Question about HP PSC 1610 All-In-One InkJet Printer
Paper jams - HP PSC 1610 All-In-One InkJet Printer
  • 19 more comments
  • Anonymous Apr 15, 2008
    it makes some noise inside and the paper jams and get wrinkle just on the U turn(on the back side) ...someone says the problem is a worn out pinion
  • lucasch Apr 15, 2008
    it makes noise inside and jams the paper on the U turn going to outside someone says a pinion is worn out
  • humblepie Apr 21, 2008
    The paper feed is not distributed correctly and thus jams the paper crumpling it to the right side of the printer.
  • Anonymous Apr 22, 2008
    i have the same problem did anyone find out how to fix it?
  • hamzain2 Apr 23, 2008
    When I do the duplex printing the paper gets jam. It is happening every time on 2300d printer. Any possible solutions
  • Anonymous Apr 29, 2008
    paper jamming on right side lexmark z615 rarely used.
  • Anonymous May 02, 2008
    paper jam
    Paper jams as it is coming into tray
  • john haggas May 06, 2008
    i have some problem paper jams but nothing stuck in that i can see it just want load the paper into printer and paper jam light starts flashing
  • avs01 May 07, 2008
  • Anonymous May 08, 2008
    Paper jams in the right side and cannot be cleared?
  • Anonymous May 12, 2008
    Paper jam but no paper inside.
  • worthyoflove May 13, 2008
    paper jam but no paper in it also
  • lbaylor May 13, 2008
    FS-3900DN "Printer Jam Duplexer". "?" Detatch Casette 1 > Remove the paper jam > open green lever and remove paper jam. This troubleshooting procedure does not clear the jam from the sensors - what does it take to reset the software to restart the printer?
  • Anonymous May 13, 2008
    no paper to be fund,I looked every where, and no paper. what do I do?
  • Anonymous May 22, 2008
    paper jam, no manual available
  • Anonymous May 24, 2008
    Paper Jam and printer always display incorrect paper size. Approx 1" jam at output tray
  • Anonymous Jun 06, 2008
    Phaser 7300DN indicates paper jam. Followed instructions, removed the tray there is no paper to be found.
  • Anonymous Jun 08, 2008
    How do I open the back of my printer?
  • JAM QUEEN Jun 10, 2008
    HAVE PAPER JAM. HAVE CLEARED ALL PATHS STILL SAYS PAPER JAM. PRESS OK NOT WORKING. ANY SUGGESTIONS
  • DTHT Mar 25, 2009
    When we hit print, it pulls a sheet of paper half way through the printer without printing, then indicates "paper jam". When we clear the paper from the back of the printer and press "OK", it repeats the same process and never clears. We have also tried disconnecting the printer, and reconnecting it with no luck.
    Any suggestions?
    DT
  • 23 Answers
Had this problem, too with HP PSC 1610 AIO, paper would pull in part way and stop, then display would indicate: Paper Jam, Clear Jam and Press OK, but there was no paper in the path at all. Found in HP forums that possibly the problem was a broken off piece that may be called the "x-bias" lever which is on a little spring inside the printer just to the left of the carriage bay on the right side of the device. There are two photos of "broken" and "not broken" at this forum site:
http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?threadId=1085918
Since HP does not sell the little part to repair it, I phoned HP and got a good "trade-in, trade-up" price for a better device. Hope this helps someone else find the answer to the constant paper jam issue, as I always appreciate the FixYa forum help from everyone else here, too.
Posted on Jun 12, 2008
I had a paper jam with my 6210 hp printer! kids crying i'am getting upset for two day clearing up this problem. went on line and someone suggested that this was not a paper jam, but a paper sensor problem. i went back in for the last time and in the center of the paper feed roller was a black clip that move a little up and down and on the far left there was a black clip that also moved back and forward. reloaded my paper tray, and after two day of hell it is working fine. i don't know if these clips as i mention solved the problem but after reading about cleared up paper jam and it's telling you that you still have a jam?? it only wanted to be feed... paper. it should have ask for paper!
Posted on May 02, 2008
  • 435 Answers
Please visit the below mentioned link to get your printer fixed:
HP PSC 1610 Paper Jam
Thank You
Posted on Oct 20, 2008
SOURCE:
Epson xp430 paper jam, but I can't find any jam!
