Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
Just hooked up and LED reads REM off
I cannot get it to work
    Top Expert:
  • Raypak Master
  • 6,514 Answers
Go to set up menu and turn remote to off
Posted on May 25, 2016
URC-7140 i cant set up to my satelite receiver
go to www. remotecodelist.com and download . However you must test the rem.control for to see if working. Use camera digital turn ON, AND point at the rem.control press any key, ( see the picture) you must see the LED i.red ON, if NOT open the rem.control for cleAN the keypads, from grease, dirty, etc, and try again.
Feb 28, 2013 | Televison & Video
I cant connect my sony RM-VLZ620 to my uverse cable box
you can read very well the instr manual coming with the codes. There are some alternatives for to get the properly codes. Example, there in the manual automatic research, you must to press certain keys, by that reason you must read carefully the owner manual and try again.with the another function.
Of course you can test the remote control for to see if working,. Get some digital cameras, point the rem.control to the camera and the camera will be on see the diagram, press any key from rem control and see if the LED infrared is ON, if NOT open the remote control and clean the keypads from dirty, gease
Feb 27, 2013 | Sony RMVLZ620 Remote Control
Pyle pla2170
The power cable and the rem cable need to have different power sources. The best thing to hook the rem. to is a power antenna wire, or if you don't have a power antenna, you'd need to hook it to the ign. or accessory wire.
Jul 31, 2009 | Pyle PLA2180 Car Audio Amplifier
1999 Ford Windstar Rear Light/REM issue ??
How would i be able to get a manual for my 1999 ford windstar van?
May 21, 2009 | 1999 Ford Windstar
No power to amp
you need to hook up the rem wire, that runs from head unit to amp its usaully a blue wire on the head unit and there should be a rem input near where the power leads are on the amp
Mar 21, 2009 | Kicker ZX400.1 Car Audio Amplifier
How do i set this up in my home
What is the REM (remote I assume). The second hot wire other than the red is usually yellow. Is your REM wire yellow. Also, don't forget to put a fuse in the "positive" side of the circuit. Keever
Mar 03, 2008 | Bazooka EL2150 Car Audio Amplifier
Blowing fuses
you may have the rem wire hooked up to the yellow 12v battery wire located on your harness. try yellow to yellow and if your rem is not working correctly when is hooked blue to blue put in on the red ignition wire located on your harness. should solve the problem. or return it
Mar 02, 2008 | AudioControl KVT-911DVD Car Video Player
Nothing from amp
The RCA "plugs" should be in an OUTPUT of the radio (sometimes they are INPUTS, like for an MP3 player..). Go to Sears or somewhere similar and buy an inexpensive Multimeter. Set it to DC volts and place the black lead on the GND termunal of the amp. With the red lead on the BAT terminal you should read roughly 12 volts always. With the car running and radio on, place the red on the REM terminal and again you should see 12 volts. If not it's the wiring. If the voltage is 12 on both then the amp is likely damaged.
Sep 01, 2007 | Kenwood KAC-7202 Car Audio Amplifier
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
44 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
