Question about Lexmark Office Equipment & Supplies
Phone jacks pushed in how do I open up to pull them out
Phone jacks pused in how do I open up to pull them out?
  • 623 Answers
Look for a little tab on the side (the wide one) push on it and it should release.
Posted on May 28, 2010
Speakers won't work after I use headphones
This more about what you are connecting the speakers to.
The headphone jack is essentially a switch that mechaniccally opens the ground connection to the speakers. It is a spring that is opened by the headphone jack pushing the spring contact open. What often happens is the headphone plug gets pulled at an angle and forces the clip to be open permanently.
Sometimes the jack can be removed and replaced. Take the music source to a repair shop.
Feb 26, 2015 | Audio Players & Recorders
Tip
How to connect your VOIP phone service (IE Vonage, MagicJack, Via Talk) to...
Are you tired of being tied down to your computer area to use your VOIP phone service (IE Vonage, MagicJack, Via Talk or ITP)? Here is a way to make your existing home phone jacks work with your VOIP.
***** DO NOT USE THIS TIP IF YOU HAVE DSL (FROM THE PHONE COMPANY) FOR YOUR INTERNET SERVICE PROVIDER OR IF YOU ARE IN AN APARTMENT BUILDING*****
Items you will need-
  1. An existing home telephone jack near your VOIP service modem.
  2. A screwdriver
  3. A telephone cord long enough to reach from the VOIP service jack to the existing phone jack.
COMPLETE THESE DIRECTIONS EXACTLY AND IN ORDER OTHERWISE DAMAGE COULD RESULT TO YOUR VOIP MODEM.
NOTE THAT EACH HOME IS SLIGHTLY DIFFERENT AND MAY HAVE NON-STANDARD WIRING SITUATIONS OR HAZARDS UNFORESEEABLE SO THIS TIP IS TO BE DONE AT YOUR OWN RISK AND YOU WILL BE RESPONSIBLE FOR ANY CONSEQUENCES THAT ARISE FROM WORKING ON YOUR OWN HOUSE SUCH AS IF YOU DAMAGE ANYTHING OR GET SHOCKED OR FRY YOUR VOIP MODEM AND BURN DOWN YOUR HOUSE IT'S ALL ON YOU....
So hopefully I haven't scared you off from trying this tip since it is fairly simple to do but complements of lawsuit happy America I had to cover the disclaimers....
Let's get started...
First thing you need to do is to locate the main telephone junction box to your home usually located outside near the power meter. Here are some pics of some standard used boxes.5124c69.jpg
There is a screw keeping the customer access door closed. Loosen this screw and open the access door to expose the home wiring. Note: this screw does not usually come completely out. To set you at ease, yes it is completely legal for you to access this portion of the box. The portion that you are not supposed to access is restricted by a security bolt and can not be opened with a normal screwdriver.
Once you have the access door open there are two types of commonly used connections.
  1. The most common is one similar to this picture. Disconnect the lines attached to the test jacks.
    If you have more than one line here then loosen the screw terminals one at a time and place the wires from the other lines to the same terminals on Line 1 so all jacks in the home should be available.
    Note: there may be a cover over where the screw terminals are for where LINE 1or 2 are, simply pull the cover toward you to expose the terminals.
2) The second style is very similar to the first but the area where the screw terminals are has a plastic rectangular bar about 2 inches long and 1 inch wide with telephone lines attached to it (often times Red and Green or Blue and White/Blue). If you have this style of connection push the side of the bar closest to the center of the box and then pull outwards and to the right this should expose the "Test Jack". Once the bar has been extended twist it 1/4 turn counterclockwise to remove it from its mounting bar. Use caution not to disconnect the phone wires attached to the bar.
Almost there and now the hardest part should be done.
Now return to where the VOIP modem is located and remove the telephone cable for the phone that was being used for your VOIP service.
Connect the new phone cord to the same outlet that the phone was connected to on the VOIP modem and then connect the other end to the home phone jack.
If you still want to connect a phone to the jack you are connecting to here then a simple telephone line splitter plugged into the jack will fix that.
Now try to connect a phone to any of the phone jacks in your home and you should have dial tone. Note that most phone service is made to comfortably handle 4 phones that connect to a phone jack.
on Jan 16, 2010 | Lands Phones
FIXING DOOR (DOOR IS COMING OUT)
The large oven door pull's off , and can also be pused back on the same way , if holding the door about 12" from closing pulled towards you to remove or push down to put back on if you pull it off the hinges it may take two to put it back on again
Jun 08, 2011 | AEG B2100-4 Electric Single Oven
How do i open the back of my htc hero phone?
In order to get the batter cover off the Hero, you will need to do the following:
- turn your phone over
- with both of your thumbs on the bottom of the phone/battery cover, push upwards towards the top of the phone. so push up from the usb jack of the phone towards the speaker jack
-the cover should snap off, and you will have access to your battery and SD card.
Good luck.
Jul 04, 2010 | HTC Hero Smartphone
How to solve charging problem
Dear, Could you explain the problem like is there a charging error display on your screen or is this problem of your charging jack.
well i can help you, if there is charging errror display on your mobile screen so your charger or your battery must be corrupt or non-geniune.
OR if there is problem with your charging jack so it is very easy to fix this problem, you just need to buy a new jack it is very cheap. Then if you can change it yourself so it is better otherwise you just go to a cerified mobile phone repairer and let him chande your jack. Changing the jack is just like 1 2 3, you just pull the jack back after opening your phone and push the new jack.
Thanks
May 06, 2010 | Sony Ericsson P990i Cellular Phone
I want to remove my Sim from iphone 32gb how ? and replace another Sim
To do this, you must have a SIM eject tool or simply a straightened paper clip or any pin-like object hard enough to push-open the SIM tray. BTW, the SIM eject tool came with the box when you bought your iPhone.
Now, on the top of the iPhone, in between the power button and the headphone jack, you'll find a fine oblong-shaped line which is the SIM tray.
To pull it out, you need to insert the SIM eject tool (or the paper clip) on the very tiny hole you'll find just beside the headphone jack. Push until the tray pops out. Don't worry, this is completely safe, that is the only way you can pull it out, just be gentle with your iPhone.
Once the tray pops out, pull it and replace the SIM with any SIM you want. When you're putting it back, remember that the tiny hole should be closer the the headphone jack (or the carrier logo on the SIM should be facing the front of the iPhone), and make sure that everything is completely aligned. Don't force it when it get stuck, just pull it out again, and gently put it back.
Here's an image for your reference:
Visit my blog for more iPhone / iPod touch tips, or click here find them on FixYa.
May 06, 2010 | Apple iPhone 3G
I cant hear my music
it's usually the first contact (ground) of the headphone jack module that loses it's elasticity and does no longer touch the headphone plug properly. you can try to pull it back inward from the outside using a dentist tool or a sewing needle. if that fails you have to open the ipod touch and push the contact inward or replace the jack module.
Jun 15, 2009 | Apple iPod touch
Remove back seat
If I remember correctly, you can push down on the bottom half of the seat bench while pusing back towards the back of the car, it should release the latch system so you can pull the lower seat cushion out, the back rest portion of the seat may be bolted in.
Apr 06, 2009 | 1994 Ford Taurus
21 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
