Question about Andis 04710 Beard Trimmer
Trimmer humming but not cutting
When the trimmer is turned on the trimmer hums but the trimmer does not cut , neither do the blades move, before this i have had no problems with this trimmer. ive had this product for a couple of years now but only used it around ten times a year
any suggestions would be well appreciated. thanks.
    Problem Solver:
  • 9 Answers
Use new battery if it used with battery..
but if it used with electricity then motor inside has gone bad
Posted on May 29, 2010
My husbands clippers won't cut
Blades are NOT moving HOW TO Fix a broken Hair clipper ...
? 2:42
https://www.youtube.com/watch?v=DX4Xc47F_IE
Mar 29, 2015 - Uploaded by You can Fix It!!!!
... blade fix how to won't cut by adjusting the blade adjusting the play with the motor so ... Blades trimmer trim trimming cut cutting cutter trimmers barber ... dog clippers shear shears shearing shave shaver shaving buzz cut ...
My clippers hum like their working but dont cut - Fixya
www.fixya.com/.../t3222969-clippers_hum_like_working_but_dont_cut
Jul 25, 2008 - my clippers hum like their working but dont cut - Wahl Designer 6 (8355100) question. ... hair clippers repair. Apr 22, 2013 ' Shavers · 1 Answer ...Clippers jam and won't cut when trying to use attachments. Jan 11, 2009 ...
Clipper Maintenance - Rapid Edge
www.rapidedge.com.au/cat/maintclip.html
Clipper won't cut cleanly or easily. Lack of oil and dirty. Sometimes a hair gets caught between the blades. Lubricate and clean your Clippers regularly.
Dec 21, 2015 | Health & Beauty
B&D Hedge Trimmer (HT33) was working yesterday but not today. Motor sounds fine & the blades move back & forth ... just not cutting any foliage ... any ideas?
Mechanical issue. Make sure that the screw that holds the moving blades up against the non moving blade is adjusted properly. If loose, the blades will not be close together during the cutting stroke and no cutting will ensue.
Jul 05, 2015 | Garden
Stihl hl75 pole trimmer. Blades don't move. Cable turns when cutting end is off machine, but will not drive blades when it is attached. Anyone have an idea as to what's going on?
More than likely a gearbox problem in the cutter head. They can break teeth on the gears and also have delicate needle bearings than can wear if they are ungreased. Maintenance is paramount on these moving parts.
Jul 26, 2012 | Stihl Hl75 Line Trimmer Owners Manual
When i turn on my shaver it just hums. no cutting sound.
Possible that the blades are clogged with hair or dirt and the motor is jammed . Use the fine brush that had come along with the shaver to clean and free the blades, Use some light oil on the blades to free any signs of dirt or rust on the blade set.
After shaving it is important to clean and keep the blades dry.
Dec 08, 2010 | Andis T-Outliner Hair Trimmer
Flymo sabre hedge trimmer blades move but do not cut!
It sounds as if they have come off of the spindle inside and are not synchronised as they should be so the bottom blade is being pushed out of the way when trying to cut. You need to open up the head and unscrew the top to the small gearbox and make sure the bottom blade hasn't jumped up off of the catch point on the shaft.
Jul 23, 2010 | Garden
Hi! There is power to the unit....the blades don't move.
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
Jun 08, 2010 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
My Black and Decker hedge trimmer's blades won't move, but smoke and a burning smell comes from the motor. Can it be fixed? How much would it cost?
Your blades are stuck together.
What I did:
And it worked!
May 30, 2010 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
Homelite hedge trimmer , motor runs but blades do
What I did:
And it worked!
May 16, 2010 | Homelite Factory Reconditioned 26cc...
Motor runs, but blades dont move
with engine off, take a screw driver and manually move the blades to make sure that they are not jammed. Then spray the blades down with wd-40 oil and they should move freely again.
Jul 28, 2009 | Garden
My B & D electric hedge trimmer blades are frozen
spray liberally with wd40, let side and hour spray rag with wd40 and clean blades and look for any bent teeth in blade that maybe binding them as u clean use pliers and screwdriver to move if any found, it is likely that wither sap dried or rust formed and is creating too much friction for blades to move wd40 will help free up blades
Jul 09, 2009 | Black & Decker Black Decker 16" Hedge...
Andis 04710 Beard Trimmer Logo
312 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
