Question about Logitech G51 5.1 Multimedia Surround Sound Speaker System (6-Piece)
There is no sound coming out of the speakers. I checked and everything is on, nothing is muted, and the green light is even going up and down when music is on. What should i do?
    President:
  • 1,099 Answers
the problem of the no sound could be as a result of blown fuses in the audio stage of the printed circuit board, please do check for blown fuses, if otherwise take the system to the manufacturer for proper diagnosis. hope this will help..
Posted on May 28, 2010
No sound in my pc even theres a speaker put
you had a problem at your sound card verifies this :
- Check if everything is connected
- in your Quick Launch toolbar, you do a right click on the speaker icon and "adjust audio properties" if you look everything is in order: sound volume, the mute box is not check .. .
- or you go to control panel system hardware p?rif manager and then see if you dont have a point. So you launch a detection in http://www.touslesdrivers.com/index.php?v_page=29
good luck
Jan 31, 2011 | Computers & Internet
Music is playing - everything is turned on - fixit says there is no problem - sound card is active - speakers worked yesterday - now nothing, no sound is coming out of speakers
you might have hit by accident a windows mute key or a mute on your speakers themselves or maybe the wire that plugs into your speakers or computer got disconnected accidentaly.
try going in your Control Panel and check what u have in the Sound tab, it might give you some clues if the problem is inside the box.
you can also go into Control panel and Device manager and see also the sound Tab in there see if also your card shows up there...
if u have also an onboard sound card and also a pci sound card those can get into conflict if both are active at the same time.
good luck!
Oct 22, 2010 | HP (ED808AA) 2 Speakers
Have external gateway speakers
First make sure your sound cards are working properly. 1) Check the master volume of your PC. Go to start menu, control panel, sounds speech and audio devices, sounds and audio devices - i) In volume tab click the speaker volume and check whether all the left, right, etc.. volumes are in medium or high. ii) In audio tab click the volume tab of sound playback and make sure that the master volume is not in mute and all the volumes are either in medium level or at 100%. After making these changes try playing any music. Even if the problem persists go and get your sound card checked in an authorised service centre.
Thanks & Regards,
Shiva
Sep 11, 2009 | HP (ZD929AA) Computer Speakers
Sound does not work
check the audio connector ( color green ) if it is connected properly to audio port ( color green : beside the pink port ) .
Check if you have installed the drivers for the sound device.
Also, if you have the speaker configuration in your system, you can check it if it has just been muted.
make sure .
1. You installed the right driver properly
2. It is not muted .
3. Try to use another speaker, so that you can test if your speaker device is working .
if none of these works, then probably your audio device, doesnt work.
Aug 09, 2009 | Computers & Internet
Speakers plugged in, not muted on computer. still wont work.
speakers could be broken, one or more of the wires could be broken (inside)
Jun 29, 2009 | Harman Kardon HK695 Computer Speakers
Sound won't work without the earphones being plugged in
Make sure the speaker volume is turned up and also go into Control Panel, Sounds and make sure nothing is muted and all volumes are turned up. Also make sure the speakers are plugged into the sound jack in the back of the pc. The speakers also need power but since the light is on, it sounds like they are plugged in.
Apr 14, 2009 | E-Machines eMachines Desktop PC
Sound
Make sure your volume is not on mute. If the speaker icon on your lower right has a red x means its on mute. To test go to control panel and double click sounds and test. If Windows sounds work without speakers then problem is with speakers. Make sure volume is up, make sure its properly connected to correct output jack (usually green or light green). Also make sure speaker power on. If those things are correct check your device manager ( right click my computer) select "manage", click on "device manager" and on right pane check to see if theres any yellow exclamation, question mark or red x on the sound device section. Yellow exclamation or question mark means to update or install correct drivers. Check your speaker box if it comes with a CD.
Jul 29, 2008 | Dell Inspiron 530s Desktop Computer...
No sound coming from speakers
check your interconnection cables-check volume control not in low level-no mute button or switch is pressed-check your input selector for right selection.-if you have speaker button confirm it is pressed.
Jul 20, 2008 | Audio Players & Recorders
No sound
What exactly is evrything?
Reinstalled sound drivers?
Checked your speaker cord to make sure it comes into the green hole on the back?
made sure your speaker wires are not broken?
Volum on the speakers?
Control pannel> Sound> Speaker Icon: Are the controls HIGHLIGHTED? If not sound driver is not loaded.
Check Volum MUTE. SOme programs MUTE your volume without a warning.
Jan 04, 2008 | Behringer FCA202 - FireWire Audio...
A215 speakers
Do you see a little speaker in the lower right hand side or your screen, If so double click it and make sure the volume is up and there is nothing muted. If everything looks ok there write back to me and we can figure it out with a few more questions about what kind of system you have, and OS (Operating system) Let me know and we can fix if this don't work please let me know I am trying to get all the free one I can fix and help for the Holiday. So Have a Happy Holidays
Dec 17, 2007 | Dell A215 Computer Speakers
Logitech G51 5.1 Multimedia Surround Sound Speaker System (6-Piece) Logo
322 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
