Question about Spectroniq Portable 7" Widescreen DVD Player
Dead I have a PDV-700, the unit will not turn on by the battery or by the ac plug. What do I need to get this unit fix and what would the cost be to fix the unit?
  • Spectroniq Master
  • 8,457 Answers
The power supply board probally dead,not worth repairing,beacuse the power supply board part and the labors of the Tech. the cost to u could be same amount of money to buy a new one.The new one cost only about $100 dollars.
Posted on May 28, 2010
I need to buy a battery and replacement cord for my son's Duraband PDV-709
Your local Radio shack could help you with a power adapter.
Technical Specifications:
AC input voltage ……120VAC, Output ………9V 2-2.5A Up to 22W
Plug Tip size.......4.0/1.5/12mm
or
Search E-Bay for Duraband PDV-709 they have car or home adapters.
Dec 03, 2009 | Durabrand PDV-709
Where i find ac dc adaptor durabrand portable pdv 705
You should go to a local electronics shop with the old adaptor.
They merely need to match: Voltage in Voltage out Current requirements Plug size Plug polarity (center positive or negative) There is nothing "magic" about the original vendors power adapter.
Oct 06, 2009 | Durabrand PDV-705 Portable DVD Player
NEEDS AC ADP. CHARGER FOR A DURABAN PORTABLE DVD MODEL PDV-705
call alco electroninc at 1800 252 6123 they will tell you where to buy a new battery.
Nov 13, 2008 | Durabrand PDV-705 Portable DVD Player
Car power adapter for portron pdv768
I went to Wal-Mart and purchased a Phillips Power Inverter that provides AC power from any car outlet. Just plug the AC power plug into it and then plug into the lighter plug socket. It solved my problem....It costs $19.99. Hope this helps!
Jun 21, 2008 | Protron PDV-768 Portable DVD Player
I have a 9"durabrand portable dvd player that need the plug in cord
You can buy an ac power charger adapter for your Durabrand PDV-709 here:
http://www.acdapter.com/DURABRAND_PVD_AC_ADAPTER.html
May 04, 2008 | Durabrand PDV-709
PDV-288
I might be willing to sell you mine! The power supply burned up on my unit after having it only 3 months. It would cost me as much to fix as it would just to go out and buy a new one. I can tell you for sure though that I won't be buying this model again!
Dec 22, 2007 | Protron PDV-288 7" LCD Portable DVD Player
MAGELLAN ROADMATE 700 ON THE FRITZ.
I had the same problem with myRm 700, too. Solution : connect your unit into the AC power pack . Turn it on. Then reinsert an address into the unit while plugged into the 110 volt ac wall outlet power supply. You may need to repeat this operation a few times.
Also, used mine in my 18-wheeler using a ac to dc power inverter. It seemed to work everytime. Note make sure the ac to dc inverter you by has enough dc output to feed your Gps all the juice it needs. That ac to dc inverter can be used to run other ac powererd appliances, too.
Aug 30, 2007 | Magellan RoadMate 700 GPS Receiver
Protron PDV 388 DVD Player
Plug in A/C adaptor to ubit and with unit off, see if you can get a voltage measurement from the terminals that connect to the battery. If voltage is present, dead cells in battery. If no voltage present, suspect switching regulator. These units are hard to service due to parts availablity and cost of a replacement unit vs shop labor and parts charge.
Jun 09, 2007 | Protron PDV-388
Spectroniq Portable 7" Widescreen DVD Player Logo
100 people viewed this question
Top Spectroniq Televison & Video Experts
Frank Zabroski
Frank Zabroski
Jayesh Panchal
Jayesh Panchal
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
