Question about Dell (8N816) Motherboard
I did not mistreat my computer in anyway. If the computer does not start up even with the battery charger in and everything, what does that mean is broken? The harddrive or the motherboard?
    President:
  • 1,902 Answers
If when you press the power button NOTHING at all happens then the motherboard is bad.
If you turn on the computer and the lights all turn on but nothing else happens then the hard drive is bad.
If when you turn on the computer and you hear the hard drive start, the fan running and everything else seems to be working then your video card is bad.
Posted on May 28, 2010
Testimonial: "Awesome!! That is what I thought, thank you!"
    Top Expert:
  • Dell Master
  • 79,186 Answers
Either the harddive is defecfive or the software is corrupted, contact dell customer support for details on determining which is the problem, email support is free for this type of problem.
Pro logix charge does'nt start
Do you mean that the charger doesn't start the car? Have you waited long enough for the charger to charge the battery? Sometimes it will take a long time. A battery will lose its efficiency up to 60 percent during cold weather. That means it will take even longer to charge up the battery for a start. Especially if it has been sitting for a long time. Remember, to start a car with a battery charger, the battery must have a partial charge. Put your battery charger in the low setting of "2amps" and allow it to charge for a dozen hours. If it doesn't start the care by then, you better have the battery tested. It may not be able to hold a charge. Which could keep it from starting the car.
Apr 04, 2014 | Clore PL2320 20/10/2 Amp Pro-Logix Battery...
Not turning on
Be aware that most cameras, when connected to a computer or to a charger won't start up.
Please try to charge the battery (batteries) on an external charger.
But if the charger does not "see" the battery, the battery must be defect.
By "see" I mean, when you place a battery on a charger, the charger will respond with a light, to indicate it has a battery and started the charging process.
Jan 05, 2014 | Canon Cameras
Battery charger on quantum electric wheelchair starts out ember color then starts flashing red I check wires everything is plugged check it about 3 months ago everything was ok now th chair won't
Did you charge it at all during the 3 months? Did you store chair on a full charge? Check to see if batteries are dead. Batteries should be disconnected and/or stored on a full charge. If left connected they should be fully charge every week.
Mar 17, 2013 | Health & Beauty
I cant get my power chair jet 3 to charge batteries are good
Hi valentin 201
I have owned my own business for 3 years and have been working on scooters and powerchairs for 15 years. . In the future give as much info about the scooter as possible.
1. load test the batteries even if you think they are good, check anyway. Sometimes even new batteries won't hold a charge.
2. Your charger on the powerchair must have enough volts to open the charger inhibitor. That is, the charger won't even start up if your batteries are low. Both batteries need to have at least 20-22 vdc.
3. Some chargers have a 3amp fuse check that and repace if needed.
4. With a multi meter set on dc200 check your batteries. Red on one battery and black on the other. Check to see what you get for voltage. If no voltage reverse the lead wire to the other posts. Once you get a reading of 20+ volts watch the meter and plug in the charger, it should increase the volts on the meter. if not the charger is bad, replace. Charger should be 24-31 volts to be a good charger.)
One of these sugestions will fix the problem
Good Luck
Tim
May 03, 2011 | Jet 3 Ultra Power Chair
Battery will not charge.plugged in not charging
Does the computer start anyway, but it's just that the battery won't charge? If that's the case, it's probably a bad battery.
A procedure to do before assuming a bad battery is to (1) remove the battery, (2) disconnect the power supply from the computer, and (3) press and hold the power button for about 30 seconds. This resets the logic circuits in the internal power handling section. If that doesn't help either, then the battery is probably bad.
If the computer isn't starting, however, it could be that the power supply has failed. Check the voltage output on the power supply.
Hope that's helpful.
Jan 12, 2011 | IBM ThinkPad T30 2366 Notebook
When i connect my adpater to my laptop it doesnt charge my laptop even thow the light on the adapter is green
I'm not sure I understand your question. Can you please be a little more specific.
If your computer is showing green light and it powers up it would mean that your battery is no good and you should start looking into purchasing another battery. If that does not answer your question please feel free to leave a message and I will try and do everything I can to assist you. Good Luck!
Dec 10, 2010 | Sony AC Adapter Charger for Sony Vaio...
Toshiba laptop won't start up
Try this:
  • remove battery
  • replace battery
  • restart
Then:
  • with charging cord plugged into computer and wall restart
If it starts on the battery the computer has reset itself-- you're good to go...
If it starts on the wall charger but not the standalone battery... the battery is the problem.
If neither works replace the charger cord.
Good Luck
Jeff
Sep 13, 2009 | Toshiba Satellite A205-S4777 Notebook
Won't charge after the battery runs low.
that means your battery is flat so first boost the battery using universal charger or in other way charge you battery directly
Apr 08, 2017 | Sony Ericsson XPERIA X1 Smartphone
Low battery display
My first guess would be to take a volt meter, and check the power pack to see if it's putting out the correct DC voltage(or any voltage). Those things are super cheap!
Then check the plug in on the scanner to make sure your getting a good connection(might have a broken connection to the circuit board). If those are 2 year old rechargeable batteries, they might be getting close to laying down and dying. Hope this helps,, Mechanic
Oct 22, 2007 | Radio Shack Pro-94 Scanner
Dell (8N816) Motherboard Logo
187 people viewed this question
Alun Cox
