Question about Samsung HL-P5063W 50" Rear Projection HDTV
A whining sound louder at time than others started my months ago. It diminishes and comes back up in volume. The picture colors went haywire with the highest sound ever this week. We turned it off for 3 days and turned it back on today and the sound is still high but the picture is perfect. The original seller of the model to us said it was probably the picture tube. Is the picture tube the lamp.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. A loud whine like sound can be caused due to a bad color wheel as the color wheel spins faster and makes a high pitch sound when it goes bad. From what you have described it also clears out to be the color wheel as it seems the bushing of the color wheel has seized and is causing this issue. Replacing the color wheel will cost you around $130 if you do this yourself. If you take assistance from a professional he might charge you another $150 to replace it. Moreover, this is a common issue with Samsung DLP TVs and as I said if you want to do it yourself then please see this video on how to replace the color wheel in Samsung DLP TVs. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 28, 2010
  • jam76 May 28, 2010
    Moments after I sent you my information the picture screen went haywire. Could this additional problem mean the lamp needs to be replaced instead of the color wheel.
  • Rylee Smith
    Rylee Smith May 28, 2010
    Dont think it is the lamp as if it was the lamp the unit will not make a loud whine like sound.
Nisson Maxima ST -2001
It could be the bearings in the alternator or could be the bearings in the idler pulley or trenchener pulley. if the alternator goes out it will not charge the battery if the others go then the belt will brake and you can cause more damage to the car.
Jan 28, 2014 | Cars & Trucks
Hi my c1 has started to make a whining sound (bit like a dog whine) the last couple of days. It tends to get louder and is intermittent, it starts when the engine is fired up (no probs starting engine)...
Have your drive belt replaced (sometimes called the auxiliary or serpentine belt) when it slips it creates a screeching noise and it's also a sign that it's going to fail (snap).
These can run the alternator and power steering so you should change it as a preventative measure.
Oct 17, 2013 | 2008 Citroen C1 1.0
Hi, I have a Samsung DLP Model HL-P6163W, approximately 5 years old. We replaced the lamp one year ago with no problems. In fact, we have had no other problems at all with the TV except recently. About...
Ur tv have a colors wheel design in it.Tv have buzzing,squiling or loud motor noises.Have colors turn in Black&White or flashes white within pictures.All these causes and problems are the effect of the colors wheel is dying and require repacement of the colors wheel,because it is woring out and not spinning correctly on it motor axis anymore.Have no machanical experience taking things aparts and putting it back together again.Don't atempt to change the colors wheel by ur self,bacuse the colors wheel sit way back on the tv,must take out many machanicals parts before u can even come to it to change it.Hire a Tv Tech. to change the colors wheel ok best solutions and no complication taking out the old one and putting in the new colors wheel,for it to functions correctly.
Jan 07, 2011 | Samsung HL-P6163W 61" TV
The power comes on and then turns off and the front green power light blinks.
There is a small IC in the power supply section,
not the IC regulator that's the problem.
Jan 06, 2010 | Philips 32PT6441/37 32" TV
Whining noise from front end. starts at 5mph and
If the sound is coming from your power steering pump and the fluid level is good, the pump could be going out.
Oct 12, 2009 | 2001 Dodge Dakota
Whining Noise and Image Problems
You better to check the color wheel or Lamp ballast.
Normally, the noise comes from color wheel.
Jan 17, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Whining Noise when idle and gets louder when accelerating on 2000 Nissan Altima GLE
hi more than likley to be the alternator remove your fan belt start engine see if noise disapears yates210456
Oct 08, 2008 | 2000 Nissan Altima
Samsung Model HLP5063wx/xaa
what are the indicator leds on the front doing? if all 3 leds are blinking then it's probably the color wheel ,lamp or the dmd board, if you turn it on and it goes through a series of shut downs then the leds blink, it's probably the lamp or dmd board.
Sep 02, 2008 | Televison & Video
High pitched whine when the motor starts
Had the same problem. It quit within about 5 seconds after turning the TV off. Replaced the color wheel and the whine is gone. The picture also looks brighter, which may be due to dusting the projection lens with lens-cleaning compressed air (from a can). The color wheel was about $100 from Samsung parts and it took less than 3 hours to replace. See http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/ for good info, and be sure to read the cautions.
Aug 07, 2008 | Samsung DLP HL-P5663W 56" TV
I have an RCA model #HD50LPW62AYX2 hdtv/dlp rear-projection set. The picture went out, and we thought it might be the bulb, so replaced it. The picture still will not come on, and there is a loud...
The color wheel can make a whinning sound for sure, However it should not continue to whine after shutting it off. That sounds more like the fan used to cool the lamp, as that will continue to run after the set is shut off. How soon does the whinning start when you push power? Let me know I should be able to help you out. DLPs are my specialty
Mar 26, 2008 | Televison & Video
Samsung HL-P5063W 50" Rear Projection HDTV Logo
110 people viewed this question
Jerry Greenberg
Jerry Greenberg
