Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman LT2000 tractor seems to drain batteries over a 3 t 4 month period. Works fine then it just dies after 3 or 4 months and battery is shot?
  • 279 Answers
Check your charging system! The alternator may be bad. If you can't get it repaired, just put a trickle charger on the battery the night before use. That is not a fix but will get you by...Lee
Posted on May 28, 2010
Craftsman tractor lt2000 with 17hp Kohler won't start. Ran fine last week. Rebuilt carb, changed oil, and new plug & fuel filter month ago. Has spark and fuel. Cranks but won't fire.
Hi Mike:
It's trying to make you crazy.
I have a model YT4000 and it is a PITA to start when cold.
I pull the air filter, toss in a bit of gas to prime it, and it starts instantly.
I'd suggest that you give yours another try. 3 or 4 times of a couple of seconds each. If it doesn't go, pull a spark plug and see if it is wet or dry. Wet indicates getting gas but no spark. Dry indicates not getting gas.
While you have the plug out, check the spark... Hot & blue.
Hope this gives you some more to work with.
Jun 22, 2015 | Craftsman Garden
How do I get my craftsman lt2000 to not die?
safety switches need to be replaced
Jun 13, 2013 | Garden
Craftsman lt2000 will not start
You should read 12 volts atleast. Try www.managemylife.com for a owner's manual.
May 08, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a 92 Camaro and the problem I'm having is sorta weird.. My car ran fine about 2 months ago, but i haven't driven it for about 2-3 months. When i went to fire it up the battery was dead, so I...
SOUNDS LIKE YOU NEED BOTH THE ALTERNATOR AND THE STARTER TESTED.THE CAR SHOULD STAY RUNNING OFF THE ALTERNATOR ONCE BOOSTED,IT SHOULD START OFF THE BATTERY WHEN FULLY CHARGED.
Oct 18, 2009 | 1992 Chevrolet Camaro
Sears Craftman LT2000 does not start
bad safety switch one under seat ,clutch pedal,blade engage leaver
Sep 01, 2009 | Garden
LT2000 had been working fine, but trying to start
Make sure there is no corrosion on the battery terminal connections and check the fuse and safety switches clutch, brake,seat.
Eric
Jun 29, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Loss of drive in a Craftsman Lawn tractor
I also have a Craftsman tractor with the same problem. Sears repairman said it needed a new transmission and it would cost $1,400 to install. A new one is about $1,000. Anyway, if you remove the battery and the battery tray under the seat it will expose the transmission fill hole (hex). I opened the top and it looked empty. I had a bottle of 90 weight gear oil in my shop and filled the transmission to the top. I have not had any problems with it since. $4.00 bottle of oil verses a new tractor is worth a try.
Mar 30, 2009 | Craftsman Garden
Battery keeps draining
are you not using it for three months at a time? if so it could something as simple as a clock draining the battery, i would disconnect the battery if you are not using it for extended periods of time
Feb 16, 2009 | 2001 Lincoln Continental
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
620 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
