Question about Vivitar Vivacam 5399 Digital Camera
Put sd card in vivitar 5399 but not reading it
Not reading
  • kakima May 28, 2010
    Are you sure it's an SD card? If it's larger than 2GB then it's actually an SDHC card and won't work in the 5399.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vivitar Master
  • 102,366 Answers
Receiving no response in over a month, I assume this is no longer a problem.
Posted on Jul 02, 2010
Vivitar 508nhd wont work when SD card put in
Are you sure you have an SD card (2GB or smaller)? The 508 won't work with higher-capacity SDHC cards.
Jan 28, 2013 | Vivitar DVR 508HD Digital Video Recorder
How can i put audio on my vivicam 5399?
The 5399 is designed primarily as a still camera, with some video features grafted on. As such it captures images, not sounds. You can add a soundtrack using video editing software on a computer, but you cannot record one on this camera.
Dec 28, 2011 | Vivitar Vivacam 5399 Digital Camera
My Vivitar Vivicam 5399 is refusing to turn on. It has worked perfectly up until a couple of weeks ago, when it started to turn off at random moments, usually soon after I had turned it on. Now, it doesn't...
Have you tried to see if the battery door is completely shut? This is usually the problem with many digital cameras with batteries. Clean the battery door and where the battery touches the metal of the door. Check to see if the door is completely flush with the camera body when you close it. I know for a fact that Vivitar cameras **** the juice out of batteries fairly quickly also. If you have the USB-cord provided with the camera, plug it into your computer and see if that holds a charge to your camera. If all else fails, call up Vivitar for further inquiry, your battery may be dead.
Mar 08, 2011 | Vivitar Vivacam 5399 Digital Camera
Cannot download from vivicam 5399 NO DRIVER FOUND
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
Oct 30, 2010 | Vivitar 5399 Digital Camera
Vivitar 5399 not reading memory card. Originally had a 4GB card and that worked fine, then all of a sudden the camera wouldn't read the memory card. Card is fine in other cameras. Just switched to a...
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Aug 28, 2010 | Vivitar Vivacam 5399 Digital Camera
I have a Vivitar 5399. I cannot take pictures
move your pictures to the computer and then delete them there (only delete the ones you dont want anymore)
Oct 10, 2009 | Cameras
How can i get a manual for a vivitar vivicam 5399 digital camera?
Go to www.vivitar.com and put in your model number and you can download the manual. I just checked.
Aug 28, 2009 | Vivitar Cameras
Vivitar
My Vivicam 4000 owners manual states that only SD cards up to 256 Mb are supported.
Feb 14, 2008 | Vivitar ViviCam 4000 Digital Camera
Vivitar Vivacam 5399 Digital Camera Logo
91 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
