Question about Mtd 22" Yard Machine Push Mower
Recoil starter wont let me pull it out - Mtd 22" Yard Machine Push Mower
  • 61 Answers
I would think that your engine control cable has gone bad. There is a brake on your flywheel and your engine control cable releases this brake, this cable is hooked to the handle that you have to hold down to start the engine. you can remove the engine cover and see the brake against the flywheel, pull the handle and see if the brake is releasing. If it is releasing then something in the recoil is defective. I hope this is of some help to you.
Posted on May 29, 2010
My recoil starter won't pull out it is stuck
Just take the cover bolts for the pull cord off. Then see if it works. There are usually two cogs that engage into the shaft of the engine. These cogs push outward when you pull the cord, engaging the shaft of the engine.
Oct 01, 2014 | Garden
How to fit a recoile spring to my husqvarna stimer
you can pull the rope and it recoils just fine but it's not gripping the engine's crankshaft then most likely it's one of your recoil's starter pawls, the part you'll want to look into is called that, a pawl, and it's either the pawl itself or the spring that attaches to it
Aug 18, 2014 | Garden
HOW TO FIX MY TORO RECOIL
You need to probably replace or put the recoil spring back in place.,You have to take the recoil off to do it.
Jun 22, 2014 | Toro Power Lawn Mower
Problems with recoil starter
The recoil starter needs to be repaired. It is a common failure item.
Apr 27, 2014 | Craftsman 3000 PSI 27 GPM Briggs ...
Recoil starter
Go to you tube On the line repair recoil core
Feb 14, 2014 | Toro Power Clear 418 ZR - Single Stage...
Broken spring in recoil starter on lawn mower
While I have not done this on newer model lawn mowers, I have replaced recoil springs in the past. Here's what I did: First you need to pull the spark plug wire off so the engine will not start. Then block the flywheel with a piece of wood to keep it from turning. Then, using another piece of wood such as a short (6-8 inch) hardwood dowel placed against the ears of the recoil drive, and drive it in a reverse direction (clockwise) with a hammer to knock it loose. It may take several sharp blows to break it loose. The recoil drive is reverse threaded to keep it from coming loose when the engine is running. Once the drive is loose, remove it to get access to the recoil spring which must be replaced if it is broken. With a new spring in place, rethread the recoil drive counter clockwise until it is finger tight. Then, tighten it down with one sharp blow against the wooden dowel.
Jul 10, 2013 | Garden
Pull cord wont spin the motor
The engagement "dog" is probably rusted in place. Try spraying WD 40 on the recoil mechanism as you pull the starter cord
Jun 27, 2012 | Garden
Husqvarna 125r wont start. has spark, compression, air filter and exhust checked. could it be the timing? if so how do you adjust?
Pull spark plug out. Pull cover from recoil starter. Pull recoil starter. Inspect flywheel mag's for cleanliness. Then turn engine over untill piston is topped out. Your manets and pick up should be lined up to eachother at this point. If they are not, pull nut and or bolts from flywheel and remove to check for damaged key-way or woodruff key that aligns flywheel to crank. That is the only timing.
Apr 27, 2010 | Husqvarna 28cc Gas Line Trimmer
Pull start on my Toro snowthrower (snow master 20 - model #38020) it wont recoil itself. I removed the starter housing but can not figure out how to get the pulley and starter recoil spring out/off of the...
Its basically the same....best bet is to just buy the new pull start mechanism...they are pretty cheap, and they go bad on those units all the time.
Jan 12, 2010 | Toro Garden
Mtd 22" Yard Machine Push Mower Logo
380 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
