Question about GE JVM1630 Microwave Oven
We need to buy the little plastic part attached to the motor which moves the turntable.
  • GE Master
  • 9,098 Answers
That would be the turntable coupler.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 30, 2010
Turntable does not rotate
Have you check to ensure the motor is running if yes then check the belt to ensure it is still attached to the motor and patter. If not then you will need to re-attach the belt.
Dec 06, 2011 | Emerson Microwave Ovens
My turntable doesn.t work because the little plastic insert is broken.
Are you referring to the carousel ring under the glass tray? Or, are you referring to the turntable coupler in the center of the oven where the tray rests? Both these parts can usually be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and have great service. Prices vary between them, so shop and compare. The first three sites I have listed include helpful exploded view parts illustrations to assist you in locating and properly identifying any parts you may need.
You do not see the turntable shaft in the center of the oven cavity rotating, you may actually have a turntable motor that has failed. The motor is attached to the center plastic piece (called a turntable shaft or coupler) under the middle of the glass tray. The following link explains how to access and replace one:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price range will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
If you have any questions, or require additional assistance, please post back with your MODEL NUMBER. I hope you find this information helpful.
Apr 28, 2010 | Microwave Ovens
Motorized turntable broke
I fixed the problem with my microwave turntable motor without having to replace it. I removed the motor from the microwave and placed it in a small vise. Using a very small flat head screwdriver I was able to pry up the four tabs holding the casing together. You may need a slightly larger screwdriver after that to bend them back out of the way so you can remove the motor cover plate. Carefully take out all the plastic gears and note their position for re-assembly. You will find that the primary gear, at the bottom of the rest of the gears is attached to the motor magnet. It has a shaft that acts as a bushing passing through the center motor magnet. On the underside it is attached to a plastic washer. This is where it breaks. The motor magnet spins free of the gear/bushing/washer assembly. I used JB Weld epoxy to glue this assembly back together and it works like brand new. Note: On mine there were four indentations on each side of the motor magnet which corresponded to little ?bumps? on the underside of the gear on top and washer on the bottom. Place all the plastic gears back into the motor in the correct order, slide on the motor cover plate and use a small cold chisel with a round end and tap hammer to bend the tabs back into place. If this worked for you please let me know ? karlet@bellsouth.net
Aug 15, 2009 | Microwave Ovens
GE Spacemaker microwave turntable makes a grinding noise.
I fixed the problem with my GE microwave turntable motor without having to replace it.
Carefully take out all the plastic gears and note their position for re-assembly. You will find that the primary gear, at the bottom of the rest of the gears is attached to the motor magnet. It has a shaft that acts as a bushing passing through the center motor magnet. On the underside it is attached to a plastic washer. This is where it breaks. The motor magnet spins free of the gear/bushing/washer assembly. I used JB Weld epoxy to glue this assembly back together and it works like brand new. Note: On mine there were four indentations on each side of the motor magnet which corresponded to little ‘bumps’ on the underside of the gear on top and washer on the bottom.
If this worked for you please let me know – karlet@bellsouth.net
Jul 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacemaker XL Model #JVM3660BD001 turntable no longer turns
Jun 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No turntable
Jun 18, 2009 | GE JE1860 Microwave Oven
Sharp R-98STM-A turntable wont turn
Jun 08, 2009 | GE JVM1850 1000 Watts Microwave Oven
Whirlpool otr microwave
Once i opened up the microwave, I found that some kind of capacitor or something (had two wires going to it) had fell down on top of the fan. I had to rig the plastic mounting bracket and re-attach it to a panel inside. That took care of the rubbing noise. It turned out that some one had unplugged the wire that powered the turntable. That took care of that. it seems to work fine now. Steve
Apr 18, 2009 | Microwave Ovens
The turntable on my microwave/convection oven Model R930AW-P doesn't turn. The turntable motor shaft moves freely, but when the turntable is on it and cooking food, the turntable doesn't move.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
We have the full service manual for this oven, and have uploaded it to our site here.
The best place to order Sharp parts is Tritronics.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 05, 2008 | Sharp Microwave Ovens
GE JVM1630 Microwave Oven Logo
102 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
