Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
My dishwasher isn't draining
How do I open the drain to check if something is blocking it?
  • Whirlpool Master
  • 3,740 Answers
Check the drain hose all the way from the dishwasher exit hole through the air gap and into the sink connection. This is a common problem when a dishwasher will not drain. You will need to dis-assemble the air-gap by removing the cover and unscrewing the drain cap to check for particulate matter. Make sure you note the oreientation of the cap when you remove it as it will only fit one way. It is best if you remove the hoses and check all of the drain holes for obstructions. Dishwasher to sink connection.
Thanks for using FixYa.
Kelly
Posted on May 28, 2010
  • Kelly
    Kelly Jun 03, 2010
    If you did not figure it out there is a kick panel at floor level under the diswahser that is removable to gain access to the drain hose. Keep in mind that there are electrical connections under the dishwasher that are live even with the unit not running. It is best to secure power to the dishwasher before removing the lower panel to aviod getting shocked. Then you can remove the drain hose from the motor pump assy and check for debris. If you can not see into the hole use a small make up mirror (compact) and a flashlight to look into the hole. Then continue the full length of the drain hose removing EACH connection and checking for debris. Once you have ensured there is not any debris in each inlet or outlet port along the hose you can reinstall the hose and mounting clamps. I can not emphasize enough that the most likely culprit is the air-gap and the sink connections. I would start there FIRST before removing the lower hoses.
    Thanks again for using FixYa and if you need more help or have more questions just respond here and I will gladly walk you through the how to of slow draining or any other issues you have. We just need to communicate. A 2 thumb rating and no comment from you does not solve your problem. Let's do our best to fix it so that your happy with the end result.
    Thanks again for using FixYa,
    Kelly
Delongi dishwasher wont drain
Try connecting waste pipe to mains supply, and briefly turn on mains, it might flush out any trapped stuff in the machine
Jun 24, 2013 | Dishwashers
My GE profile dishwasher is not draining, is it fixable?
Yes, it is fixable. I would fix check to make sure the float on the inside of the unit is not stuck (not a probable, but easily checked). Then I would pull the unit out and check the pump. If something is clogging the pump intake then it wouldn't drain. If there isn't something blocking the pump intake, then it is probably the pump itself.
Sep 20, 2011 | GE Profile 24 in. Built-In Dishwasher...
DOES NOT DRAIN ALL THE WATER OUT OF THE INSIDE. DISHES ARE STILL NOT DRY
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 12, 2010 | LG 24" XL Tall Tub Built-In Dishwasher -...
I have a small dishwasher it goes through all cycles water won't drain out of the bottom
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 07, 2010 | Maytag 24 in. MDB4000 Built-in Dishwasher
Not draining complety
Hi
Thanks
Rylee
Sep 07, 2010 | Admiral 18 in. DWCA500AA Free-standing...
Water does not empty from dishwasher
Hi
Thanks
Rylee
Jul 04, 2010 | Maytag MDB9750AWS Built-in Dishwasher
The dishwasher does not completely drain.
Hi
Thanks
Rylee
Jun 10, 2010 | Whirlpool 24 in. DP940PWP Free-standing...
Water won't drain
Hi
Thanks
Rylee
Jun 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
The door on my dishwasher everytime you open it is making a loud creaking sound and there is water at the bottom of the dishwasher always. what to do?
Hi
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mar 03, 2010 | KitchenAid Dishwashers
the first things to look for, are the simplist faults.
1:) Check that the Outlet Hose-Pipe Isn,t Blocked-Kinked Or Bent.
2:) Check that the Pump, is not clogged/Blocked or not-functioning.
Hope this helps you start, your fault-finding successfully.
Mike @ Compurepair.
Aug 02, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
223 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
