Question about Raymarine St 4000 Wheel Drive E12093
I have an older ST4000 AutoPilot and this summer the drive motor doesn't seem to function. How do I disconnect the wires to determine if I have power coming from the control head and what voltage show I see on the wiring.
  • 64 Answers
You can check it in 2 places:
1) the back of the control head
2) the motor itself. The wire plugs into the motor or the shaft coming off the wheel portion.
You should have approx. 12 VDC coming from the control head to the motor.
Posted on Jun 14, 2010
How do i recalibrate the st4000 tiller for the starboard side
Hi Tina!
The ST 4000 is factory default to the starboard side. If you require a port side mount, see chapter 7 of the manual to which I have provided a link below. (3.16 MB) About halfway down the page.
The text reads as follows:
OPERATING SENSE REVERSAL
Press +1 and -1 keys together for five seconds.
The display will then show port or starboard and the phase of the autopilot will automatically change.
The control head will automatically revert back to its normal operation within 5 seconds.
Note: This should normally only be required if the actuator is port hand mounted.
Hope this helps.
(Sorry about the orientation of the manual, it's pretty cheesy coming from Raymarine.)
-Steve
Raymarine Retired Autopilot Manuals
Dec 05, 2014 | Boating
St4000 pops into standby
Hi
This is almost always caused by a dirty connection at the standby contact. If you're handy with electronic repairs, take the control apart and clean the circuit board for the contacts with silicone spray (safe for plastics) and a Q-tip and reassemble. Works 99 44/100% of the time.
Hope this helps.
-Steve
Apr 09, 2014 | Raymarine Smartpilot Autopilot St6002 S1g...
My st4000 wheel pilot turns on with the boat, rudders center up like normal, but then if I push the AUTO button the power fuse blows
Are you sure that you've got the correct value fuse in? Check that the motor/gearbox assembly will turn; ie, it's not siezed up. Check the wiring to the motor to make sure that there's no short circuit anywhere.
Nov 07, 2010 | Raymarine ST4000 GPS Receiver
MOT POW SWAPPED, this is the message which appear just like that. the autopilot is working last 5 years, i have checked the wires connections, all is set as the diagram. one thing: my rudder has some...
Check if rudder reference unit is installed as before ,it seems that the pilot sense that the rudder is turning the wrong way. check when giving +10 command the
rudder turns to increase the heading,if yes, it could be the wiring of the rudder reference unit or it was installed the wrong way after service on the rudder.
Is rudder position indicating correctly?
Jun 24, 2010 | Raymarine Smartpilot Autopilot St6002 S1g...
My st4000 mkII shuts off from auto mode whhen i engage the clutch lever and the wheel turns for a second. the screen goes blank and just displays "st4000" . voltage is fine and all wires are connected....
CHECK THE POWER SUPPLY WIRING ,If it worked before ,could be corrosion or lose wire connection,or terminal bad crimped,or terminal loose inserted.
If it is new installation ,power wires could be undersized,or battery discharged .
Normally autopilot shuts off from auto and restarts when power supply voltage drops under the reset voltage ,when the wheel turns ,the motor current increase and the power voltage drops when the power supply wires are not OK.
Apr 06, 2010 | Raymarine St 4000 Wheel Drive E12093
I HAVE A 1997 AUTOHELM ST4000 AUTOPILOT AND THE
GLUE THE SMALL POSTS EXACTLY IN PLACE AS THEY BROKE OFF ,DRILL A HOLE VERTICALLY THROUGH THE POSTS ,SAME SIZE AS HOLE IN THE SS WHASHER, (HOLE OF THE SCREWS)ALL THE WAY THROUGH THE BACKPLATE ,INSTALL A STAILLESS SCREW WITH HEAD ON THE REAR OF THE BACKPLATE AND NUT ON THE WASHER SIDE TRIM TO EXACT LENGHT USE LOCKTITE FOR NUT.
Jan 05, 2010 | Raymarine St 4000 Wheel Drive E12093
Service Manual for Autohelm's st4000 Wheel Drive Autopilot
Hi, If you are looking for Autohelm service manuals you may find them at http://sdmarine.online.fr/Service%20Manuals/Autopilot%20Systems/
Dec 18, 2009 | Raymarine St 4000 Wheel Drive E12093
Minn-kota 865 autopilot
Hello dtspins2. Your footswitch is stuck. Disconnect the DC. Remove the bottom of the foot control, check the wiring for insulation broken off and wires shorting out, and disconnect a wire(note color of wires) from switch, reconnect power to confirm motor don't run. Remove the switch and contact your local electrical supply store(may cost less) or marine store for replacement. Good Luck.
Sep 07, 2008 | Boating
Wiring of seatalk instruments
OK, you are confused. Seatalk is a bus system, using 3 wires , (power +, power-, and Data.) red, bare and yellow repectively. So Red and Bare are 12V and ground. Since the 125 shows a green light, it is getting power and outputting data. but is it seatalk?? to make a 125 Seatalk, you must hook red and green together to 12 V, so check that first. if green is grounded or not connected, that is the problem (or one of them)
Next divide system to its' simplest terms, so hook the GPS straight to the display ST60, and see if it works red to rd, yell to yell and bare to bare (sometimes black) One by one hook the others into the chain until they all work or failed device takes down Seatalk network. If you are missing 12V on a seatalk leg, check 5A fuse in course computer. If you have a pilot, you have a course computer, unless it is ST4000 wheel pilot, and then the brain is the display (course computer is built in to ST4000 display)
Sep 01, 2008 | Raymarine RL70CRC GPS Receiver
Sea talk failure
Remove all wiring from 4000 head, hook up only 12V, if seatalk fail continues, it is the head. if seatalk fail goes away, hook in instruments one by one until the bad head is found. Seatalk is 12V red, Ground Screen(bare wire) and Data yellow (pulsing voltage). good luck 847-746-0100 John Barry
Jul 14, 2008 | Raymarine A65 Combo GPS...
Raymarine St 4000 Wheel Drive E12093 Logo
247 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
David Burbee
David Burbee
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
