Question about Nokia 6700 Classic Cell Phone
Bluetooth connectivity fails to load. When selected, a black progress band sweeps back and forth across the bottom of the screen. I can only stop it by pressing the red "call end" button. Can you advise please ?
  • al_smith May 28, 2010
    Hello "nonontech", did the "factory reset" and tried again. It appears to have worked thank you. Just got to re-load all my settings now !! Many thanks.
  • Nokia Master
  • 4,737 Answers
There're two likely causes, 1. Application settings, 2. Firmware corrupted/outdated,
Your first step is to restore the phone to it's default settings, to do this, go to settings, and select "Restore Factory" when you are asked to enter security code, enter "12345" without the quote, and then ok, again confirm Ok, it'll will automatically restart. And check the bluetooth by putting in On (Power on the Bluetooth). If this doesn't solve, you'll need to flash your mobile, i recommend Jaf Box for this model. This will definitely fix the problem.
In rare cases, there's hardware problem related to bluetooth module (bluetooth Ic), but this is your final decision, if the above two measures don't work. I wish you good luck. You can post me in case if you need further assistance.
Posted on May 28, 2010
  • Lebanon Raingam
    Lebanon Raingam May 28, 2010
    You are always welcome. Good luck and thanks for using FixYa.
Netflix will not come on it goes all the way to screen where you pick your choice but when i do it goes to another screen
After making a selection you should get a black screen with some blue balls that alternate from blue to white to show loading progress, that screen should change to the red "Netflix" screen with a progress bar on the bottom to show how much of the movie has been loaded into the streaming queue. Then it will go back to a black screen and the movie should begin to play.
Now the speed to which all of this occurs varies as it is based on your available download bandwidth. Based on the information provided, it could indicate a problem with the Silverlight plugin for your web browser.
Silverlight is a plugin created by Microsoft to allow the streaming of protected content, it is also the plugin that Netflix uses to stream online video.
You could try to uninstall the Silverlight plugin and then reinstall it to see if that works.
Microsoft Silverlight
The link above will take you to the Microsoft website with the current version of Silverlight.
If reinstalling the plugin does not fix the issue, a problem with your Internet connection, a firewall issue or a malware / spyware issue on your computer.
Jan 15, 2014 | Computers & Internet
Black band across bottom of screen
hi,
Is the black band is about one two inch thick have to check the back light section of your lcd tv. All lcd tvs have back light to illuminate the pixels. Two types of back lighting are there CCFL (cold cathode fluorescent Lamp) and LED. In your tv its CCFL. CCFL need high voltage 1000V or above . For providing this high voltage there is inverter stage ( back light inverter). Also there will be 12 or more CCFL behind the lcd screen. If any on of there CCFL failed the there will come a gray bar noticeable only when there is hight light.
There will be two causes for this problem.
1. CCFL is faulty.
2. The inverter transformer driving CCFL is faulty.
You have to check the inverter fist. For conforming which one is faulty do the following.
There is independent connection for every two CCFL from the inverter board. Try interchange the two nearest connection. And watch is the line is shifting or not after every interconnection. You have to try by interchanging all the nearest to connections for CCFL.
If the line shifted then the inverter board is faulty. If the line stays there then the CCFL is faulty. Normally there will be problem with inverter transformer. If the transformer is faulty then you have to replace the inverter board as a whole.
ok
Jun 11, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
My tv was on, the tv went black, the tv was making a soft semi rapid ticking sound, the tv was unplugged for 12 hours then plugged back in. The tv is making the same sound? Suggestions or solutions
The clicking is caused by the relay that supplies AC to the main power supply. It disconnects repeatedly because there is a fault on the output of the main supply or within the supply itself. If this action didn't happen, it could cause a fire or trip your household breaker. Since this is a CRT type set, I would be checking for a shorted horizontal output transistor or a failed fly-back transformer with which this transistor works to produce high voltage for the CRT and the signal that moves the sweep back and forth across the width of the screen.
