Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
I want to put a fuel cut-off valve on my poulan lawn tractor. I have a warranty and I don't know if that will void my warranty or not. I also have insurance on the tractor. If I put anything on the tractor will that void my warranty?
  • 284 Answers
No, not something simple as a fuel cutoff valve,but
to be sure you can always call where you bought your mower from and ask ,or call poulan service center,or a known warranty service center in your area that would honor a problem if ever needed.
Posted on May 28, 2010
  • 2,841 Answers
I cannot see how installing a simple fuel cutoff valve could possibly void the warranty. But, just in case purchase the cutoff valve from the same place you bought the mower and pay them to install it. That way there will be no questions later on if something comes up. You might spend a few dollars but you will cover yourself.
Popular Pro 625 series. starts and runs but why does it die while cutting?
Poulan PR625Y22SHP Lawn Mower User Manual
homeappliance.manualsonline.com > ... > Poulan Lawn Mower
Poulan PR625Y22SHP Lawn Mower User Manual ... Briggs & Stratton 850Professional-Series Commercial Replacement Push Lawn Mower Engine (190cc, 7/8
Sep 11, 2015 | Garden
I have no brakes on my 17.5 hp 42" cut Poulan lawn tractor. No parking brake, nothing. I need to know how to replace the brake pads on this particular machine.
Most garden tactors have a basic disc brake on the side of the gearbox, a small caliper is held with a couple of bolts, you need to know who the manufacturer of the gearbox is to get parts, they are not supplied by the tractor manufacturer.
Aug 21, 2013 | Poulan Garden
2008 poulan pro 18.5 hp 42" cut 6 spd smokes bad when i put it in gear
check drive belt make sure its not rubbing against melt guied tabes
Aug 18, 2013 | Poulan Pro Lawn Tractor 2006 and Newer...
After finishing mowing my lawn the other day, my mower leaked (dripped) gas from beneath the bottom of the carberator. What should I do to get the leaked stopped?
Ok, first thing you need to do is check your oil. Make sure no gas has gotten into the oil. if it has then be sure to drain it.
carberators today are really having problems with very tiny dirt particles making them malfunction. after cleaning my carb 3 times in one year and having to change the oil each time, i decided to get a 6 dollar fuel shut off valve. i cut the fuel line and installed the valve. when done mowing i turn the valve off and have not had a problem since. in fact i have put a valve on all my small engine equipment.
Apr 29, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan 550 mower idle problme
Check air filter, replace if needed.
Check engine oil level and condition. Add/change as needed.
Check spark plug. Clean and re-gap if needed (.030 gap)
Drain the fuel and replace with fresh premium grade gasoline. If your local station has a notice on the pump regarding Ethanol content, drive to another station!
Most owner's manuals specify 89 octane or higher and most warranties become void if E85 fuel is used.
And finally, Oxygenated fuels are not your mower's best friend. :-)
Hope this helps.
Oct 04, 2009 | Poulan Pro " Pro" Self Propelled Mower
Lawn Tractor won't start after wrong fuel used, drained, etc
Check the fuel shutoff solenoid (on the bottom of the carburetor -- has a wrie plugged onto it) -- it may be sticking.
Spray carburetor with carb cleaner. Then if you can get it to run long enough to do any good, put carb cleaner in the fuel -- follow mixing proportions on the label.
If this doesn't work, need to take carb apart and thoroughly clean it.
Charlie
Aug 29, 2009 | Garden
How to put deck belt on
need a diagram of how to put a deck belt on a 15.5 hp/38" cut 5 speed poulan lawn mower model number 9601200-3801
Jun 22, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
96 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
