Question about Motorola Mobility RAZR V3
Troubleshooting my bluetooth is stuck and my keypad wont work. what can i do.
  • 2 more comments
  • vlad2379 May 12, 2008
    my motv3 just get hang-up and all the keypad dont work
  • Anonymous Aug 22, 2008
    I turn it on with the red end call button, but when its on I can't use the same button to turn it off and all the other keys won't work
  • doreenv3 Aug 23, 2008
    my phone turns on and then I can't do anything else
  • doreenv3 May 11, 2010
    i dont get any answer
To setup into pc
Posted on Apr 12, 2008
The smart wash light on my kenmore elite model 66513753K602 is flashing. I have tried the suggested button sequences to reset it and they have not worked. How do I troubleshoot it to determine which...
From the tech sheet:
CHECKING KEYPAD
OPERATION
A rapidly blinking LED over
one of the keys of the keypad
(or sometimes a "dead"
keypad/console) indicates one
or more key switch lines are
stuck or shorted on either the
control or the keypad. To
determine if the control or
keypad is faulty, do the
following test:
1. Unplug dishwasher or disconnect
power.
2. Open the dishwasher door.
3. Open console and disconnect the
keypad ribbon connection from
the control (at P1). Make sure all
other connections are made.
4. Put console back together. Do not
close the dishwasher door.
5. Plug in dishwasher or reconnect
power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control's response:
? If the control is OK (no longer
sees shorts with the keypad
unplugged), it will respond by
turning on a Drain Motor for
2 minutes. Check and/or
replace the keypad if the
control responds OK.
? If the control is not OK (still
unplugged), then the drain
motor will NOT respond and
will remain off. If no response,
replace the control.
Jan 21, 2015 | Kenmore Dishwashers
Sears troubleshooting
craftsman garage door openers are made by chamberlain.. Give them a call on their 800 number with your craftsman model number and they will help you
Aug 23, 2014 | Sears Craftsman LiftMaster Chamberlain...
Parrot 3200ls bluetooth wont pair with phone
go to SETTING / PAIRED DEVICES / move onto a paired device and press the middle button , then scroll down to delete and press middle button, then press green to confirm.
Apr 08, 2010 | Parrot Ck3200 Ls - Color Cell Interface...
LG 32lc7d lcd tv the work find for about 5min. Then the on screen menu comes on the screen then it gos off the remote will not work what board is it ?
Maybe the remote has some keys that are stuck together on the membrane pad. Take the batteries out of the remote, then turn the TV on again see if the menu problem is still happening. Also check the menu button on the TV see if it is stuck by pressing it a few times.......
If all seems ok but still have the same problem, then the the keypad board in the TV needs to be checked for intermittent shorts or opens. If the keypad board is good then the main board needs troubleshooting. This seems like an EEPROM problem, you may want to test that first on the main board.
any questions please ask....
CWR
Jan 20, 2010 | LG 32LC7D Television
How do you activate the bluetooth
make sure the driver is installed.
http://us.acer.com/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=843&ctx1.att21k=1&CRC=1841181145
Jan 04, 2010 | Acer Aspire 5536-5224 Notebook
My keypad on my Katana stopped working. Can only
Friend, Check the flex connection from the keypad interface then clean the board or the doom with pencil eraser
Jul 25, 2009 | Sanyo Katana SCP-6600 Cellular Phone
Whirlpool Dishwasher Model GU2500XTPS1 Light on soak/scour button flashes on and off. Dishwasher will not run.
there s atechsheet / troubleshooter behind you lower kickplate assy-- this was taken from there
PROBLEM: WON’T RUN AND LED ABOVE KEY(S) IS FLASHING
RAPIDLY
Stuck key(s) or shorted
circuit(s) in keypad.
See Checking Keypad Operation, page 1. Shorted circuits or
connections on the control
that read the keys .check/replace keypad
1. Unplug dishwasher or disconnect power.
2. Check/replace control
Nov 03, 2008 | Whirlpool Dishwashers
Windows Vista wont connect to these headphones
Try going to control panel->sounds->make the hands free audio the default.
Jun 17, 2008 | Insignia Bluetooth Wireless...
My keypad won't work
Sounds like the power button is possibly stuck or broken. Razr's aren't very durable. Did it get wet or dropped recently?
Jan 23, 2008 | Motorola Mobility RAZR V3
MMV5000 keypad is intermittent
You have a stuck button on the keypad.  With the cost to replace the part I would replace the microwave.  Would appreciate a solved rating for expert advice.
Oct 25, 2007 | Maytag MMV5000 Microwave Oven
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
