts buzzing, its probably normal plasma noise
Jun 01, 2010 | Samsung Televison & Video
Vizio makes loud static noise, picture goes fuzzy.
You should check your home wiring and grounding. Also be aware of anything that has recently been turned on when this happens. Anyone using a microvwave, cell phone, or other appliance that might be causing the interference.
Mar 02, 2009 | Vizio P4 46 in. HD-Ready Plasma Television
Sony plasma picture is blurry and makes a popping noise
Hello MDay02,
Your problem maybe your X board which is the same as PCB X sustain. Changing the fuse in this case may NOT solved your problem. If you are handy, you may be able to change the board yourself. We have most Sony X board in stock. If you purchase the board from us, we will walk you through the installation process for FREE over the phone.
Mar 17, 2008 | Sony PFM-50C1 50 in. Plasma HDTV
Buzzing/Fizzing noise at the back of TV.
Sounds like arcing from the high voltage transformer. i don't not recommend using it until you have it looked at.
Jan 30, 2008 | Televison & Video
Loud buzzing
check your connections again, if you have the audio and video reversed you will get this exact problem no video/ fuzzy video, and squealy noise out of only one speaker (other will likely sound correct) You're watching the sound channel, and listening to the video channel basically... hehe
Aug 14, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Technical repair questions
your fly back is bad. the fuzziness is caused by the bad fly back. and soon you will lose the picture due to this fly back and might cause the horizantel transister to blow. change it as soon as possible. good luck
May 01, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
108 people viewed this question
Top Televison & Video Experts
