Question about Sony Handycam DCR-VX2100 Mini DV Digital Camcorder
My PC Does not recognize it
When I plug in my camera using an iLink (4 pin to USB), my PC does not recognize the device. Do I need a driver?
  • tooferone Apr 08, 2008
    Yes, it is in VCR mode. FYI I have Windows XP Professional. I think maybe this version of Windows does not recognize the camera, or maybe because I'm using a 4 pin to USB firewire instead of a 4pin to 4pin. Any thoughts?
  • 78 Answers
Is the camera in VCR/Playback mode?
Posted on Apr 08, 2008
SOURCE:
I have a mini DV SONY DCR-PC9E PAL camcorder and i need to copy my tapes on my WINDOWS 7 Ultimate 32bit. Don't Have the Driver, and my computer is not reading the USB cable connected from the Camera to the...
I believe this camera has a firewire/iLink connector.
Using a firewire cable will allow you to not only transfer videos, but will also let popular video editing software control your camera for ease of use!
As for the driver, your camera is specific to latin america.
You might try to download this program which is a licensed sony product, but will be in spanish. It may have drivers built in, which will allow your pc to properly recognize your device in other programs.
Feb 23, 2011 | Sony Handycam DCR-PC9E Mini DV Digital...
The LCD screen has suddenly stopped working. The Handycam is a DCR-42,purchased in September 2005 and sparingly used. I have given it to Sony Service Center at Arabinda Sarani, Kolkata, India. How do I...
See this, it answers to most of your queries:
http://www.fixya.com/support/t5921707-convert_mini_dv
The CD that came with the camcorder is not compatible with Windows 7. You have to go to Sony's site and get an update. See if the following link is useful:
http://www.sony-asia.com/support/download/415262
I think USB streaming is not supported in Windows 7, so probably iLink is the only option available to you, which anyway is better than USB in terms of less frame drops and capture of DVD quality. The camera has 4 pin ilink port. Check whether you have 6-pin port or 4-pin port or both type of ports on your computers. Laptops generally have one 4-pin port. Desktops can have more than one iLink ports and can have both 6-pin and 4-pin. 4-pin port would look exactly like the one you have on your camcorder. You can find a photo of 6-pin ports at
http://en.wikipedia.org/wiki/File:IEEE_1394_Firewire_PCI_Expansion_Card_Digon3.jpg
If your both the computers have at least one port with same number of pins, then you can use one cable for transferring to both.
You will need an ilink cable with 4-pin male to connect to camcorder and either 6-pin male (http://cgi.ebay.in/4-Pin-6-Pin-DV-iLink-Cable-/400180203017?pt=LH_DefaultDomain_203&hash=item5d2c994e09)or 4-pin male (http://cgi.ebay.in/4-Pin-4-Pin-Firewire-IEEE1394-DV-iLink-Cable-/400180205113?pt=LH_DefaultDomain_203&hash=item5d2c995639) to connect to the computer side.
Dec 09, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
No driver for sony handycam trv30 using windows 7; can't find a driver that will work with firewire 1394
usb streaming is not supported by your new windows OS,reason usb driver is not available. for ilink or ieee1394 connection it should be a plug-and-play connection. no setting in the camera enables or disables ilink output and an ilink driver for the camera is not needed to support this connection (not unless you need to update or reinstall your ieee1394 device driver to get it to work). check this solution link: http://www.kb.sony.com/selfservice/microsites/search.docmd=displayKC&docType=kc&externalId=C86798&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=157560925&stateId=1200%20157576924
hope you can get to establish connection.thanks:)
Aug 25, 2010 | Sony Handycam DCR-TRV30 Mini DV Digital...
Sony Handycam DCR-HC42 Mini DV not recognized by Windows 7
win vista and win 7doesn't support usb streaming. the usb driver for this model would not be compatible with your computer's OS. although, you were able to download PMB still this wouldn't work, it's basically an alternative software that you can use with the newer OS. still the device driver would not be installed. and you would get a message that "ilink connection is not detected". the reason you get that is bec the camcorder and the software is intended for use with the dv (ilink or ieee1394) connection. so if your computer has an ieee1394 card and you have a compatible ilink cable,then your good to go,it should be a plug-and-play connection (no drivers required). all you need then would be a video capturing software (like win moviemaker) to transfer videos from tape to PC. hope this helps. thanks :)
Mar 28, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
DO I REALLY NEED A FIREWIRE CARD?
If your camera is Firewire, iLink,or IEEE 1394, then you need Firewire support or a Firewire card.
If your camera has a USB symbol, or says USB anywhere in the manual, you can use USB for the functions it allows.
There is no USB to Firewire or Firewire to USB without the use of an advanced device.
May 12, 2009 | Acer Aspire M3201 Phenom X3 8650 PC...
Unable to export video from camcorder to PC
Get a 4-pin Firewire cable. Plugs in just below power plug slot. What plug you need on the other end depends on your computer. You can get Firewires in 4 to 4 pin; 4 to 6 pin, and 4 pin to USB. My laptop is configured to take a 4 or 6 pin Firewire but my desktop only has USB. I transfered using 4 to 4 pin and it worked great. No drivers, no discs needed...at least with Vista. As soon as I plugged in the camera, I was asked to whether I wanted to transfer from biginning of tape or at currenty location. I chose from the beginning and the camera automatically rewound and strated to transfer to the PC. I don't know if it would work same way with 4-wire Firewire to USB but assume it would. Cables around $35 but I purchased at Circuit City for the going out of business discount. I also bought some SD cards so I can take snapshots and transfer them too for print.
Get a firewire and you should be fine.
C
Jan 13, 2009 | JVC GR-D270 Mini DV Digital Camcorder
Unable to use firewire Sony handycam DCR-HC 54E (mini DV)
Anyone try this on Windows XP? Apparently firewire doesn't work with Vista.
Dec 10, 2008 | Video Cameras
Yes, it is in VCR Mode...
You need a 6 pin to 4 pin firewire cable, friend :) It should work with one of those.
Apr 08, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
Canon ZR800 MimiDV Camcorder
You cannot connect a DV cable to a USB port. These are two incompatible standards. DV is also called Firewire, iLink or IEEE1394. You PC must have that kind of port for you to transfer your video from the ZR800 and you will need a DV (iLink/Firewire) cable. You cannot use USB cable they will not work. Check www.MyCableMart.com if you want an example. Most new PC come with 1 or 2 iLink/Firewire/1394 port. If you PC does not have an iLink/Firewire/1394 port then you will need to install a iLink/Firewire/1394 card (see http://www.usbfirewire.com/Parts/rr-fw-byt.html) for more information.
Aug 13, 2007 | Canon ZR800 Mini DV Digital Camcorder
Sony Handycam DCR-VX2100 Mini DV Digital Camcorder Logo
188 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
