Question about Samsung CXJ1952 19 in. Combo
My vcr plays slowly
When I try to play a vhs video tape in my tv vcr combo, it plays very slowly with grainy picture for 5 seconds before stoppping all together. This seems to happen when the tape is near the middle of the length of the tape (i.e. 4 hr mark of 6 hr tape) and longer. When the tape is rewinded and played, the tape plays fine with normal picture. What is wrong?
  • Samsung Master
  • 3,866 Answers
The VCR needs to be tuned so to speak there is a tension band that is slipping or has slipped in it and you going to need repair straight put.
If you not good at VCR repair then you might want to check it into a tv repair shop that does VCR's as well. But its pretty easy fix for a tech.
Thanks for you considerate votes and feedback
Posted on May 28, 2010
Testimonial: "Thank you"
  • 4,234 Answers
I'm sorry to say, but the tension band is not lileky to be the problem. The tension band is there to keep tension on the tape, but it is the pinch roller that actually pulls the tape through the unit. With the symptoms you describe, I would have the pinch roller examined. I would also check the idler tire.
Dan
Sony rdr vx560 dvd recorder vcr combo
Look for tape residues on the head drum (metal cilinder inside). Clean it with extreme care or use a cleaning tape. If any tape get stuck inside recently the ground shaft might be bended and it causes grainy pictures.
Oct 12, 2013 | Televison & Video
I have a number of VHS-C tapes from my various video cameras in the early-to-mid 1990s that I'm transferring to DVD via my DVD/VCR combo device. But several of of these tapes that have the suffix...
VHS-C and S VHS-C are two different animals. Super VHS-C will have much better video resolution than standard VHS and uses better videotape. A standard VCR will not play the Super format. You need a S VHS VCR. You would need not only a S VHS VCR but also a S VHS-C adapter. Yes, Not even the adapter is the same as a standard VHS-C adapter cassette.
You can send out your few S VHS-C tapes to a video conversion service. That might be the least expensive way to get them on DVD. Otherwise you could look on E-Bay.com for either a compatible camcorder (S VHS-C) or the S VHS VCR and the S VHS-C adapter.
http://vhs-to-dvd.com is one video conversion service that should be able to get your tapes on DVD for you. You could also look locally for a video service that does conversions to DVD.
Feb 19, 2011 | Televison & Video
Why won't older Sanyo VCR playback VHS tape on new HD-LCD TV?
The problem is not with your TV. I have had this problem as well and the older the VCR gets the harder it is for it to turn the tape. Does your VCR react the same way with other tapes? Try Fastforwarding the tape about halfway and then test it again.
Jan 06, 2010 | Sanyo Televison & Video
Vcr cuts my tv off after i put the tape in
The VCR is not turning the TV power off. The tape is not playing. I'd guess maybe it needs a cleaning or a replacment.
Dec 24, 2009 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
My dvd/vhs combo has sound but no picture on the vhs side?
Check ur RCA cable setting might have a short in the cables.
Dec 12, 2009 | Televison & Video
VHS tape plays for a few seconds and automatically ejects
My guess would be dirt on the rollers inside the VCR. They sesnse a jam and ejct. Try a VCR cleaner (with cleaning fluid) and see if that helps.
Feb 21, 2009 | Symphonic WV806 DVD Player/VCR
Stuck VHS tape in Samsung TV/VCR Combo
I told you in premium post that Unplug your Combo for 5 - 10 minutes from AC outlet and replug it. Now push eject button and take out cassette.
Oct 09, 2008 | Samsung CXJ1352 13 in. TV/VCR Combo
Emerson TV won't stay on
I am currently have the same problem . I just got off the phone with the support tech and he suggested unplugging TV for about 5 minutes and if that doesnt work to unplug TV for about 2 hours. He said that may reset the TV . I am waiting now. If it works , I will leave feedback.
Nov 15, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Emerson ewc1302 13 in. tv/vcr combo problem
We had that same problem. Try a VHS head cleaner. Worked for us.
Oct 24, 2007 | Emerson EWC1303 13 in. TV/VCR Combo
VHS problem, any help?
It sounds to me like you have a problem with the reel sensors not detecting movement of the tape through the VCR. This could also be caused by a defective voltage regulator(s) that powers the sensors. This model was made by symphonic/funai (1-800-242-7158), and it is not likely worth repairing.
Dec 30, 2006 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
Samsung CXJ1952 19 in. Combo Logo
94 people viewed this question
Henry  Thomas
Henry Thomas
