Question about Panasonic TH-46PZ800U Plasma TV
No action shutoff was activated. How do I turn
If we are watching the same channel for any length of time this notice comes on and the TV goes off "no action shutoff was activated". How do I turn this off? I cannot find it in the manual. Thank you
  • Panasonic Master
  • 8,457 Answers
Go in ur tv menu go to SETUP.Check for Sleep timer might be on.This timer have setting like 30 60 120 mins.Turn off the sleep timer tv well not auto shut off.Check ur remote control might have a button said sleep.
Posted on May 28, 2010
  • fergie200194 Dec 04, 2010
    It was not the timer....there is something in the manual about not using the tv -( like if no one uses the clicker or changes channels) say for three hours, the TV "thinks" there is no one in the room and it will shut off automatically to save hydro - it's something that is factory set and there isn't anything in the book about it that we could see either. So give the TV some action before the 3 hours are up!
Tip
Harmony remote always sets TV to channel 3
So I have had this a few times where the setup wizard for the Watch TV Activity not only asks what input the TV has to be on, but also what channel. A lot of the time I got annoyed when the channel would always goe to a particular one (usually 3) at the beginning of the Activity.
Unfortunately, we can not get rid of this setting, although there is a workaround. If we go through the setup for the Activity again, and select the channel to be '0' for the Activity, in most cases that will work.
When most TV's receive a '0' channel command and no other numbers, it disregards the command and stays where it is.
Hope it helps
on Mar 18, 2010 | Audio Players & Recorders
Hi I pressed the wrong button turning the TV on, now I have no sound and can't get it back. please help.
SAP (Second Audio Program) may be turned on. This used to be a widespread RCA problem maybe caused by incorrect conversion of analog signals for viewing as phony HD images. Costly class action lawsuits addressed the problem in USA. Most of the specific equipment causing the problem used by broadcast/production/satellite industries was either adjusted correctly or replaced. If the problem re-occurs, it may caused by specific TV channels or programs that you watch. Codes inserted in the signal are incorrect and confusing the RCA TV Guide and audio processing circuits. The error causes SAP to be incorrectly selected as default for all channels.
Remedies:
Change audio settings in customer adjust menu to Stereo from SAP. Sometimes the On screen TV Guide set-up must be cleared of location, etc., and set-up again.
Sometimes it is difficult to set correctly. Unplug TV for 12-24 hours and TV may reset to default stereo setting instead of SAP.
This was an active Class Action legal issue 10-15 years ago in the USA.
easyab
Feb 23, 2011 | RCA Televison & Video
HOW DO YOU GET CHANNELS REPROGRAMED INTO THE TV?
Hello
Auto presetting channels you wish to know I thinks, if so do the following.
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable (CATV)
channels.
? When AUTO PRESET CH action is completed, the lowest memorized
channel reappears on the screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH",
the tuner will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by receiving conditions. In this case,
try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input, "NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
OK.
Jan 11, 2011 | Emerson EWF2004 20" TV
What buton do press to get the channels?
Hello
To tune the TV either with cable of trerrestrial antena, plug in the cable or terrestrial antena cable to the antenna socket of the TV and do the following.
on the TV screen.
channels.
OK.
Dec 16, 2010 | Emerson EWF2004 20" TV
Recording
You should set the VCR to the channel which you want to record. It doesn't matter what channel the TV is on. In your case, just turn off the TV.
I making assumptions about your setup. If you can turn on your VCR and TV and watch the channel that you will be recording, then just turn your TV off, and you should be good.
Only caveat, some VCRs must be turned off while waiting for the recording timer to activate (presumably, so as not to interfere with someone actively watching a program).
May 19, 2008 | Sanyo VWM-800 VHS VCR
Viewing
When you watch TV with a Cable Box or a Dish Network Box you are using a tuner inside that box. The signal that comes out of that box only contains one channel, the one you're tuned to. So you can take the output of the Dish Box and send it into your ATI tuner card, but you cannot change the channel to anything other than what the DIsh Box is set to. I'm sorry, but that's just the way it is. I use a Hauppague tuner card that has what's called an "IR Blaster". By hooking this device up to my Cable Box and I can used my computer to change the channel on the Cable Box itself.
If you had cable, you could run the cable into the TV tuner and watch the analog channels. I have Time Warner in my area and they still broadcast about 50 channels in analog. I cannot use the tuner card to watch any of the digital channels. This probably does not help you, but I thought you might like to know.
I want you to know that I don't get paid to offer these suggestions. I know it's a strange hobby, but I like to help when I can. Even though I cannot solve your problem I hope I provided helpful information and you will give this solution a positive rating. I've noticed that many times this type of question goes unanswered because nobody wants to get a bad rating when a problem has no solution. Thanks and good luck.
Jan 02, 2008 | ATI TV Wonder 650 (DNH100715331) Video...
TV LOCKS TO ONE CHANNEL
Check menu for favorite channel setting......
activate auto-program for channel memory....
If that fails,try hard reset = unplug ac cord for a length of time,
plug in & try again..................T.
Sep 20, 2007 | RCA F36650 36" TV
Panasonic TH-46PZ800U Plasma TV Logo
2,955 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
