Question about Brother IntelliFAX 5750e Laser Fax
Multiple pages the machine is taking in more than 1 page at a time when sending a fax. Is there a roller that needs to be cleaned or replaced?
  • 39 Answers
Actually, when you get more than one paper feeding in at a time, it is almost always the separation pad being worn down. Go here to buy a new sep. pad and tell them Ken from National Cartridge Co. sent you there!
http://www.precisionroller.com/paper-feed-components-for-brother-intellifax-5750e/details_9248.html
Posted on May 31, 2010
Why can't I fax more than one page at a time?
IF IT JAMS OR TAKE ALL THE DOC AT THE SAME TIME CLEAN OR REPLACE ADFRollers and separation pad. TEMPORARY SOLUTION IS use sanded paper gently to give surface of roller and adf pad, moer grip
Apr 23, 2013 | HEWLETT-PACKARD HP 2140 Fax
Paper Jam when trying to send a fax on 4th page
Paper Pick up Rollers get dirty or worn out with the passage of time. Hence, require cleaning or replacement if worn out. In case you find them dirty use a soft, dry, lint free cloth to clean the rollers. Don't use chemicals as they may damage the rubber and plastic. However, if needed, you can use damp cloth or some cleaning liquid such as mild detergent or glass cleaner to damp the cloth.
Lift the top Cover, Locate the roller and clean them. Depending upon the make & model of the fax you have, lift the top cover accordingly and locate the paper pickup roller.
Hope it helps! Good Luck!
CreativeTECH
Aug 01, 2011 | Canon Office Equipment & Supplies
Canon tech support for faxphone L80 --- will not fax multiple pages --- multiple pages are faxed as 1 page
If you have time and small amount of skills do the next:
Open cover of keyboard panel ( pull towards ), then you will be able to see, on fax side two rollers, and on keyboard side one separation assy ( rubber piece grey or black color ), as first aid use mild sand paper and "scratch" on it and clean with alcohol.
Also clean the rollers on fax side, while turning them.
This is only as first aid. If then works, that means that you need to order and replace separation assy. For EU code is HG5-1308-000.
TIP: when you replace sep.assy, also tighten the spring wich holds separation assy.
Jul 01, 2010 | Canon FAXPHONE L80 Laser
The fax takes two pages at once when trying to send a fax with multiple pages
Clean the rubber feed rollers and the separator under them (the area below the feed roller that is supposed to hold the next page in place when the top one is fed.
Sometimes the roller is on the bottom, and separator on the top, depends on model.
Use a lint-free cloth dampened with isopropyl alcohol or at least dampened really sparringly with water + washing-up detergent.
Oct 28, 2009 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Adf sporadically pulls fax/ copy through top
Yes,but the most imported part for dubble feeding is the sepatation pad,this white pad is on the lower part of the docfeeder and work with the feed rollers,fist make sure that pad is clean before you replace the rollers,and then replace the pad.
Jun 17, 2009 | Canon PC-1080F Plain Paper Laser Fax
Paper sticking together when receiving a fax
There is a separation pad under the feed roller,that pad needs to be cleaned or replaced.If you open the fax and remove the cartridge,inside at the back were the cartidge was you will find a roller,cleen that roller.Under the roller there is a strip of rubber-the separation pad.Take a ruller cover it with a cloth and use it to clean the sep assembly under the roller.If the problem pressist the sepparation needs to be replaced.
Feb 22, 2009 | Canon FAXPHONE L80 Laser
Fax uf 590
Pull open the bottom of the operating panel just above the paper tray one inch 1". Clean the small scanner glass with alcohol, it's hard to see. It's just above the first rubber roller at the black base of the machine.
Feb 19, 2009 | Panasonic UF-590 Plain Paper Laser Fax
Panasonic kx-f100 fax prints and sends a page on 2 pages- too big
it sounds like one of your rollers is not making contact with the paper. either the roller is dirty or you need a new one
Dec 08, 2008 | Panasonic KX-FP81 Plain Paper Fax
Fax sending problem
It sounds like you have a few problems. First, the comm error usually means there was a problem communicating with the other fax. This maybe caused by a phone line issue, or a bad connection. You will have to replace you ink but that does not have anything to do with your sending issues. As far as the pages getting stuck, the separation pad under the top cover should be cleaned. If you lift up the cover where you load your pages to be sent, and look in there(on the backside of the keyboard)you will see a flat square rubber piece. Clean it thoroughly with a rag and some rubbing alcohol. Also clean the rubber rollers as well. Good luck John
Jul 03, 2007 | Brother IntelliFAX 1840C Plain Paper...
Brother IntelliFAX 5750e Laser Fax Logo
131 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
