Question about GE GSS22JEPCC / GSS22JEPWW / GSS22JEPBB Side by Side Refrigerator
I am having a similar problem as other with my GE GSS22JEPH SxS fridge and freezer no longer cooling properly. I've cleaned the condensor and everything I could get to back there and have taken the cover off the back of the inside of the freezer to find the coils are completely frosted over. From what I gather this is a defrost heater problem, can anyone give me the part number for the defrost heater for my model?
SOURCE: Jenn Aire Side by side Fridge side luke cool. Poor Cooling
you have a defrosting issue
Posted on Apr 20, 2008
  • 15 Answers
SOURCE: Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Posted on Feb 03, 2009
SOURCE: ge model gsh25jfrfww not cooling just clicking
Replace the main board on the back i got the part for $130 at a wholesale parts store
Posted on Mar 06, 2009
  • 358 Answers
SOURCE: Cant find defrost swicth on NEC fridge freezer
The defrost timer should be inside the refrigerator where the cold control is.
Posted on Apr 23, 2009
jumptrout51
  • 3361 Answers
SOURCE: Frost free failure on a GE fridge. Removed access panel to freezer section to find evaporator coils crusted in frost. Cannot locate defrost timer and cannot locate any repair manuals online. I'm not w
The defrost timer is electronic and built in to the main control board on the rear of the box.
The defrost heater and defrost thermostat are the most likely culprits on this brand.
They are in the freezer above and below the coil.
They usually come as a set.
Posted on May 24, 2009
GE side by side refrigerator model GSS22JEPD freezer ices up.
remove the freezer shelves and remove rear inside panel in freezer,under the evaporator located here theres a heating element,it has probably opened up and can no longer heat,this is a very common problem with g.e. SxS refrigerators,replace it by unplugging unit,then remove 2 screws holding heater bracket and unplug heater and replace g.e.heater part # is WR51X10101
Jun 16, 2012 | GE Refrigerators
I have A LG SXS Fridge. The Freezer is fine the fridge is not cold. I have read that the damper door might be closed. How do I find the damper door?
The damper is between the fridge and freezer section.
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 31, 2011 | Refrigerators
I HAVEA GE SIDE BY SIDE, THE FRIDGE AND THE FREEZER ARE ONLY COLD IN THE BOTTOM HALF, FROST BUILD UP IN THE FREEZER, BOTTOM HALF,
HI you have a bad defrost heater, located in the freezer behind the rear panel at the bottom, the part cost around $50-70.00.
Sean
Mar 28, 2011 | GE Refrigerators
Refigerator is not cooling properly. Temp
Refrigerator or freezer is not cold enough check this part:
* Check the temperature setting
* Assure that there is enough room for air flow in the refrigerator or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condensor coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
Mar 28, 2010 | GE Profile Stainless Bottom-Freezer...
GE SXS Fridge/Freezer
if the fan in the freezer compartment is not running theres a problem.
verify power to the fan motor, if present replace fan motor.
if not hopefully theres a wiring schematic/diagram so you could trace that circuit back to the control board and verify whether thats bad or not..
WR55X10942 - BOARD ASM MAIN CONTROL
generally though if the fan by the compressor is running the fan in the freezer should also be spinning and have power..
by the way, it states in the parts listing that it is a dc motor
WR60X10074 - Motor DC Evaporator Fan
hope this helps,
best of luck,
ttfn
Oct 27, 2009 | GE GSS20IEP Side by Side Refrigerator
Can't find refrigerator coils/ cooling issues
There're two coils ,the condenser coil wich you already clean (also make sure the condensing fan motor works properly and the fan blades are also clean).The other is the evaporator coil wich is located inside the freezer behind the back wall cover.
Apr 21, 2009 | Refrigerators
GE model TFX22R ice maker problem
First clean out the condensor coils. If you have pets it should be done at least 3 times a year. The other possible problem is if the gasket in either the fridge or freezer is worn out or has a gap it will not cool properly. Check that the fan underneath the unit by the condensor coils is running when the compressor is . Some smaller refrigerators have only condensor coils on the back and no fan. These units should have room for air flow on top and sides not built in flush with cabinets. Buy a thermometer for both the fridge and freezer compartments. You run the risk of food poisoning if the fridge temp can not be kept below 40 degrees. Freezer temp should be able to keep at least 0 - 5 degrees. (Ice cream is a very good indication of proper temp. It is the first thing that melts. Ice maker is a close 2nd.)
If these things don't work call for repair. Don't risk losing all your food!
Jun 24, 2008 | Maytag MSD2756G Side by Side Refrigerator
GE GSS22JEPCC / GSS22JEPWW / GSS22JEPBB Side by Side Refrigerator Logo
85 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