The transistor replacement with labor wouldn't be terribly costly if done by an honest tech but if the fly-back transformer has failed, it may not be available any more and would in any case cost $60-100 US plus labor. These two parts will often fail nearly simultaneously as the result of one of them going first, then damaging the other.
Nov 12, 2010 | Sharp 32C-240 32" TV
How can i autotune my soney trinitron tv iv lost the manual
Hello
Enter menu, and select the [autotune or auto search] function with the help of Prog+ Prog- and Vol+ and Vol- buttons. After that function highlighted press Vol+ button once and release. The TV will tune and store automatically in its memory, all the transmitting stations at that time, and after tuned the entire band it will finish tuning and will display the first channel. You must select auto tune for this. Not manual tune or fine tune functions. A horizontal bar will run across the bottom side of the screen indicating that the tuning process is in progress, and it will reset three times to zero and will continue tuning. It is due to the auto band selection is done inside the microcomputer of the tv. No other functions will response anymore, till autotune process is completed. Ok.
Oct 19, 2010 | Sony Televison & Video
I can't get a full screen picture black band across top and botto
try adjusting the aspect ratio. on widescreen movies or shows you will still get the black bands on the top and bottom. if you play with the aspect ratio you can sometimes get rid of it
Apr 19, 2009 | Protron PLTV3250 32 in. LCD Television
My lg incite bluetooth does not detect the motorola S9 bluetooth
this took me nearly an hour to figure out, but here goes:
go to "settings icon" - tap "bluetooth" - turn it on - go to "accessibility" tab - make sure your phone has a "name" - then make sure "allow other devices to connect", "all devices" and "other devices can discover me" are selected - then go back to the "general" tab - tap on the "bluetooth manager" link - go to "active connections tab" - click on "menu" at the bottom right corner - click on "paired devices" when the menu comes up - click on "add".
Now quickly put your bluetooth headset into pairing mode and as soon as the device and passkey asking screen comes up, tap on the little windows "find" (or "search") icon next to the "device" field. once your phone detects your headset, it will take you back the device and passkey screen, where the name of your headset will now appear in the device field. all you have to do is input your device passkey.
Now go back to "bluetooth manager" screen, where in your "my shortcuts" tab, your "hands-free connection" icon should be present. if it's not, then click on "new" in the bottom left corner and select the "hands-free/headset setup". On the screen that comes up, select "next" which will take you to the next screen. Here your headset device icon will be present with a small red checkmark beside it. Tap this and your phone will establish a connection with your headset. It will then take you back to "bluetooth manager" - "my shortcuts" screen where your "hands-free connection" icon will now be green with two small arrows beside it pointing towards each other. If you click on the active connections tab, you'll see your headset device icon there. Also, a pair of headphones will pop up on your windows toolbar at the very top.
After this setup, to ensure your phone's security, go back to the "settings" - "bluetooth" - "accessibility" tab. Select "paired devices only" under the Accessibility heading, and deselect "other devices can discover me".
Hope this helps everyone...so far this is the only non-user friendly feature of the phone that I've come across, rest is pretty good and highly customizable.
Mar 20, 2009 | LG Incite Cell Phone
Yellow area on screen
either burn in or magnetic field interference. I suggest moving any speakers away from the tv. if thats not the case, then find a strong magnet, make sweeping motions across the screen with it but dont touch the screen! Keep doing this until the colors change, then "sweep" them with the magnet into a corner and they will mostly dissapea.......r, sounds complicated but worked for me. can be scary so dont try unless sickly despearate or confident.   Hope This helps!
Jan 24, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Toshiba CF2772B New in 1992. Has black band across the bottom
If the pix was good up until this point, I would take the plunge and repair it, even though it may be close to 200 US...accordianman
Nov 11, 2008 | Toshiba 27A33 27" TV
Nokia 6700 Classic Cell Phone Logo
59 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
