Question about Garden
Cub Cadet 2145 with 14HP Onan Engine.
Runs for 20 minutes or so and then quits. Took spark plug out and checked, no spark. Sits for awhile and then starts normally. Problem repeats itself over and over.Seems to have plenty of gas in the carb.
  • 284 Answers
Sounds like you may have ignition coil or module whichever you prefer (one in the same) may be heating up and shutting down? Check all your grounding connections also
Posted on May 28, 2010
Cub cadet lt1050 starts but after mowing for awhile i shut it off it wont start again
be sure the air fins on the engine are clean. make sure the fuel line is away from heat source. loosen the fuel cap and see if it starts. sometimes if the cap don't vent it will not let it start. change the spark plug. check to see when it does this if it still has spark. the coil may be going bad.
Oct 05, 2016 | Cub Cadet Garden
I have a Cub Cadet Model 364 with a 18 H.P Briggs & Stratton motor. It runs fine for about 20 minutes. Than starts hesitating. Like the motor wants to stall out. Help!
Firstly, try to run the engine without cap on the fuel tank. If it stays running well, clean out the ventilation hole in the fuel cap ( or replace the fuel cap ).
Check for dirt in the fuel tank, fuel tank connections, hose, strainer, filter. Clean everything!
Check if you still have sparks when the engine stopped from itself.
Check if you still have compression when engine has stopped from itself ( valve settings too close )
Sep 28, 2016 | Cub Cadet Garden
Cub Cadet LT1050 Runs fine..20 min...dies...wait 20 min....runs fine 20 min.
Check the breather in the fuel cap, run it with the cap loose and see if it is any better.
May 30, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Cub cadet series 2000 stops running after 20 minutes cutting
Hi, check that you have spark. they are renouned for doing ignition modules in. Regards Phil.
May 31, 2012 | Cub Cadet Garden
Cub cadet 12.5 hp kohler comand engine sporadic loss of spark
spark control, yes, trace spark plug wire back to its end, you will find what I will call a coil, for lack of the better word, it can be. I would think that is your problem, if you are presently not getting a spark in the plug.
Jul 18, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 2145 (Onan engine)runs the battery down
One possible problem is the voltage regulator is out. To test this, start the engine and put a d.c. volt meter on the battery, if the voltage readout decreases as the mower runs, replace the regulator
Jun 24, 2009 | Garden
Cub cadet weed eater wont stay running
air vent in gas cap pluged, push a pin through it
Oct 04, 2008 | Craftsman 25cc Gas Line Trimmer
Garden Logo
360 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
