Question about Sony KP-57HW40 57" Rear Projection Television
For sure i have the same tv and i don't want to pay to get it repaired but it's starting to go blue screen and then shuts off.
  • 1joe2 Apr 14, 2008
    TV comes with good picture for about 1 minute then red and green projectors fade out than tv shuts down.
What will that cost?
Posted on Apr 27, 2008
  • 121 Answers
Chances are its the blue picture tube it would need to be replaced
Posted on Apr 12, 2008
What makes a tv screen turn blue and shut off
Hello jamdevdm,
Welcome, and thank you for using FixYa!
To get to the point on your TV issue: the blue screen is the Blue Projection drive firing, but it would appear that non of the other colors are firing (Green and Red). It sounds like this TV will need some major diagnostics to see if the other Jets are dead or if the power control board is dead.
I recommend that you take this TV to a local TV Repair Shop and have it looked at, if it is worth it to you.
In most cases, a repair of the nature; it is just as cheap to replace the set than pay for parts and labor.
Have a great day!
Sep 11, 2011 | RCA Televison & Video
The Screen Turns Green then shuts itself off? Is this the Bulb or something else?
My sony 65Ws500 model about 4 months ago it started turning the screen all blue as soon as I turned it on. it stayed blue for about an hour then come back on normal now when I turn it on it will shut down and I get a small red light flashing 8 time then pauses and does it again 8 time then pauses then again and so on. I took back panel off. I turn on tv The blue bulb gets very bright and the green and red projection bulb goes out and now it shuts off. and the blinking starts it a code flashing but don't know the code to find out whats wrong. would someone help if u can been wife and I laid off from work 3 months now cant afford tech prices on our employment. wife and I has 2 little girls to raise. along with the rest of u parent out there and one getting employment cant offord repairs. Thank U. Adams01220@yahoo.com
Feb 13, 2011 | Sony KP-65WS500 65" Rear Projection...
Tv shuts off after 2 seconds
This is made by LG / Zenith. They have had alot of problems with there TV's.It most likely has an inverter board going bad or could be power supply board. It will cost to much to repair. Get an extended warranty when you buy a new one. It will pay for itself.
Aug 02, 2009 | Vizio VA26L 26 in. LCD HDTV
Blue haze spot-yellow tint
I have the same problem with blue haze that just spread out on model 55VS69A ,
tv is almost 2 years old. i called hitachi and they advised to call a local repair center to check the tv...they confirmed Optical Block (light engine ) replacement light engine cost $1400 and labour $400, so i called back hitachi and they said they will provide light engine and will have to pay labour!....this is not right paying out of pocket for a tv less than 2 years old....I am not sure if the issue will resurface again...more likely ....Hitachi is supposed to issue a recall or atleast like sony did to cover all cost for there defective TV's....I will NEVER buy hitach again.
Hitach SUCKS.
Dec 28, 2008 | Hitachi 60V500 60" Rear Projection...
Blue waves
You need convergence circuit repair. The cost depends on where you live and who you call.
In Calgary, Canada typical TV shops want $300 to $650 for convergence repair. They will include cabinet damage and wall scratches for free.
It is a difficult technical repair to attempt as a rookie tech. It is even more difficult if alignment is required or any secondary problems are encountered. If you have no tools, no experience soldering or doing electronic repair; you may end up with scrap or paying a high price for someone to fix after your attempt to repair.
easyab
Aug 11, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Blue Screen and TV shuts off
Here's a shortcut to what the blinking codes mean.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Strange how some people have 5 blinks. Most with this problem have 8 blinks (like myself)
I still have the blue-flash-then-shutting-off problem.. (8 blinks meaning voltage error) but I did fix the blue lines.. The lines across the screen can be very easily fixed whether they're blue green or red. . No, I mean REALLY easy. Took me longer to get the cover off. Once the front cover is off it takes 10 seconds. This link was also posted recently in one of the posts below as a solution..
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
(My lines didn't look like the ones in the picture mine were several evenly spaced blue arcs)
After some research I believe the flash/shutting off problem means the CRT is going. I've also read that it might be the D-board and I'm not even sure that that is... But If it is indeed the CRT then I'll let you know it's very difficult to find a replacement blue CRT as this part has been discontinued.. but I did eventually find an alternate to an alternate part (yes that's the 3rd alternate !)) online for $256. Here: http://store.tv-repair-service-salinas.com/8-733-649-35.html
If you're bold enough to attempt that then good luck and please let us know if it worked.
Or another alternative is there's a whole lot of Boxing Day sales goin' on right now.
Jul 12, 2008 | Sony KP-51WS500 51" Rear Projection...
Kp-57ws500
My tv too had a blue screen problem. Then it started to shut down after staying on for less than a minute. I thought that I would with a huge repair bill but I followed the directions at this link: http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html and now my tv works perfectly.
May 01, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony turns on and off again
Apr 27, 2008 | Sony KP-57WS500 57" Rear Projection...
Blue area near center of screen
Uh Oh! blue screen of death. Your light engine has warped a little from overheating and is distorting the picture.
My suggestion to you is to get on the phone with hitachi and start complaining, then keep complaining until they agree to pay for it. You may have to get the problem diagnosed by a pro before they agree to pay for it though.
Oct 08, 2007 | Hitachi 50V720 Television
Yes, you are correct on the phrasing. The CRT's were a common issue with these units and all three must be replaced as sooner or later the green will follow the other two CRT's. It was a great model and had a beautiful picture when operating normally. The CRT's are costing about 200 each for rebuild as the green and blue are mostly no longer available. Your repair cost are going to approach $1000.00 or more.
Mar 07, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57HW40 57" Rear Projection Television Logo
37 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