They don't tell lies :>) Even the smallest piece of paper over the sensor will record a jam. This often happens when you have a jam and you pull the paper and it tears a piece off. Open all the doors, remove the paper tray, remove all the toner or cartridges and look with a flashlight. Always pull paper jam paper in the direction it was going, undo tensioner clips if present and pull paper evenly and slowly as not to tear the paper. If you do, keep the paper and find the piece that fits the piece that is missing.
Having said that, see the link
Paper Jam Problems - Epson XP-430 User Manual [Page 234]
https://www.manualslib.com > ... > Epson Manuals > Printer > XP-430 > User manual
Epson XP-430 Manual Online: Paper Jam Problems. If you have problems with paper jams, try these solutions: 1. Cancel the print job from your computer, if...
SOLVED: Error says paper jam, but there is not. What could cause this ...
https://www.ifixit.com/.../Error+says+paper+jam%2C+but+there+is+not.+What+could... Dec 18, 2013 - I have an Epson Artisan 837 all in one. It was working perfectly fine yesterday. Today it is telling me I have a paper jam. I went through the steps ...
How to solve paper jam or paper feed error DO IT YOURSELF ...
? 3:43
https://www.youtube.com/watch?v=kHHpVcSJvvA
Aug 16, 2016 - Uploaded by Easyprint-DZ Support
... of commons problem of printer . paper feed error or paper jam error. ... we gonna work on epson ...
Paper Does Not Feed Correctly - Epson
https://files.support.epson.com/htmldocs/pho22_/pho22_rf/trble_4.htm Paper does not feed. Multiple pages feed. The paper jams. Paper is not ejected fully or is wrinkled. Paper does not feed correctly when using the double-sided ...
Epson XP-430 ' XP Series ' All-In-Ones ' Printers ' Support ' Epson US
https://epson.com/faq/SPT_C11CE59201~faq-293729 Mar 24, 2016 - If paper jams when you load only one or two sheets, try loading more sheets at a time. Do not load more than the recommended number of ...
Epson xp430 paper jam Google Search
Oct 23, 2017 | Epson Office Equipment & Supplies
Paper jams at toner cartridge, printer service maintenance kit installed
Paper Jam clearing: copy and paste the link in your web browser...I used to work with these printer's..when they work great, when they don't, not so great..
https://www.manualslib.com/manual/949165/Hp-Laserjet-5000.html?page=84
Clearing Paper Jams If the printer's control panel displays a paper jam message, look for paper in the locations indicated in Figure 22, then see the procedure for clearing the paper jam. You might need to look for paper in other locations than indicated in the paper jam message. If the location of the paper jam is not obvious, look first in the top cover area.When clearing paper jams, be very careful not to tear the paper. If a small piece of paper is left in the printer, it could cause additional jams. If paper jams are a recurring problem, see page 78.(A paper jam message might also display if the rear door is open.)
The top cover of the printer must be opened and then closed to clear a paper jam message.Paper jams can occur at the following locations:Output areas(top and rear)Go to page 75.
Loose toner might remain in the printer after a paper jam, but thetoner should clear after a few sheets are printed.
Jan 31, 2018 | HP LaserJet 5000n Printer
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
Error e03, but there is no jammed paper
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
My canon MP620 Paper Jam Pull out the Jam Paper Al
There are pieces of paper stock on the sensor, when the paper jam happened then you pull out the paper did you get the whole page of the paper or have missing pieces? open the paper guide, turn off and on the printer and observe the unusual objects in the roller, this error is caused by objects in the sensor.
Oct 20, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Getting the error on my HP 4345mfp - TOP OUTPUT BIN, PAPER LATE JAM. 5017-Oct-2009 02:02 PM18209913.09.0048.081.2TOP OUTPUT BIN, PAPER LATE JAM 4917-Oct-2009 02:00 PM18209613.09.0048.081.2TOP OUTPUT BIN,...
my experience says jamming in duplex area using card stock. this may occur if default is duplexing. set default to single side and / or try same job using plain a4 80gm2
Oct 20, 2009 | HP LaserJet M4345 MultiFunction Printer
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Paper Jam
Good day, Check the table below about the problem of paper jams.
Display and Meaning
[Paper Jam 0] - Paper has Jammed in the feeding area of the paper input tray.
[Paper Jam 1] - Paper has jammed in the fuser area or in the manual feeder.
[Paper Jam 2] - Paper has jammed in the paper exit area.
hope it will help you.
Jun 04, 2009 | Samsung SCX 4200 All-In-One Laser Printer
HP PSC 1610 All-In-One InkJet Printer Logo
1,287 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
