Question about Sub-Zero 700TC Bottom Freezer Refrigerator
Drawers not cooling. Staying at 70 deg. Solution?
    Sergeant:
    Champion:
  • 311 Answers
This is not a diy unit for repairs- call in a professional.
Posted on May 28, 2010
Adjusting freezer temperature
My name is Peter, retired Sears Home Services Tech. The freezer temp should be between 1 & -2 Deg. F, the fresh food section should be 35-40 Deg. F. I think you may have other problems if the unit does not hold temp. 70% of my service calls were either Samsung or LG. Samsung should stick with televisions.
Oct 11, 2014 | Samsung RF28HDEDBSR RF28HDEDBSR French...
I have some problem with our machine scotsman mv450 is to long product ice very slowly
Min freeze time 6 minutes and max freeze time 45 minutes. the 6 minutes is with perfect conditions. Example: Cycle time water temp was 50 degrees coming in to the water sump tray from water supply and the Ambient air temp surrounding the machine was a constant 70 deg than the machine should make ice every 10 - 12 minutes.now we know that the water temp from the water source is not going to be 50 deg and room temp will not be 70 deg all the time so the warmer water temp and ambient air temp is the longer it takes to make ice. one thing you wont to check is the water inlet valve to make sure it is not letting water seep through causing water temp not to cool down from running across evap plates. make sure the condenser coil is clean this will slow down production of ice.
Apr 17, 2013 | Kitchen Appliances - Others
Room is warm 86 deg. unit runs, discharge temp is near 70 deg. unit runs for a while, will not bring room temp down.outside unit shuts off, i turn unit off, 1 hour and restart, it does the same.
The unit has a leak and is low on charge (freon) Find and fix leak, then vacuum and recharge...Leak is probably in flare fittings behind unit...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Mitsubishi MS24WN Air Conditioner
Running hot...how doi change thermostat
the normal temp. from 70 to 90 deg cent., if it is in range do not change thermostat.
thermostat range from 92 to 82 so the cooling fan work on 92 and stop on 82 ,check it is written on thermostat.
Mar 23, 2011 | 1993 Acura Legend
I have a 98 cevy astro that i replaced the engine coolant temp sensor and i cleared the code after i started the van and ran it for a bit the code (p0118 engine coolant temp circuit high input ) came back ...
Hello! After you changed the sensor did you also replace the coolant? If so, It is necessary to bleed air from the cooling system or The ECM will set code P0118...If not check the connector wires...Black and Yellow for corrosion and/or broken/loose connections...See resistance to temperature chart...When engine is cold resistance of the CTS is high...when hot resistance is low...This will tell you if the sensor is working properly.............Guru...........Saailer
deg F deg C resistance (ohms) 210 100 185 160 70 450 100 38 1,800 70 20 3,400 40 4 7,500 20 -7 13,500 0 -18 25,000 -40 -40 100,000+
Oct 20, 2010 | Cars & Trucks
Refrigerator (Samsung RS2555SL) quit cooling on both sides. Front panel was blinking at set temperatures (34 fridge side/0 freezer side) but inside was warm. I unplugged for 5 min and ran self-diagnostic...
hello dont know if you have the same model
but this may be worht a look
samsung fridge freezer problems
http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01"> name="allowFullScreen" value="true">http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">
Sep 28, 2010 | Samsung RS2578BB Side by Side Refrigerator
Canon IR 3100cn Copier Error Code E00002-12
E002 Insufficient temperature rise of the fixing unit
0002 The non-contact thermistor fails to
reach 70 deg C within 180 sec after
reaching 50 deg C.
Check on connection of the thermistor, Replace the
fixing unit
To recover from the error: In service mode ( * 2 8 * )
COPIER>FUNCTION>CLEAR >ERR
0003 The non-contact thermistor fails to
reach 100 deg C within 180 sec after
reaching 70 deg C.
0004 The non-contact thermistor fails to
reach 120 deg C within 180 sec after
reaching 100 deg C.
0005 The non-contact thermistor fails to
reach 140 deg C within 180 sec after
reaching 120 deg C.
0006 The non-contact thermistor fails to
reach 160 deg C within 180 sec after
reaching 140 deg C.
0007 The non-contact thermistor fails to
reach 180 deg C within 180 sec after
reaching 160 deg C.
0008 The non-contact thermistor fails to
reach standby temperature (normally
190 deg C) within 180 sec after reaching
180 deg C.
0101 The non-contact thermistor fails to
reach 120 deg C within 300 sec after
power-on.
0102 The non-contact thermistor fails to
190 deg C) within 300 sec after reaching
120 deg C.
Jun 06, 2010 | Canon iRC3100 Printer
I have a samsung side by side fridge, and the fridge side is not staying cool, but the chill drawers are keeping the right temp??? The Model# is RS267LABP
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The chill drawers are probably staying cold because there is a vent to the freezer in the wall for the cold air to seep through.
Nov 03, 2009 | Coffee Makers & Espresso Machines
Loss of temperature control
Is the heater staying on all the time? Most likely cause of themostat trouble is the sensor. Try to find it and measure its resistance at different temps to verify the trouble.
Dec 31, 2007 | Honeywell CT3200 5-2 Day Electronic...
Refrigerators Logo
102 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
John Tripp
John Tripp
Steve
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
