Question about Garden
Why does the pressure washer start, but stall when the choke is being closed?
  • 3,740 Answers
Remove the float bowl nut and clean out the holes in the bowl nut. There is most likely debris in the holes. If this is not the problem I need the engine model number to assist you more.
Thanks for using FixYa.
Kelly
Posted on May 28, 2010
  • Kelly
    Kelly May 29, 2010
    Just doing a follow up here. Is the engine still running rough after cleaning the float bowl nut? If so I really need an engine model number to pass you the correct information.
    Kelly
How come on a troy built Honda pressure washer when you push in the choke it stalls
if it stalls most case scenario would be the carburetor ,it needs the jet and fuel tube cleaned.
Oct 18, 2014 | Garden
Exha2425
not supposed to... only supposed to start with choke closed...Now if you mean will not run unless choke is closed I would suggest removing and cleaning the carb...
Nov 07, 2013 | Garden
Engine starts but won't continue to run. Choke doesn't stay closed after starting. will stay running only if I hold choke closed manually.
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Aug 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
I have a pressure washer, that i start with the choke on. as soon as i shut the choke off it stalls
First thing, if you are using last years gas stop and get some fresh gas, old gas is enemy #1 of small engines. You may need to keep the choke on longer and then only take it half way off. if it does not warm up in a minute or 2 you most probably have a fouled carb. you can try some carb cleaner that you add to the gas and see if that works.
May 06, 2011 | Karcher 2500 PSI Pressure Washer
The engine starts cold after 2 or three pulls, runs ok initially, but seems to have slightly less power. After a few minutes I can turn off the choke. When teh engine warms up and runs for about 15...
I would first try draining the carb bowl, if you look at where the choke lever is and look below that you should see a clear red tube with a flat head screw below that, if you just turn the screw out the carb will drain. If you still have an issue you are going to have to clean the carb.
Oct 26, 2010 | Karcher G3025OH Pressure Washer
Won't start, can't remember starting procedures and dont have manual
Make sure the fuel valve is on. Generally that means pointing down inless there is a diagram on it.
Turn the switch on.
Pull the choke on the carbuerator on full. There will be a picture of a butterfly valve set it so that it is closed. Pull the cord till the engine fires. let it sputter for a second, then open the choke. If the engine dies right away, do all of the above again but once it fires, only open the choke half way. once it warms up a bit open the choke completely.
Dec 22, 2009 | Honda Pressure Washer PSI 3000
Reconditioned B&S pressure washer will not restart
Some suggestions:
Is the gas old? If in doubt replace it.
Try removing the air filter and spraying carburetor cleaner into the carb Then try starting it. If it runs for just a minute, then stops, the carburetor needs cleaning.
Sep 19, 2009 | Briggs & Stratton Garden
Pressure washer stalls off choke
Probably the carb's low/mid speed circuits are clogged real bad. The only fix I know if they are as bad as you describe is remove and soak/clean carb, and this may not work as some of the circuits are as fine as as human hair, and the solvent may or may not work. Then it' replacement time.
Sep 14, 2009 | Briggs & Stratton Garden
Garden Logo
82 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
