Question about Hayward S220t Top Mount Pro Series Sand Filter 22" Tank Include Top Mount Valve
CLEANING YOUR POOL WHAT ARE THE PRECEDURES OR SETTING THAT YOU MUST DO
  • 640 Answers
Your users manual will walk you through step by step instructions for getting these pool filters running properly. In addition to the filter, you will need to make sure that you have the proper chemicals and a powerful automatic vacuum for your pool.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
Posted on Sep 02, 2010
Got e90 error filter pump not working,noticed water not in lower clear hose called intex got new pump unit hooked up,bled air ran it still no water in hose What can i do, still under warrenty
Call Intex and follow up with their warranty precedures to fix/replace. Dont do anything that would void the warranty, atleast until they say they wont fix/replace it.
Jul 29, 2015 | Intex Pool & Spa
Tip
IRobot Mirra 530 Setup
Setting up your Mirra 530 is easy!
  1. Use the power supply at least 12 feet from the pool
  2. Plug the cable into the power supply
  3. Place your Mirra in the pool, rocking it side to side to release air
  4. Once Mirra has sunk to the bottom, plug in the power cord into a grounded outlet
  5. Press the "Clean" Button on the power supply.
Mirra will start the cleaning cycle!
on Sep 17, 2013 | iRobot Mirra 530
Tip
IRobot Mirra 530 Tips & Tricks
Tips from iRobot Resources:
Run Mirra only when in the water.
Mirra has a very strong motor system that needs to stay cool for optimal performance and life. Your pool water around the motor helps keep it cool during operation. Therefore Mirra should not be run outside of the pool due to the risk of overheating the motor.
Choose the correct filter canister.
Use the Large Debris Filter Canisters when the pool contains a significant amount of large debris (leaves, insects, etc.) and when the pool is opened for the season or cleaning during the Fall. The Fine Filter Canisters are ideal for filtering small debris such as algae, sand, silt and bacteria and for regular pool cleaning maintenance during the peak of your pool season.
Keep Mirra working at peak performance.
Mirra uses the powerful force of water pumped through its filter to clean and circulate pool water and to propel itself around your pool. It pumps and filters more than a gallon of water every second! Clean the filter canisters regularly by removing them from Mirra, emptying its contents and hosing it out. Keeping the filter canisters clean will ensure optimal cleaning results and strong pump suction.
Allow the motor to cool before removing the robot from the pool.
Mirra's power supply has an automatic timer that shuts Mirra off after each cleaning cycle. Wait 20 minutes before removing Mirra from the pool to allow the pump motor to cool. Turn the power supply off and unplug it from the electrical outlet before removing Mirra from the pool.
My aquabot keeps trying to come out of the pool
Aquabots are interesting little robots! They're made to clean the entire surface of the bottom of the pool, and in regards to cleaning the sides, they are programed to climb walls, but once they reach the surface the programming recognizes the specific angle of the top and sends it back down the wall. Normally an Aquabot should never leave the pool. It should reach the surface and go back down the wall to continue cleaning. Good luck!
Pool Remodeling in Clearwater FL
Jul 17, 2014 | Aquabot In - Ground Robotic Pool Cleaner
Sticker wore off on the filter. which button backwashes? the pool is about to overflow.
b> VALVE SETTING FUNCTIONS OF VALVE POSITIONS FLOW DIRECTION THROUGH VALVE FILTER PUMP - TOP - THROUGH FILTER - BOTTOM - RETURN For normal filtration and vacuuming pool through filter. BACKWASH b> PUMP - BOTTOM - THROUGH FILTER - TOP - WASTE For reversing flow for cleaning filter. RINSE b> PUMP - TOP - THROUGH FILTER - BOTTOM - WASTE For initial start-up cleaning, plus resetting filter bed after backwashing. WASTE b> PUMP - WASTE For vacuuming directly to waste, lowering pool level/draining pool. CLOSED b> NO CIRCULATION PAST PUMP PORT For shutting off all flow to filter and pool. RECIRCULATE b> PUMP - RETURN For bypassing filter, but circulating pool water. May be plumbed for "off-system" pool water access. Ideal for Jet-Air® fittings. WINTER b> VALVE NOT IN USE
Ifthis answer does not fix your problem, please comment with additional detailsprior to rating the answer. Positive feedback is appreciated once your problemis solved! Thank you.
Aug 28, 2011 | Hayward SAND FILTER, PRO SERIES
Self Cleaning pool problems
I shork pool three days ago and still blue green what do I do I need the pool for tomorrow night
Jul 14, 2010 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
What setting should I have my Hayward Sand Filter system on when I am vacumming out my pool?
Your pool filter should be set on "filter" for normal vacuuming. If you have a heavy debris load or an extremely dirty pool, you might want to vacuum with the "waste" setting, if your filter has one.
May 20, 2010 | Hayward SAND FILTER, PRO SERIES
How do i drain my pool with a hayward variflow pump?
To Flush out the filter with the backwash setting. The backwash setting releases trapped particles from the filter back into the swimming pool. You may need to alternate between the rinse and backwash settings until the water runs clear in order to unblock your filtration system and flush out clogs. To Rinse away dislodged items from the backwash setting. The rinse setting flushes clean water through the pipes and carries away any particles or clogs freed during the backwashing. To Drain the pool select waste on the multiport valve. This sends the water directly to the drain rather than back into the swimming pool. Close the filtration equipment and stop the pump with the closed setting. You should only use the closed setting when you turn the pump off. This function allows you to remove the strainer basket, clean the filter tank and perform other swimming pool maintenance on the filtration system.
Aug 08, 2009 | Hayward 1.5 Hp Northstar High Performance...
Hayward S220t Top Mount Pro Series Sand Filter 22" Tank Include Top Mount Valve Logo
122 people viewed this question
Top Hayward Garden Experts
Dennis Key
Dennis Key
john h
Are you a Hayward Garden Expert? Answer questions, earn points and help others
