Question about Maytag Neptune MAH5500B Front Load Washer
Od litght is on but door is closed - Maytag Neptune MAH5500B Front Load Washer
  • 10,319 Answers
OD Opened Door not sensed by machine control board Machine control board did not see the door open prior to the beginning of a new wash load. 1.Open and close door, then restart washer. 2.Check wire connections in harness leading from machine control board to door lock mechanism.
3.Check door monitor switch for welded contacts.
4.Check inputs and outputs at machine control board.
Posted on May 29, 2010
Od error code
The Neptune Od code will come up when the unit does not see the door opened before starting another cycle following a completed cycle. Simply opening the door and closing it again will remove this code until the same incidence happens again. So if you are looking to rewash a load of cloths you must first open the door then close it before you can start the machine over. Pleazer Appliance...
Apr 13, 2014 | Maytag Neptune MAH5500B Front Load Washer
My front loader washer is having the error code od and will not start. What does this mean and how can I fix this?
OD: Opened Door not sensed by machine control board. in this case the lid switch needs attention. or washer door. hope this helps ! 1.Make sure door is closed. Check for loose wire connections at switch and/ or machine control board. .Check for failed door monitor switch. good-day !
Nov 14, 2011 | Maytag Neptune MAH5500B Front Load Washer
Hi! I have a maytag and it gives me OD error and it doesn't wash. As I push the button it gives OD on the digital screen. What should I do?
'OD' could stand for 'open door. If so there is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 04, 2011 | Maytag Washing Machines
I have od on my control panel what does it mean
The OD "fault" code on the display means "OPENED DOOR". This does not mean the machine thinks the door is open, but it has not recognised that the door was opened prior to starting a wash cycle. This could be because you filled it, then turned it off before turning it back on to run the cycle. Often you can clear this "code" by simply opening and closing the door again and starting the wash cycle as normal. If this doesn't work then there may be a fault in the door lock switch or the control board.
Hope this helps.
Regards,
BElectric
Dec 01, 2010 | Maytag Washing Machines
Washer won't start. Display shows "od"?
od is an open door error if the door is closed then you would have to replace the door switch or the wiring that goes to the door switch first try to open and close the door and make sure it seats properly in the small hasp type holder if the error code still persists then check the wiring to the switch and if the wiring looks like everything is connected well then you would have to order a new door switch i hope this helps in your appliance situation and please remember to rank this solution if you have any more questions please message me back. Have a great day
rickead1
Aug 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
Won't start/"od" displayed
Yes, OD is a open door error code. You may need a new door latch assembly. pn 22002262.
Jul 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Hi! getting od error and waher will not let me start any cycle
Hello, the "od"error you getting means the control did not detect that the door was opened between washes. Try opening and then closing the door again and if the error message is still present, there may be a problem in the door switch mechanism, the electronic control or the wiring between the two.
Thanks
Jun 05, 2010 | Maytag Neptune MAH6700A Front Load Washer
I have maytag neptune top load. when i push button to start load od comes on display
od refers to open door,
you may have lost your magnetic door switch
or it may not be working properly,
but for whatever reason the tha machne will not do anything until that door is sensed closed
go to
www.appliancepartspros.com
type in your model number look in the lid section
you will see the part you need
Oct 22, 2009 | Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
112 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
