Question about HP Officejet J5780 All-In-One InkJet Printer
Internal DRS error when scanning - HP Officejet J5780 All-In-One InkJet Printer
    Novelist:
  • 76 Answers
When you go to do the scan using the "HP Solutions Centre" "Scan Document" button (press this now).
Click on the "Change Settings" button (lower right side of scan window) in the window that opens. This opens the "Scan Document Button" window. Make sure the "Show a preview scan." box is ticked (In Button settings bottom right of window.
Click on the "Advanced Document Settings..." button (Right Hand side 2nd under "Scan Type)
Change the "Output Resolution (ppi) for Document as Image:" to 200. While here, check the correct language is selected. I also tried an Output Resolution of 600ppi. This seemed to make no difference as the system defaults back to 300ppi when the scan is carried out, regardless of what has been selected, but still scans as expected instead of erroring. For some reason I have yet to discover, simply changing the ppi removes the erroring!!
While here (in the "Advanced Document Settings..."), now would be a good time to change the scan to "Black & White" which in itself reduced my scan from 24.5MB to 1MB The only thing you'll need to do then is, after the scan, adjust the "Black and White" level manually for clearest picture. I got the best results this way. If you forget to select this at this point, don't worry, it can be done from the next window (HP Scanning)
Now click the "OK" button. This takes you back to the "Scanning from... Scan Document button (HP Solution Centre) window. Now click on the "Scan" button (in the "Scanning from...Scan Document Button (HP Solution Centre)" window.
Now you'll be in the "HP Scanning" window which is where you can make any final changes you deem neccessary. You can also see how big your file is and how each change makes a difference to the size of your file. Note that this is not the storage size. It is the size of the "working in ram" file.
When the document is the way you want it, then select finish. This time, it should go through to the final program as expected. Don't expect every character to be correctly recognised, especially with any hand written documents. Tables are especially notoriusly bad.
Hope this helps. Good luck and I'll let you know if I find anything else to help.
When it works, it works well. In the mean time......
Posted on May 29, 2010
I have an Officejet 5610 All-In-One and when I am trying to scan, while processing, I am getting "Internal DRS error 1500:c0:300". How can I solve this please?
Search the HP knowledge base for more ideas. You didn't say if that error message is showing up on your computer or on the LED panel of the printer.
Sounds like your trying to scan a document. Make sure the application that is supposed to receive the document is installed.
Oct 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Problems with Age of Empires II
I think the game may need direct x to run
Problem apple does not have direct x
research on internet is pointing to emulating windows on Mac
and running dirext x in emulation ?
https://www.parallels.com/au/landingpage/pd/general/?gclid=CjwKEAiAi-_FBRCZyPm_14CjoyASJAClUigOnIf36NPJH6HLhU3gR7pjCfXoq_M5fkmTj1iGAnEpAxoCOH_w_wcB
Mar 05, 2017 | Macsoft Video Game Consoles & Games
When scanning I get the following error internal DRS error 1500:c0:3001
hi,
1) go to Add/Remove Programs: Remove all HP Software.
2) Manually search for/remove all HP program files.
3) Run my Registry cleaner.
4) ONLY IF YOU KNOW WHAT YOU'RE DOING : Manually search the registry via Control F function for any remaining HP registry entries.
5) Defragment/re-install/run reg. cleaner/carefully analyze and save appropriate registry keys(see my pic's for what to definitely save).
6) Defrag. again
7) Test run HP Solution Center again.
Sep 19, 2009 | Computers & Internet
I'm getting a internal drs error 1500:c0:3001 when I am trying to scan my old documents into emails or wordpad. Paper has watermark and shaded areas. All in English
See if you can update your TWAIN compliant driver at www.twain.org... if you are using OCR (optical character recognition) software, you may want to first scan to a Word .doc (OCR tends to scan text in "clusters", like text-boxes, and your wordpad or email client may not recognize the multiple "boxes" of text...
Hope this helps!
-- RT
Sep 03, 2009 | Office Equipment & Supplies
Internal DRS error 1500:c0:3001
found this solution, maybe it also helps to solve your error.
Try and change OCR language
he was scanning documents with danish language to PDF and OCR language set to English. Received the same error, changing OCR language to danish solved his problem.
If not
go to HP support webpage:
http://www.hp.com/cgi-bin/hpsupport/index.pl
choose support and tr.. information option
enter your product name
and check if there is a fix published.
Success!
Aug 28, 2009 | HP LaserJet 3600n Printer
I'm getting a error that states.Internal DRS error 1500:c0:3001 after scanning a document while I am saving it.
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
djiu9ofdfd3
Apr 21, 2009 | HP Officejet 5610 All-In-One InkJet...
Internal drs error 1500:c0:3001
Try change the OCR language.
I had the same problem (HP Deskjet F4280, error code 1500:c0:3001) scanning documents with danish language to PDF and OCR language set to English. Changing OCR language to danish solved the problem.
PaulPS
Apr 13, 2009 | Office Equipment & Supplies
I'm getting an error:Internal DRS error:1500:c03001.PLEASE HELP!
You need to change the resolution on the scan to 200 dpi. The steps to do it vary according to your HP Solution Center software version. Just find the "Scan to PDF" settings. or create a new "default" profile because it wouldn't let you modify the installed setup sometimed without saving it under a new name.
Apr 13, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
When I scan a document on my HP deskjet f2210 and the document is
I recommend uninstalling all HP components from your add/remove section in the Control Panel - restart computer - and then reinstall from the original disk sent from the manufacturer. Do you still have the disk?
Mar 26, 2009 | HP Deskjet F2210 InkJet Printer
Using HpDeskjet f2280 All-In-One Printer, Scanner, Copier. When scanning have error message "Internal DRS Error 1500:c0:3001
You need to change the resolution on the scan to 200 dpi. I submitted this to HP and that is what they told me to do. It works. The steps to do it vary according to your HP Solution Center software version. Just find the "Scan to PDF" settings. In my case, I had to create a new "default" profile because it wouldn't let me modify the installed setup without saving it under a new name.
Oct 30, 2008 | Computers & Internet
HP Officejet J5780 All-In-One InkJet Printer Logo
336 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
