Question about Whirlpool Washing Machines
Cabrio washing machine gets stuck with 43 minutes remaining in wash cycle then flashes an f fault
SOURCE: washing machine not working
I just had the same problem. In my case, a pen cap was stuck in the impeller of the drain pump and prevented it from working. To access the drain pump remove the lower kick panel on the washer by removing (3) Torx drive screws. Make sure you get the water out of your tub before working on the pump or it will spill out on the floor. The pump is front & center. First check the clean-out filter for blockage by turning the big knob on the front of the pump. If that doesn't appear to be the problem, you can take the pump out by removing (1) screw and disconnecting (2) hoses and the electrical connector. The pump itself consists a white housing and a black motor assembly. Remove the motor assembly by removing (3) screws. This is where you will see the impeller and and item that may be preventing it from turning. Besides dealing with the water, the most difficult part of repair is reconnecting the hoses using the hose clamps. Best of luck! RDam
Posted on Jun 29, 2007
  • 209 Answers
SOURCE: bosch max wfl2000 washing machine
I am a recently retired appliance engineer of 20 years sounds like a faulty cold supply, or just no water getting to machine, if water supply ok check the water solenoid, check for open circuit just try that to start with, hope this helps if so rate me please
Posted on Sep 09, 2007
  • 1294 Answers
SOURCE: Hotpoint WD420 - Stuck in wash cycle
Suggestion: Plug off the wall first. Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Check out user's manual. Good luck. Also check if your inlet into the machine is not clogged.
Posted on Oct 01, 2007
SOURCE: Why is the fault F18 error code on my bosch washing machine flashing?
F18 is a drainage fault.
The appliance has a set time to drain if it doesn't drain within that time F18 appears in display
Diver 1
Posted on Feb 08, 2008
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
My whirlpool cabrio washer doesn't work, I ran diagnostic test and I get a series of lights flashing but don't know where to find the code bases on the pattern of lights flashing.
go google and type in -- fault codes for whirlpool cabrio washing machine --- and there will be a pdf version for down load
or you can go google and type in --workshop manual for whirlpool cabrio washing machine --- and there will be a manual in pdf version which will have trouble shooting section in it with the codes as well
Oct 15, 2015 | Whirlpool Washing Machines
Why is my washer stuck in the spin cycle
hi
this might be too obvious but did you try to unplug the washer for at least 5 min to completely reset the computer in the washer ?
Jun 08, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
OL before spin cycle starts
What is the complete model number of your unit?
Dec 04, 2012 | Washing Machines
Flashing f code
Hi, "F" Variables (F4 to F16) (Electrical Problem) Select PAUSE/CANCEL twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains, call for service.
Oct 04, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My Cabrio washer is showing a 5d error and not spinning or draining well. What is the problem?
The troubleshooting page in the owner's manual says: 5d "Sd" Suds Detected - Did you use regular detergent? Regular or hand-washing detergents are not recommended for this washer. Use only High Efficiency (HE) detergent. Did you add too much detergent? Always measure detergent. Follow detergent manufacturer's directions. If excessive suds are detected, the washer will display this code while running a suds reduction correction routine at the end of the wash cycle.The susds reduction routine removes extra suds and asures proper rinsing of your garments. If te code remains and the wash cycle dial is flashing after the recovery routine has stopped, re-select your desired cycle using cold water. Press start. Do not add detergent.
Sep 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio model wtw6200sw0 serial number ct3471269 type 581, it has an "F" on the screen, it stalls out when it is washing as if the motor gets stuck and then it flashes "F"
Sounds like a motor problem , F is for fault often a number with it , this is a fault code , refer to your hand book for explanation of these.
Nov 09, 2009 | Whirlpool WTW6400SW Cabrio Washer
Stuck timer
clean the metal moisture sensor with rubbing alcohol they are located on the grill inside the dryer on the front. or, the vent to your house is blocked some how, call someone to clean it.
Feb 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Hoover 1300 washing machine
hi there this is a common fault you will need to replace the control module and selector switch/timer
Dec 01, 2007 | Hoover H130E Front Load Washer
Washing Machines Logo
41 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
