Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
The Frigidare 20.5 appears to be operating normally but will not get colder than 20 degrees?
  • Frigidaire Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerThe Frigidare 20.5 appears to be operating - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 28, 2010
I have a small magic chef freezer that opens from the top. I has about 3 or 4 cu. ft. of freezer space. Lately a buzzer has been going off every 15 or 20 minutes. It buzzes for about 5-10 seconds and then...
With the time as the compressor gets old the buzzing will increased, its not a bid deal, just set the thermostat to 1 during the winter, saves you energy and give the compressor more time to rest.
Sep 28, 2011 | Magic Chef Chest Freezer MCCF5WBX
I have a Frigidaire model GLFU206FWA upright freezer. The temperature control won't go above 10 degree F. This causes freezer burn on some foods after a period of time. Is there a way to regulate the...
Good day,
Manufacturers of freezers do not give the option of running the machine much above that temperature. Normal operating temperature for a freezer is about -2 to about 8 above F.
Otherwise people could accidentally set the temp too warm and cause a loss of food.
Some appliance parts houses carry universal thermostats that could possibly cover the temperature range your looking for, but 30 degrees is far to warm to preserve frozen food safely.
Jun 21, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
This unit has a crank case pressure regulator and it is icing up I am unsure of the correct charge becauase the data plate is gone; however I did adjust the cpr valve to where i had a svt of -20 and this...
Freezers usually have a super heat of 6-8 degrees and as it approaches the set temperature, it can be as low as 4 degrees. you will have to 'babysit' this and adjust as you go but it has to be done in extremely small amounts. the crankcase pressure regulator basically keeps the compressor from being overloaded from high pressure like from after a defrost or the door being left open.
Apr 29, 2017 | Hussmann Commercial Freezer DCCG-12
KFS220RHY Is this freezer good for frozen foods as well as ice cream storage
Good day,
No reason it wouldn't work fine. It should be noted that if your in a grocery store the freezer sections used to store ice cream are separate from those for normal produce.
The reason is the ice cream is normally kept 15 degrees colder.
However, this unit has an adjustable tstat that should get you around the ideal 0 degree range.
As well, it's designed to be rugged not as energy effecient as a standard domestic freezer.
May 07, 2010 | Kelvinator KFS220RHY Freezer
Temp Control
Hi!!
The higher the number, the colder the setting.
Rate this post, Good Day!!
Apr 26, 2010 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Hotpoint ffa91g fridgefreezer wont go below -5
Good day,
If your talking fahrenheit, that is well within it's limitations.
Why would you want it any colder. -5 is fine. 0 to 4 is considered normal.
R134A runs at -15 degrees. It is considered normal for the box (any box) to run 10 degrees higher than the refrigerant.
When R12 (freon) was used it ran at -21 degrees, and could maintain a box at -10, but those days are long gone.
Jan 05, 2010 | Freezers
Normal Operating pressure for true 2 door Freezer R404A Room Under 80 degrees F Box at -10 degrees F
The pressures depend, somewhat, on the expansion device,i.e. a TXV or Cap Tube. Take a pressure reading, then convert it to a temperature. The evap temp should be right at 10 colder than the box temp. Remember, heat flows to cold so the evap has to "Lead the Load" in order to cool. In many cases, the condensing pressure is usually ambient temp, plus 30, then convert to a pressure. These are general accepted practices that have been used for many years.
Hope this helps
Jul 11, 2009 | True 49 cu. ft. / 1388 liter Commercial...
Running High @ -10 C and should run at -20 C on coldest setting
1. Make sure the sealing gasket is making good contact all the way around. It's pretty easy to lose 10 degrees. If it is a magnetic seal on the door gasket, it may not be sealing all the way around.
2. If it is staying that cold, everything is working well enough. Maybe you need a little gas in the compressor. Time for the service guy.
By the way, is your unit speced to be that cold full of supplies? Is the door opened frequently? minus 35 is pretty cold.
Mar 11, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
248 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
