Question about Panasonic Audio Players & Recorders
Error f61 in panasonic sht540
I have this problem since yesterday when ever i turn it on its dose but then just give error code f61 will b greatful for soloution thanks
  • 4 Answers
The abnormalities an output or power supply circuit of POWER AMP.
In normal operation, when DCDET2 goes to "L" (Low) (Not during POWER OFF condition), F61 appears on FL Display and PCONT goes to "L" (Low).
This is due to speaker output has DC voltage or fan is not working.
Posted on Mar 02, 2011
Turn on dvd panasonic sc-ht440 the display see me f61
Hi, F61 is and amp error code. probably needs an output ic. could be a shorted speaker or bad cooling fan. Disconnect all speakers and turn it on. if the fans run and it still displays f61 then odds are very good an amp ic is bad.'''Hope it helped.
Have a nice day..
Feb 24, 2011 | Panasonic SC-HT440 System
When i turn on my receiver f61 code comes on then it shuts off how do i fix it. Panasonic SC-ht650
Many things can cause the error code f61 on a Panasonic.
Most of them need a service tech to repair. Output IC or voltage regulator....
The one thing you may be able to check is the cooling fan, it should turn on hen the power button is pushed. Make sure it spins freely.
Most often it is the output IC
Feb 11, 2011 | Panasonic Audio Players & Recorders
AFTER A FEW SECONDS MY SYSTEM SHUT DOWN AND SHOWS ME F61 ON THE SCREEM
  1. AFTER A FEW SECONDS MY SISTEM SHUT DOWN AND SHOW ME F61 ON THE SCREEN
Oct 25, 2010 | Panasonic SC-AK300 CD Shelf System
F61
That code means the audio amplifier IC´s are dameged and need to be replaced
Jan 23, 2010 | Audio Players & Recorders
F61 code error
Change the audio amplifier IC are damaged that´s the mean of that code
Sep 06, 2009 | Panasonic SC-AK640 Shelf System
My panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Jun 22, 2009 | Panasonic sa-ht930 Home Theater Audio...
SC-BT 100 Error Code f61
Had the same problem. Found that the code refers to the cooling fan. Could be that the fan is dusty or not running when the system starts up. I removed the fan with the two screws and reseated the plug. Make certain that the short, black wire (that seems to go to nothing) is securing the plug to the board.
Dec 24, 2008 | Panasonic SC-BT100 Theater System
F 71 error
I work at an authorized Panasonic repair center and I think the error code you have may be an "F61" not an "F71".
I have never seen an "F71" so I looked it up in several Panasonic service manuals and could not find an "F71".
The "F61" error is an amp or power supply failure. If this is the error code you are getting, try these two things first.
1. Disconnect the speakers and then turn it on.
If the unit turns on without an error code, you have a bad speaker.
If not, try step 2.
2. Resetting the unit could help, but it is unlikely. Unplug it from the wall outlet for about an hour and then plug it back in. This will reset the microprocessor.
The "F61" error It is a common problem with many different Panasonic receivers.
Your best bet is to take it to an authorized Panasonic service center.
The repair on this type of failure can cost anywhere from $75 all the way up to and over $200, it just depends on the exact problem that is causing it.
If you have a shorted output amp IC it can be on the costly side because some of Panasonics amp IC's cost over $100 just for the part.
If you are a technician and need help troubleshooting it, please give me the model number of the unit and I can tell you of several different things to check.
If you are not a technician with good soldering skills and the proper equipment, there is really nothing else you can do to fix this unit.
You must decide if the cost to repair it is worth it, compared to the cost of a new unit.
If you decide to purchase another unit to replace this one, let me know what type of unit you are looking for and I can advice you on picking out something a little more reliable.
Panasonic makes great car stereos, some of the best. But the home stereo equipment they make is really not up to the same standard. I have been repairing them for over 17 years and I know them very well. For the same price range you can do much better with another brand.
I hope this helps you to either fix this, or to make a better informed decision o what to replace it with. If so, a good rating would really be appreciated.
Thanks, and have a great day,
Dave
Jun 21, 2008 | Panasonic Audio Players & Recorders
How do I solve Panasonic SA-HT800V error code F61?
unplugged a Panasonic HDTV plasma for four minutes, plugged back in and Now the DVD does not work.
How to reset?
Aug 28, 2007 | Panasonic sa-ht800V Home Theater Audio...
CODE F61
F61 tells you its a power source problem according to the manual. to all F61 error it is very likley that the str470-050a reg legs desolderd and have broken away from the main body of the regulator giving you the f61 and shut down.
Jan 12, 2006 | Technics SCEH790 CD Shelf System
708 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
